    Further development of the MMM-Swipe module
    25 Posts 7 Posters 15.1k Views 7 Watching
      c.keen
      First, a big THANK YOU for all module developers. Unfortunately - and thats the reason why I am posting here - I am a real programming NOOB. I am only able to follow tutorials others wrote and use the good modules others programmed.
      As already mentioned in the header, I want to aks if s.o. is interested in developing the MMM-Swipe module further , using the HC-SR04 sensors. If you have followed the development of the module two guys (mochman and shbatm) have already programmed on this module and I am a huge fan of the idea - hope that it going to work soon!
      Last time I discovered the MMM-Pages and asked the developer if he would be interested in taking over the MMM-Swipe development as pages could be changed by swiping it. Sadly he won’t have time available in the near future.
      I would be very happy if someone is out there wanting to take over this great project!
      Regards,
      c.keen
        StefanMe
        Thanks Keen!
        I need exactly this! i couldnt get this module work until now. What is your expirience with eather of this modules?
        The one from mochaman is starting fine in sudo, and the sensors recognice my hand in calibration mode, but in vebose mode it doesnt work at all! It just happens nothing.
        The other module from shbatm is running without sudo but not starting completly… showing just Loading MMM-Swipe...
          c.keen
          Same here for me. The one from mochman didn’t work entirely as intended.
          The fork from shbatm I never tried because he wrote that due to problems using the sensor which his dog did not very much liked the module is not finshed yet. I totally understand that he is going to try another way because he won’t be able to use the sensors.
          Hope there will be more people who want that module finished. I think it could be a very effective way to switch between pages once it is running.
          • N Offline
            nowis
            Hey,
            I tried to use the MMM-Swipe module some month ago, but without any success. No I finally had time to look over it and figured out a way to use the HC-SR04 sensors without sudo. So far the module recognizes if you out your hand in front of a sensor, but I haven’t tried to calibrate a nice “swipe” gesture, yet.
            I would be up to develop the module further, including a switch page functionality.
            Since I took the one from mochman as a starting base, I would ask him if it’s ok if i fork or link to his page in a new repo.
            So if you guys want, I will try to upload my module soon (after cleaning up a little bit).
              c.keen
              @nowis: That sounds great!
              Maybe you can also take a look at the module shbatm created. I don’t know what the status of the module is he developed but he wrote that it is up to 90% ready to use.
              Although I have no clue about programming I think it should be possible to use the MMM-Swipe module in connection to the MMM-Pages from edward-shen. He also uses some kind of input (skywriter) to give commands to the pages module to switch pages.
              But for daily use I would prefer the HCSR-04 sensors.
              • N Offline
                nowis
                I will have a look at both modules sometime the next week. Will keep you updated.
                  StefanMe
                  That would be awesome!
                  Thanks! I also would donate it if it works later! Because i really want this feature!
                  • N Offline
                    nowis
                    Hey,
                    I got the module up and running. I forked shbatm’s module and changed the method of how to detect a swipe. It is not perfect, yet, but it works for me.
                    There is still more work to do, but I thought I will share it with you already, so you can try it. It works with the MMM-Pages module.
                    I will continue working on it the next days. Feel free to share your experience with me, as well as ideas for improvements.
                    It took me a while to “learn” the right technique to swipe. I put my hand in front of one sensors (try to make form a flat surface with your hand), stay there for about 400ms (sounds weird, sorry) and then swipe from there over the other sensor. Just practice a little bit. The swipe detection is not trivial.
                    Here is the link, have fun! https://github.com/Simon089/MMM-Swipe
                    richland007R 1 Reply Last reply Reply Quote 0
                    • richland007R Offline
                      richland007 @nowis
                      @nowis
                      Hi there i followed your instructions step by step and got everything installed from your fork for MMM-Swipe, however when i add the MMM-Swipe config parameters to the MM’s config.js file and start the Magic Mirror i get a blank screen and nothing else .
                      Only after ctr-alt-del and manually killing the MagicMirror instance (ctrl+q does nothing in this case) i am able to get back to Rpi’s desktop.
                      After inspecting the MagicMirror npm start messages i found out that MMM-Swipe and some error with math-statistics module (i do not have a MagicMirror math statistics module) being unavailable that seems to be the culprit of it all, it also seems that the math statistic’s module is a node.js package of MMM-Swipe.
                      If i go back to MagicMirrors nonfig.js and comment out the MMM-Swipe module everything works just fine with my MagicMirror … what do you think it is happening??
                      Does it have anything to do with maybe the physical sensors?? They are wired just as they are supposed to according to the schematics but maybe they are not working?!?!?!
                      I am unable to give it an answer by myself so any help will be greatly appreciated
                      Thank you in advance
                      Denis
                        AxLed Module Developer
                        @richland007
                        i had the same error on a rpi1 B, here is a solution that worked for me:
                        Change into MagicMirror/modules/MMM-Swipe
                        npm install math-statistics –save
                        After that i got an new error like
                        Error: Module version mismatch. Expected 48, got 50)
                        Solution for this:
                        Rebuild module for the correct elecron version
                        npm rebuild --runtime=electron --target=$(../../node_modules/electron/cli.js --version) --disturl=https://atom.io/download/atom-shell --build-from-source
                        Regards
                        Axled
