    UpdateDom not working
    22 Posts 3 Posters 13.3k Views 3 Watching
      A Former User @sharmmoh1983
      @sharmmoh1983
      If you have not drawn any DOM in .getDom(), that error message will be emitted when you call .updateDom()
        sharmmoh1983 @Guest
        @Sean I have drawn DOM in getDOM() by doing this:
        this.show(0);
        this.updateDom();
        updateDom() will call get DOM() first and in that hidden will be false and hence will get executed
        There seems to be issue in conflict in positions defined in config… like top_left and top_center as I removed one of the entries which were common same issue does not appear
        This is my config file:
        module: “alert”,
        module: “updatenotification”,
        position: “top_bar”
        	module: "compliments",
        	position: "top_third"
        	module: "newsfeed",
        	position: "bottom_bar",
        		feeds: [
        				title: "New York Times",
        		showSourceTitle: true,
        		showPublishDate: true
        module: ‘MMM-Voice-Control-Sonus’,
        projectId: ‘aimevoice2017’,
        keyFilename: ‘/resources/AimeVoice-91efae41b5b4-1.json’,
        hotWord : ‘aime’,
        hotWordFile : ‘/resources/aime.pmdl’
        module: ‘MMM-googlemaps’,
        position: ‘top_center’,
        apikey: ‘AIzaSg5aknOUo5shOQ’,
        origin: ‘-31.952326,115.857847’,
        destination: ‘-32.00469,115.89405’,
        width: “600px”, // Optional. Default: 100%
        height: “300px” //Optional. Default: 100px
        module: “MMM-EmbedYoutube”, // Path to youtube module from modules folder Exmaple: MagicMirror/modules/custom/youtube/ so it’s custom/youtube
        position: “bottom_left”, // This can be any of the regions.
        // See ‘Configuration options’ for more information.
        watch: “w3jLJU7DT5E”
        module: ‘MMM-Events’,
        position: ‘top_left’,
        city: “Bangalore”, // Your City
        eventType: “sports”, // Choose from Events List below
        when: “This Week”, // “All”, “Future”, “Past”, “Today”, “Last Week”, “This Week”, “Next week”, and months by name, e.g. “October”
        mode: “noFrame”, // “Frame” or “noFrame” (around picture)
        apikey: “8V8gdwJ8WcHQnLJB”,
        rotateInterval: 5 * 60 * 1000, // New Event Appears every 5 minutes
        useHeader: false, // Set to true if you want a header
        header: “”,
        animationSpeed: 3000, // Event fades in and out
        picture: true, // true, false = no image
        When I comment out MMM-googlemaps in above config then there is no issue . IS it related to position values??
        ? 1 Reply Last reply
          @sharmmoh1983
          Yes. If you have not declared position, it will cause error when you call updateDom
          you can check ‘this.postion’. I use like these;
                if(this.data.position) {
                  this.updateDom()
                } else {
                  //nothing to do
            sharmmoh1983
            But in my case I have declared positions in my config . But my issue is if positions of module somehow overlaps or matches top or bottom (like in my case top_left and top_center ) is causing the issue
              sharmmoh1983
              Kindly assist me in getting this resolved as I am stuck .
              I am planning to hide modules upfront and the enable through voice as in when required
              J 1 Reply Last reply
                j.e.f.f Project Sponsor Module Developer @sharmmoh1983
                @sharmmoh1983 I’m not sure if the positions of the modules have anything to do with your problem, but I did struggle with a similar problem in one of my modules. Basically you can’t do ANYTHING with the Dom until MM has finished creating all the Dom objects. This will happen well after your module’s start() function is called.
                Basically you need to wait for the notification DOM_OBJECTS_CREATED before you can do things like hide or show the module. Here’s an example:
                    if ( notification == 'DOM_OBJECTS_CREATED') {
                      //now the Dom is ready; you can call hide() or show().
                      this.hide(0, {lockString: this.identifier});
                I hope this helps!
                  sharmmoh1983
                  But in that case all my modules will be appearing on screen which I don’t want and should only appear at voice command
                    @sharmmoh1983 Not the case, especially if you call hide(0). This all happens before a single screen refresh, so you won’t see the module on-screen for a split second before it hides.
                      sharmmoh1983
                      @j-e-f-f
                      I want all modules to hide during start
                      ? J 2 Replies Last reply
                        @sharmmoh1983 instead of hide, how about using display:none in css?
                          A Former User
                          Now i understand whats going on. You had tried to hide modules before dom created.
                          My suggetion is;
                          1. use css for making modules invisible with display:none on startup.(or cover all modules with temp div which has black background on top level)
                          2. after Dom_object_created message received, hide all module with .hide().
                          3. then change css again for displaying, or remove the covered div.
                          4. then you can use your command.
                            sharmmoh1983
                            @Sean
                            I will look into the approach but I don’t want every module to be off , some commanded by voice so can’t make use of css
                              sharmmoh1983
                              @Sean Also updateDOM is also creating DOM first so there should be no issue of DOM getting created or not
                                sharmmoh1983
                                @Sean @j-e-f-f Thanks for your support… i will try the discussed approach also and come back with my findings
                                  @sharmmoh1983 said in UpdateDom not working:
                                  Yep you can do it. the MM object has a method called getModules() which will give you all the loaded modules. Example:
                                  var modules = MM.getModules();
                                  modules.enumerate(function(module) {
                                      module.hide(0, {lockString: "yourLockString"});
                                    sharmmoh1983
                                    @j-e-f-f But where it call this as all modules will be loaded simultaneously
                                      sharmmoh1983 @j.e.f.f
                                      @j.e.f.f But where to call mentioned code as all modules will be loaded simultaneously
                                        @sharmmoh1983 call it in your routine that responds to the DOM_OBJECTS_CREATED notification.
                                        You can’t hide a module before its Dom exists. When this notification is dispatched it means all modules have started AND their Dom objects have been created for the first time. It’s the earliest opportunity you have to hide any modules.
                                          @j.e.f.f I am not generating DOM while start of the module but at voice command and this approach is working individually for the modules but not if all are coupled together So how come it is happening for individual modules
                                            @sharmmoh1983 all the Dom objects for all modules are created automatically when MagicMirror starts. This is not under your control, even for your own module. Your getDom() routine is called when your module’s Dom object is initially created. This is why it is common to see a conditional in getDom() routines that returns something like a simple string (e.g.: “Loading…”). Once your Dom object has been created, you can call updateDom() at your discretion to make changes to whatever your module displays. If you don’t want your module to display anything, then don’t specify a location in the config for your module. If a location is specified, SOMETHING will appear there, even if you don’t have a getDom() routine.
                                            You can’t make changes to another module’s Dom object, but you can hide or show it. However, you can’t do that until that Dom object is initially created.
                                            When all the Dom objects for all modules have been created at startup, MagicMirror dispatches the DOM_OBJECTS_CREATED notification. By waiting for this notification, you can be sure that any module you attempt to hide will be hidden.
