    Problem with fresh Installation.
    8 Posts 4 Posters 7.0k Views 4 Watching
    • zamZ Offline
      zam
      Hi , Fresh installation …
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh) everything going smoother on final stage … installing dependencies giving below error
      npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
      npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
      npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
      npm ERR! Linux 4.9.41-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! node v6.11.3
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! electron@1.7.8 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@1.7.8 postinstall script 'node install.js'.
      npm ERR! If you do, this is most likely a problem with the electron package,
      npm ERR! not with npm itself.
      npm ERR!     node install.js
      npm ERR!     npm bugs electron
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls electron
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      Unable to install dependencies!
      Any Solutions ???
      • Sandy2503S Offline
        Sandy2503
        Hi Zam !
        today i have installed a fresh mirror too.
        wich raspian have you used ? Rapian strech or jessi ?
        with stretch my mirror won`t start too. with the latetst jessi (full) my mirror works well.
        and try this to -->
        This is due to the new release yesterday of Electron 1.7.8 but a build hasn’t been updated yet for linux-arm. In the meantime, just run the command
        sudo npm install -g electron@1.7.6
        after the failure and then continue with the installation.
        it seems to be, that there is a problem with the 1.7.8 with the raspi …
        Greetz Sandy2503
        7 1 Reply Last reply Reply Quote 0
        • zamZ Offline
          zam
          @Sandy2503 said in Problem with fresh Installation.:
          Yes i am installing with ¨RASPBIAN STRETCH WITH DESKTOP¨ let me try your solution and see thanks
          Zam
          • 7 Offline
            7even @Sandy2503
            @Sandy2503
            Do you have a link to the jessie (full) that you used?
            Sandy2503S 1 Reply Last reply Reply Quote 0
              Sandy2503 @7even
              @7even
              i have installed the 2016-11-25-raspbian-jessie.img from my local harddisk.
              check google for the image like this link --> http://domoticx.com/raspberry-pi-sd-image-raspbian-linux-os/
              7 Mykle1M 2 Replies Last reply Reply Quote 0
              • 7 Offline
                7even @Sandy2503
                @Sandy2503
                Thanks… will try it out now.
                  Mykle1 Project Sponsor Module Developer @Sandy2503
                  I don’t suppose you have a firmware hash from that version? I cooked a Pi with Stretch and I’m trying to get my firmware back to that date
                  • zamZ Offline
                    zam
                    Yes i think the issue is with the electron latest version … i have installed 2017-01-11-raspbian-jessie .img it’s working fine … Thanks guys for the help Cheers…
