    602 Posts 67 Posters 2.4m Views 68 Watching
      shbatm Module Developer
      Version 1.2.1 (Updated 15 Oct 2017) Now Available on ‘master’ branch
      • Now uses hardware-accelerated OMXPlayer as default player for local video
      • Resolved latency issues
      • Uses PM2 to control stream playback – automatically restarts streams when they close
      • Fullscreen, custom window and offset options now available.
      • Important - please update your configurations after updating this module. as some settings have changed. This new version includes a new configuration tool for building your configuration section.
      Fresh Install:
      See the installation instructions on the README.
      To switch back from the ‘wip’ branch:
      (Only necessary if you want to, the ‘wip’ and ‘master’ are the same currently, but I will update the ‘wip’ with new features and bug-fixes first for testing. If you want to beta test, stay on ‘wip’)
      cd ~/MagicMirror/modules/MMM-RSTPStream
      git checkout master
      git pull
      npm install
      http-server -p 9999
      # From a web browser, navigate to http://mirror-ip:9999/config.html
      # Once your config is made, press Ctrl+C to exit the config builder
      # Restart your mirror and test!
      J NiggichN 2 Replies Last reply
        Johans @shbatm
        @shbatm
        Nice work man.
        One small question: white box is not in line with the video window.
        I added this line in the config
        //      autoStart: true,
        	rotateStreams: false,   //changed true to false
                rotateStreamTimeout: 10,    // seconds
        	moduleWidth: 354,
        	moduleHeight: 240,
        moduleOffset: { top: 20, left: -20 },
                localPlayer: 'omxplayer',
                remotePlayer: 'none',
                showSnapWhenPaused: true,
                remoteSnaps: true,
        but this doesn’t change anything, position of video window isn’t moved.
        how can I change the position?
          @Johans I just tried this on my mirror and was able to get the video feed to move without a problem. Did you try restarting the mirror & video feed after you made the change? You can also try making larger changes to make sure it’s actually moving : moduleOffset: { left -200, top: 200} or try just moduleOffset: 50 to make sure it works.
          An alternative is to watch the console log for the parameters used:
          Starting stream stream1 with args: [
              "--avdict",
              "rtsp_transport:tcp",
              "--win",
              "731, 439, 1259, 799",  # --- this is the position it tries to draw the video
          And then add the following inside the stream1: { section to specify the exact position you want the video to show using the numbers from the log and your desired offset:
          absPosition: { top: XX, right: XX, bottom: XX, left: XX },
          J 1 Reply Last reply
            barnosch
            i updated the module from work, but did not start the server thing to get the server config page.
            Later at home i could not start the server anymore to reach the config page.
            Is that mandatory?
            The stream runs good, without any changes in the config. Hopefully it does not crash so often anymore.
            I saw that it launches now another pm2 session just for the stream. thats nice.
            So i can restart both sessions (stream and mirror) with a script and do not need to reboot the whole pi anymore, when i change something.
              Johans @shbatm
              @shbatm
              Made some larger changes and saw the video moves. Now it’s perfect within the box.
              I’ve noticed that when video is out of the box window, the omxplayer is not stopped or killed. Video still remains visible even MM has stopped.
              At moment the video was perfect within the box, it also kills perfect the video stream.
              Just wanted to let you know this.
              thanks for the support.
              J.
              • NiggichN
                Niggich @shbatm
                @shbatm At first, thx for your great work. I finally tried to update the module but after npm installI get an Error message like this.
                > MMM-RTSPStream@1.2.1 postinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
                > ./install_sd_patch.sh && sudo npm i -g http-server
                Applying Graceful Shutdown patch to MagicMirror.
                error: Anwendung des Patches fehlgeschlagen: js/electron.js:96
                error: js/electron.js: Patch konnte nicht angewendet werden
                npm ERR! Linux 4.9.48-v7+
                npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                npm ERR! node v4.3.2
                npm ERR! npm  v2.14.12
                npm ERR! code ELIFECYCLE
                npm ERR! MMM-RTSPStream@1.2.1 postinstall: `./install_sd_patch.sh && sudo npm i -g http-server`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the MMM-RTSPStream@1.2.1 postinstall script './install_sd_patch.sh && sudo npm i -g http-server'.
                npm ERR! This is most likely a problem with the MMM-RTSPStream package,
                npm ERR! not with npm itself.
                npm ERR!     ./install_sd_patch.sh && sudo npm i -g http-server
                npm ERR! You can get their info via:
                npm ERR!     npm owner ls MMM-RTSPStream
                npm ERR!     /home/pi/MagicMirror/modules/MMM-RTSPStream/npm-debug.log
                I tried to update and a Fresh install but at both ways I get the same Error.
                  shbatm Module Developer @Niggich
                  @Niggich It appears it is installing correctly and the post-install is not working, please try to run the following commands and see which one fails:
                  # Change directory
                  cd ~/MagicMirror/modules/MMM-RTSPStream
                  # Install the "Graceful Shutdown" patch on MM core (Issue #1056)
                  # Install the Node.js http-server module
                  NiggichN 1 Reply Last reply
                    shbatm Module Developer @Johans
                    @Johans said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                    This sounds like there is still a glitch in the starting of the stream. I will investigate on my end too. Are you using any other modules that hide or show this one? Scheduler, Carousel, or ProfileSwitcher?
                      shbatm Module Developer @barnosch
                      @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      The config page is not mandatory, it just helps create a valid config file and helps you eliminate settings you don’t need to mess with. If you had a working version before on the wip branch, nothing significant has changed. If you used ffmpeg or the main branch before, you must update the port setting to ffmpegPort.
                      You should also still be able to get to the config page after install:
                      # Make sure http-server is installed:
                      # Start the server:
                      http-server -p 9999
                      # Navigate in browser to:
                      http://magic-mirror-ip:9999/config.html
                      • NiggichN
                        Niggich @shbatm
                        @shbatm The installation of the “Graceful Shutdown” fails.
                          @Niggich said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                          OK. It’s not required to get the streams to work, but is required to shutdown the streams if you exit/stop MM. This will be included automatically in the next MagicMirror release.
                          If you’re comfortable making the changes manually, you can find them here f646360 – otherwise don’t worry about it for now, you’ll just have to stop the streams by hand if you exit MM (they will restart automatically if you restart MM).
                            Johans @shbatm
                            @shbatm for the moment i didn’t use any scheduler, carousel or profileswitcher.
                              A Former User
                              Hi everyone, do you know how I would do this? I have a 8 channel Annke DVR analogue cameras not IP, I can view them via a web browser but a plugin is needed to be installed before I can view them.
                                shbatm Module Developer @Guest
                                @PCPAYN3 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                You just need to find out if you can access an RTSP stream for the cameras through the DVR. Not sure which exact model you have but:
                                First, check here: https://www.ispyconnect.com/man.aspx?n=Annke
                                Second, I found this after a Quick google search:
                                According to this thread here, you can access an RTSP stream for each of the cameras using the following:
                                rtsp://[username]:[password]@[ip]:[port]/[codec]/[channel]/[subtype]/av_stream
                                username such as admin
                                password such as 12345
                                ip: device IP, such as 192.0.0.64
                                port: 554
                                codec: h264, MPEG-4 or mpeg4
                                channel: channel number, such as channel one is ch1
                                subtype: type of steam. main stream is main and substeam is sub
                                For example:
                                main stream of channel 1
                                rtsp://admin:12345@192.0.0.64:554/h264/ch1/main/av_stream
                                substream of channel 1
                                rtsp://admin:12345@192.0.0.64:554/h264/ch1/sub/av_stream
                                  barnosch
                                  Since i updated to the actual RTSPStream version i have a new issue.
                                  The whole mirror crashes for some reason (black screen) and only the stream is still showing.
                                  This is not on a regular basis, after some hours it happens.
                                  Rebooting and everything is fine again.
                                  I have not updated yet to the new MM version (because of all the issue threads in the forum)
                                  Any idea?
                                  S cowboysdudeC 2 Replies Last reply
                                    Is there anything that shows up in the server or console log? Can you run the mirror using npm start dev to monitor the electron console for logs and let me know what the error is?
                                    I had already upgraded my mirror to the new version, there may be a dependency or change that is effecting it that I missed.
                                      richfreeman
                                      Sorry to hijack this thread.
                                      Are there any log’s created to investigate why a video feed will not display in the MM.
                                      omxplayer will stream the feed fine from the command line, using
                                      sudo omxplayer -o hdmi rtsp://0.0.0.0:554/onvif1
                                      Any advice gratefully received…
                                      Thanks.
                                        richfreeman
                                        udp protocol needed for my doorbell rtsp feed!
                                        Just needed to add the protocol: “udp”,
                                        instead of typical tcp.
                                        Feed appeared after a few seconds!
                                        At last!
                                        • V
                                          Vauxdvihl
                                          thanks for this great module.
                                          One question.
                                          I am using a bird cam with another rpi
                                          This “live stream” directly coming from the birds housing is available under the IP
                                          “http://xxx.xxx.xxx.xxx”
                                          Unfortunately i am was not able so far, to “show” this live stream on my magic mirror.
                                          The link that i used in the config file for this module was:
                                          “rstp://http://…”
                                          “http://…”
                                          “rstp://…”
                                          The Bird Cam uses “RPI CAM Control V6.2.31”
                                          Can anybody help?
                                          Thanks a lot
                                            shbatm Module Developer @Vauxdvihl
                                            @Vauxdvihl – when you open the stream in your browser, do you need any special plugins to view it?
                                            Without digging too deep, it looks like this is a MJPEG stream, which can be viewed without any special software in the browser. For these kind of streams it’s easiest to just use the MMM-iframe module to show the stream.
                                            If you don’t want to show the controls the page generates, you can find the link directly to the camera image by viewing the source of the camera stream page.
                                            V 1 Reply Last reply
                                            • 30
                                            • 31
                                            • 4 / 31
