Npm start throwing error
5 Posts 2 Posters 2.3k Views 2 Watching
  • N Offline
    nepsilonn
    Hi there and thank you for spending time reading this message.
    I got excited very much by this project, and i decided to make a MagicMirror on my own.
    I have followed up the whole tutorial
    bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)
    I ended up getting an error saying Electron did not install properly.
    I did RM RF node_modules and npm install from beginning
    Still in the end it is the same error that comes up
    /home/pi/MagicMirror/node_modules/electron/index.js:9
    throw new Error - Electron failed to install correctly, please delete node_modules/electro and try installing again.
    [0_1506123706492_npm-debug.log](Uploading 100%)
    Below here i am pasting the npm-debug.log
    Any help is appreciated. Thank you.
    1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
    2 info using npm@3.10.10
    3 info using node@v6.11.3
    4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
    5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
    6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
    7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
    8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
    9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
    10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
    11 silly lifecycle magicmirror@2.1.2~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
    12 silly lifecycle magicmirror@2.1.2~start: Returned: code: 1 signal: null
    13 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
    14 verbose stack Error: magicmirror@2.1.2 start: sh run-start.sh
    14 verbose stack Exit status 1
    14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
    14 verbose stack at emitTwo (events.js:106:13)
    14 verbose stack at EventEmitter.emit (events.js:191:7)
    14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
    14 verbose stack at ChildProcess.emit (events.js:191:7)
    14 verbose stack at maybeClose (internal/child_process.js:920:16)
    14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
    15 verbose pkgid magicmirror@2.1.2
    16 verbose cwd /home/pi/MagicMirror
    17 error Linux 4.9.41-v7+
    18 error argv “/usr/bin/node” “/usr/bin/npm” “start”
    19 error node v6.11.3
    20 error npm v3.10.10
    21 error code ELIFECYCLE
    22 error magicmirror@2.1.2 start: sh run-start.sh
    22 error Exit status 1
    23 error Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.
    23 error Make sure you have the latest version of node.js and npm installed.
    23 error If you do, this is most likely a problem with the magicmirror package,
    23 error not with npm itself.
    23 error Tell the author that this fails on your system:
    23 error sh run-start.sh
    23 error You can get information on how to open an issue for this project with:
    23 error npm bugs magicmirror
    23 error Or if that isn’t available, you can get their info via:
    23 error npm owner ls magicmirror
    23 error There is likely additional logging output above.
    24 verbose exit [ 1, true ]
    M 1 Reply Last reply Sep 23, 2017, 12:24 AM Reply Quote 0
    • N Offline
      nepsilonn
      Just a small update.
      I have followed the suggestions made from Mykle1 on some posts below, but i did not get any good results of this.
      I did manual installation and i still get exactly the same error.
        Mykle1 Project Sponsor Module Developer @nepsilonn
        @nepsilonn said in Npm start throwing error:
        This is telling you to delete the Electron folder
        NOT the node_modules folder, which you deleted.
        I don’t know where you think you read that I suggested that. Certainly not in this topic.
        So, what you should have done is delete JUST the Electron folder and run npm install in the MagicMirror directory
        N 1 Reply Last reply Sep 23, 2017, 9:14 AM Reply Quote 0
        • N Offline
          nepsilonn @Mykle1
          https://forum.magicmirror.builders/topic/4879/npm-start/7 I read your suggestion from here.
          Not the rm rf as a suggestion from you, but rather manual installation.
          Now it works, thank you for this.
          M 1 Reply Last reply Sep 23, 2017, 12:40 PM Reply Quote 0
            That’s good news. Enjoy your mirror.
