    MMM-Scrobbler CSS
    16 Posts 5 Posters 10.6k Views 6 Watching
      spwood100
      You are an absolute legend, let me pull the latest version and I will test and let you know
        PtrBld Module Developer
        if you want the meta text centered you need to add
        .right > .meta {
            /* margin-left: 16px; */
            margin: auto 16px;
        to your css.
          spwood100
          Works like a dream with just a few “nuances” such as if you have it on the right side of the screen with the meta data to the right of the image, the meta data disappears off the screen and I suspect the same with the left. Otherwise its really good … thanks so mch!!!
            j.e.f.f Project Sponsor Module Developer @PtrBld
            @PtrBld said in MMM-Scrobbler CSS:
            .right > .meta {
            margin: auto 16px;
            to your css.
            It’s a good idea to add the module’s name to this rule so that it does not accidentally affect another module that coincidentally happens to use the same class names. Something like this:
            .module.MMM-Scrobbler .right > .meta {
                margin: auto 16px;
              spwood100
              Thanks @PtrBld for you lightning quick turn around of this one and to @j-e-f-f for the extra advice, much appreciated
                SoleLo @spwood100
                @spwood100 how did you get the “Spotify Music” header at the top of it?
                • yawnsY Offline
                  yawns Moderator @SoleLo
                  @solelo said in MMM-Scrobbler CSS:
                  Please try this:
                  	module: 'MMM-Scrobbler',
                  	header: 'Spotify Music', // <<<<<<
                  	position: 'top_right',
                  		username: 'Last.fm username',
                  		apikey: 'Last.fm api key',
                  		//time interval to search for new song (every 15 seconds)
                  		updateInterval: 15 * 1000,
                  		//how often should we try to retrieve a song if not listening
                  		delayCount: 5,
                  		//time interval to search for new song if the 5 times not listening is received.
                  		//set this to the same number as updateInterval to ignore this option
                  		delayInterval: 120*1000,
                  		animationSpeed: 1000,
                  		showAlbumArt: true,
                  	    	showMetaData: true,
                  		//Determines the position of the meta text. Possible values: top, bottom, left, right
                  		alignment: "bottom",
                    SoleLo @yawns
                    @yawns that worked perfect. Now it’s blocking the bottom MyCommute module, any ideas how to get that fixed?
                    0_1530732002100_1de39f6e-2620-4867-860e-8175f194ba74-Screen Shot 2018-07-04 at 12.18.22 PM 🌚.png
                      spwood100
                      @SoleLo , add the following into the module config
                      header:
                      So for example
                      module: ‘MMM-Scrobbler’,
                      header: 'insert your text here'
                      Should work, let me know if it doesnt
                        SoleLo @spwood100
                        @spwood100 I got it to work but it shows up over the MyCommute module…
