    MMM-Scrobbler CSS
    16 Posts 5 Posters 11.0k Views 6 Watching
      spwood100
      That would help wouldnt it :-)
      How it currently displays:
      How it would be useful to have the option to diplay
      I have seen other examples where this has been achieved but not sure how its done. If its possible to have different display options in the app settings that would be awesome !
      Thanks for your help
        PtrBld Module Developer
        Ok, now it is clear.
        I just updated the module and you should now be able to use the key “alignment” in your config.
        	module: 'MMM-Scrobbler',
        	position: 'top_right',
        		username: 'Last.fm username',
        	        apikey: 'Last.fm api key',
        		//time interval to search for new song (every 15 seconds)
        		updateInterval: 15 * 1000,
        		//how often should we try to retrieve a song if not listening
        		delayCount: 5,
        		//time interval to search for new song if the 5 times not listening is received.
        		//set this to the same number as updateInterval to ignore this option
        		delayInterval: 120*1000,
        		animationSpeed: 1000,
        		showAlbumArt: true,
        	    	showMetaData: true,
        		//Determines the position of the meta text. Possible values: top, bottom, left, right
        		alignment: "bottom",
        This is not tested since I do not have a mirror atm but it should work ;)
          spwood100
          You are an absolute legend, let me pull the latest version and I will test and let you know
            if you want the meta text centered you need to add
            .right > .meta {
                /* margin-left: 16px; */
                margin: auto 16px;
            to your css.
              spwood100
              Works like a dream with just a few “nuances” such as if you have it on the right side of the screen with the meta data to the right of the image, the meta data disappears off the screen and I suspect the same with the left. Otherwise its really good … thanks so mch!!!
                j.e.f.f Project Sponsor Module Developer @PtrBld
                @PtrBld said in MMM-Scrobbler CSS:
                .right > .meta {
                margin: auto 16px;
                to your css.
                It’s a good idea to add the module’s name to this rule so that it does not accidentally affect another module that coincidentally happens to use the same class names. Something like this:
                .module.MMM-Scrobbler .right > .meta {
                    margin: auto 16px;
                  spwood100
                  Thanks @PtrBld for you lightning quick turn around of this one and to @j-e-f-f for the extra advice, much appreciated
                    SoleLo @spwood100
                    @spwood100 how did you get the “Spotify Music” header at the top of it?
                    • yawnsY Offline
                      yawns Moderator @SoleLo
                      @solelo said in MMM-Scrobbler CSS:
                      Please try this:
                      	header: 'Spotify Music', // <<<<<<
                      		delayCount: 5,
                      		showAlbumArt: true,
                      	    	showMetaData: true,
                        SoleLo @yawns
                        @yawns that worked perfect. Now it’s blocking the bottom MyCommute module, any ideas how to get that fixed?
                        0_1530732002100_1de39f6e-2620-4867-860e-8175f194ba74-Screen Shot 2018-07-04 at 12.18.22 PM 🌚.png
                          spwood100
                          @SoleLo , add the following into the module config
                          header:
                          So for example
                          module: ‘MMM-Scrobbler’,
                          header: 'insert your text here'
                          Should work, let me know if it doesnt
                            SoleLo @spwood100
                            @spwood100 I got it to work but it shows up over the MyCommute module…
                              spwood100
                              @SoleLo , that would be something to do with the relative sizes of the modules. You would probably need to play about with some custom css to get these to not overlap, something I am still struggling with on my screen from time to time.
                              Some excellent posts in the forum on css though:
                              https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works.
                              You could also post in the CSS help section?
                              https://forum.magicmirror.builders/category/31/development
                              Cheers
                                SoleLo @spwood100
                                @spwood100 thanks I actually just did some trial and error and figured it out, It was much simpler than I thought.
