    Incorrect Time Display in calendar(06:00 instead of 18:00 of 06:00PM)
    8 Posts 5 Posters 3.7k Views 5 Watching
    • E Offline
      erikgroentje
      I’ve Fixed it myself! Changed the timeformat here and it worked. It now shows me 18.00
      switch (config.timeFormat) {
      case 12: {
      moment.updateLocale(config.language, {
      longDateFormat: {
      LT: “h:mm A”
      break;
      case 24: {
      longDateFormat: {
      LT: “hh:mm”
      strawberry 3.141S M G 3 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @erikgroentje
        @erikgroentje this bug is already fixed and will be in the next release https://github.com/MichMich/MagicMirror/pull/943
          MrEdOne @erikgroentje
          @erikgroentje
          Can you show what you change?
          /// NVM i have this :D
          • G Offline
            goprojojo @erikgroentje
            @erikgroentje What did you exactly changed in calendar.js to show 18:00 format?
              Mykle1 Project Sponsor Module Developer @goprojojo
              @goprojojo said in Incorrect Time Display in calendar(06:00 instead of 18:00 of 06:00PM):
              This should fix the time format for you.
              Edit your calendar.js. Find the line that says:
              longDateFormat
              Change LT: "hh:mm" to LT: “HH:mm”
              G 1 Reply Last reply Reply Quote 2
              • G Offline
                goprojojo @Mykle1
                @Mykle1 Thnx. It works!
                  Thnx. It works!
                  Fantastic! :^)
