Having an issue when installing dependancies
6 Posts 2 Posters 3.4k Views 2 Watching
  • Z Offline
    Zethcore
    Hello there,
    I’m in the process of trying to get my pi setup with the magic mirror2 and this is an error that I got:
    0_1507586637012_mmFail.png image url)
    I have the npm-debug.log file as well but its got way too much content to try and upload in a forum post.
    Please let me know if anyone can help me getting this set up correctly!
    Thanks!
    M 1 Reply Last reply Oct 10, 2017, 3:17 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @Zethcore
      @Zethcore said in Having an issue when installing dependancies:
      Is that from an automatic installation? You could try deleting the node_modules folder from inside the MagicMirror folder. Then in your terminal, cd MagicMirror, then npm install in the MagicMirror directory.
      If that doesn’t work, a manual install should. Delete or rename the MagicMirror folder. Download the MM zip file from github. Place the folder from the zip file where your current MM folder is/was. Rename the new folder to MagicMirror. Then in your terminal, cd MagicMirror, then npm install in the MagicMirror directory. You may see 3 or so warnings but they can be ignored.
      If that doesn’t do it then something else is amiss.
      Good luck sir
      Z 1 Reply Last reply Oct 11, 2017, 2:14 AM Reply Quote 1
      • Z Offline
        Zethcore @Mykle1
        @Mykle1 Yes it is from the automatic installation, thanks for the advice, Ill try this tonight!
        M 1 Reply Last reply Oct 11, 2017, 2:19 AM Reply Quote 0
          Ok, good luck. I’m pretty sure one or the other will get you up and running, unless something else is going on there.
          Z 1 Reply Last reply Oct 11, 2017, 3:16 AM Reply Quote 0
          • Z Offline
            Zethcore @Mykle1
            @Mykle1 No such luck, Tried both options but still am getting an issue! Whenever I try to run npm install it gets about 2/3 of the way then throws the same error with the dependencies. Prior to trying to install the magic mirror I updated all of the firmware on my pi, could that cause an issue?
            M 1 Reply Last reply Oct 11, 2017, 11:28 AM Reply Quote 0
              It could. I had a Pi lose its Bluetooth and Wifi after a firmware upgrade, but MM still installed. I can’t say that is your issue but something out of the ordinary is certainly going on there.
              At the very least, the manual install I suggested SHOULD have worked. I’ve done it many, many times, on Pi’s, PC’s running Windows, PC’s running uBuntu, and most recently (last week), a 32bit MacBook running uBuntu, all without fail.
              Perhaps someone else with more knowledge than I will chime in here. I’ve never even seen the “Optional SKIPPING OPTIONAL DEPENDENCY” message before
