    602 Posts 67 Posters 2.4m Views 68 Watching
    • NiggichN
      Niggich @barnosch
      @barnosch thx this works fine for me…
        shbatm Module Developer
        @barnosch @Niggich - Glad you got it working. I will clarify in the next update: the camera port should be included in the url. The port setting for the stream is actually the socket ffmpeg uses (when ffmpeg is used instead of omx).
        If anyone has any additional feature requests, clarifications, config options they would like, please let me know on here. I will get back to working on this module in the coming weeks; I am Houston, TX based so I’ve been occupied with other matters recently.
        • NiggichN
          Niggich
          @shbatm - The stream is working. Now I have another question/problem. When I hide the module an show it again the Video picture is in Fullscreen. Any fix for this? thx a lot…
            @Niggich I will need to investigate further.
            As a temporary fix, you can try deleting Line 107 and Lines 109-114 in the node_helper.js file:
                ~/MagicMirror/modules/MMM-RTSPStream/node_helper.js
            You should be deleting the if…else block and this line will remain:
            args.unshift("--win", `${payload.box.left}, ${payload.box.top}, ${payload.box.right}, ${payload.box.bottom}`);
            I do not know if this will fix the problem but it is worth a try. I have opened Issue #13 to track the position, border, and fullscreen resume problems.
            NiggichN 1 Reply Last reply
              shbatm Module Developer @barnosch
              @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              added the pkill commands but it does not work. It does not kill the apps.
              From time to time, the feed disappears. Have not yet found when and why.
              Sometimes it runs 2 days without problems, the other day it only lasts for some hours.
              Issue #14 opened to track this problem to closure.
              • NiggichN
                Niggich @shbatm
                @shbatm thank you for the fast answer, but this doesn’t fix the problem.
                  shbatm Module Developer @Niggich
                  @Niggich could you please post your server log (console or PM2’s log file) when it does this? You should have several lines starting with:
                  Starting stream stream1 with args:
                  Also, what are you using to show/hide the module? (via MMM-Remote-Control or another module?)
                  This will help diagnose.
                  • NiggichN
                    Niggich @shbatm
                    @shbatm To show/hide the modules I using MMM-remote-Control.
                    Here’s the server log.
                    Starting stream stream1 with args: [
                    0|mm       |     "--avdict",
                    0|mm       |     "rtsp_transport:tcp",
                    0|mm       |     "--win",
                    0|mm       |     "203.390625, 1491.390625, 523.390625, 1731.390625",
                    0|mm       |     "--live",
                    0|mm       |     "--video_queue",
                    0|mm       |     "4",
                    0|mm       |     "--fps",
                    0|mm       |     "30",
                    0|mm       |     "rtsp://192.168.113.125:554/live/ch1"
                    0|mm       | ]
                    0|mm       | Starting stream stream2 with args: [
                    0|mm       |     "--avdict",
                    0|mm       |     "--win",
                    0|mm       |     "553.390625, 1491.390625, 873.390625, 1731.390625",
                    0|mm       |     "--live",
                    0|mm       |     "4",
                    0|mm       |     "--fps",
                    0|mm       |     "30",
                    0|mm       |     "rtsp://192.168.113.103:554/live/ch1"
                    0|mm       | ]
                    • K
                      kasperb
                      @shbatm thanks for the great module!
                      In order to make my camera work in omxplayer, I need to enter the following command before the RTSP streaming URL in Terminal:
                      omxplayer --avdict rtsp_transport:tcp
                      The RTSP stream works fine with the added command in omxplayer. Full working command for reference:
                      omxplayer --avdict rtsp_transport:tcp rtsp://admin:admin@192.168.0.130:10554/tcp/av0_1
                      Is there a way to add the command to the config in order for the camera to work?
                      When looking at node helper.js I see the following reference:
                          if (this.config[payload.name].protocol !== "udp") {
                              args.unshift("--avdict", "rtsp_transport:tcp");
                      I’ve tried to switch the protocol in the config to ‘udp’ (as well as ‘tcp’) to no avail. I hope you could point me in the right direction in order to solve this issue.
                      Full config below for reference:
                                  module: 'MMM-RTSPStream',
                                  position: 'middle_center',
                                      autoStart: true,
                                      rotateStreams: false,
                                      rotateStreamTimeout: 10,
                                      showSnapWhenPaused: false,
                                      moduleWidth: 354,
                                      moduleHeight: 240,
                                      moduleOffset: 0,
                                      localPlayer: 'omxplayer',
                                      stream1: {
                                          url: 'rtsp://admin:admin@192.168.0.130:10554/tcp/av0_1',
                                          protocol: 'udp',
                                          snapshotUrl: '',
                                          snapshotRefresh: 10, // Seconds
                                          frameRate: "5",
                                          port: 9999,
                      Thanks in advance!
                        shbatm Module Developer @kasperb
                        @kasperb said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        Adding protocol: 'tcp' should have done the trick. You can also try just removing the protocol line completely since the default protocol is TCP. The default command for omxplayer is:
                        omxplayer --avdict rtsp_transport:tcp --win 'x y w h' --live --video_queue 4 --fps 30 {{url}}
                        The bit of code you referenced is to not include --avdict rtsp_transport:tcp when using a UDP stream.
                        Also, check the console log to see what command was used to start OMXPlayer. It should print the list of arguments.
                        • K
                          kasperb
                          @shbatm Thanks for clarifying. I’ve removed protocol: 'tcp' from the config.
                          When executing the default command in Terminal, the video displays properly on my screen.
                          The MM logs indicate that the stream is started accordingly as well (see below), but unfortunately still nothing is visible on my Mirror.
                          0|mm       | Starting stream stream1 with args: [
                          0|mm       |     "--avdict rtsp_transport:tcp",
                          0|mm       |     "--win",
                          0|mm       |     "379.5, 841.5, 731.5, 1083.5",
                          0|mm       |     "--live",
                          0|mm       |     "4",
                          0|mm       |     "--fps",
                          0|mm       |     "30",
                          0|mm       |     "rtsp://admin:admin@192.168.0.130:10554/tcp/av0_1"
                          0|mm       | ]
                            @kasperb - I have a suspicion – I think this is the same issue @Niggich was having where OMXPlayer doesn’t like non-integer window dimensions.
                            Please try changing the moduleOffset: 0, setting to 0.5 and see if the video will work. If it works, you can change the offset back to 0 and try updating the module with the patch I just pushed:
                            cd ~/MagicMirror/modules/MMM-RTSPStream
                            git fetch --all
                            git pull
                            If you experience issues with the stream stopping after running for a few days, I am still finalizing work on another branch to resolve this: wip_patch which runs OMXPlayer through pm2 so it will automatically restart feed and hopefully be more stable.
                            B K 2 Replies Last reply
                              barnosch @shbatm
                              @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              Great! Looking forward to it.
                              • K
                                kasperb @shbatm
                                @shbatm I’ve tried changing the moduleOffset to 0.5, as well as some other experimental values, but unfortunately that didn’t do the trick.
                                The configuration itself should work, as I had it working with a different RTSP cam previously.
                                K 1 Reply Last reply
                                  Johans
                                  Can’t get this up and running.
                                  tried to figure out the problem but as i’m newbie i’m missing the skills to locate the problem.
                                  what I have done so far:
                                  Tested my Foscam stream with VLC. This didn’t worked either. error message:
                                  //Uw invoer kan niet geopend worden:
                                  VLC kon de MRL 'rtsp://garden:garden1000%@192.168.1.241:1052/Videomain' niet openen. Controleer het logboek voor details.
                                  then tested VLC with default stream - and this is working fine.
                                  Next installed omxplayer and applied my camera stream as follows.
                                  //sudo omxplayer -o hdmi rtsp://garden:garden1000%@192.168.1.241:1052/videoMain
                                  Video codec omx-h264 width 1280 height 720 profile 66 fps 8.333333
                                  Audio codec pcm_mulaw channels 1 samplerate 8000 bitspersample 8
                                  Subtitle count: 0, state: off, index: 1, delay: 0
                                  V:PortSettingsChanged: 1280x720@8.33 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                  This works perfect, getting full image on the display.
                                  conclusion: software is OK - just weird that my stream is not working on VLC.
                                  could it because password has special char ‘%’ in it?
                                  as omxplayer seams to work, I went back to config and added omxplayer.
                                  switched to the wip branch.
                                  started mirror - nothing happens - i get a blank screen. - below my config
                                  			    classes: 'default everyone',
                                  		                autoStart: true,
                                  		                moduleWidth: 354,
                                  		                moduleHeight: 240,
                                  		                stream1: {
                                  		                    name: 'Webcam 1 Test Stream',
                                  		                    url: 'rtsp://garden:garden1000%@192.168.1.241:1052/videoMain',
                                  		                    snapshotUrl: '',
                                  		                    frameRate: "25",
                                  		                    port: 9999,
                                  without omxplayer and master branch active, I see the video play icon on the mirror, but nothing is displayed.
                                  any ideas help to get this running would be great.
                                  Also installed MMM-IP webcam but also no image from the webcam.
                                  J K 2 Replies Last reply
                                    Johans @Johans
                                    Switched back to master branch
                                    started in dev mode.
                                    error info see picture
                                    • K
                                      kasperb @kasperb
                                      @shbatm I did a fresh install of the module, and am pleased to inform you that it’s working fine now. Thanks for your help!
                                      • K
                                        kasperb @Johans
                                        @Johans I had a similar issue, and was able to resolve it by re-installing the module.
                                        I just realized that I also added the cam’s ip to the IP whitelist and moved this module to the top of the config; not sure if that did anything, but mine is working now, so it might be worth a shot.
                                        J 1 Reply Last reply
                                          shbatm Module Developer @Johans
                                          @Johans Which other modules are you using? It looks like you may be using something like MMM-ProfileSwitcher, there may be a conflict between these modules or it may be because of the % symbol in the password.
                                          Also, when you switched to the wip branch, did you remember to re-run npm install in that folder? There are some additional dependencies for the wip branch.
                                            Johans @shbatm
                                            @shbatm
                                            re-installed module, changed IPcams password and removed the ‘%’
                                            Result: No live stream.
                                            swiched module to wip branch for usage with omxplayer:
                                            Result OK, I can see the live stream from the IPCAM - so that is working.
                                            so thanks for the feedback.
                                            • 30
                                            • 31
                                            • 3 / 31
