    Module Developer Challenge - I surrender!
    Scheduled Pinned Locked Moved Solved Development
    33 Posts 6 Posters 19.9k Views 5 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Guest
      @Sean actually the problem starts even before the cache. the way magicmirror is designed in the update module function is, that it will only rerender if there was something changed in the dom. But your solution should still fix the problem.
      Another similar way would be to put a “seed” to the dom element itself insetad of the url, as i suggested in the iframe reload module, which fixed the reload problem there.
      after line 147
      img.setAttribute("timestamp", new Date().getTime());
      which will create an dom element like:
      < img class="photo" timestamp="1508693514656" src="http://api.usno.navy.mil/imagery/earth.png?date=today" />
        @Sean
        @strawberry 3.141
        Oh hey, thanks to you both. I just got in from my daughter’s. I was playing with my grandchildren. I will give those a try right now. You guys are awesome!
        I’ll post back with my results.
          Mykle1 Project Sponsor Module Developer @Guest
          @Sean said in Module Developer Challenge - I surrender!:
          http://api.usno.navy.mil/imagery/earth.png?date=today&seed=[SomeRandomValue]
          Hi Sean,
          I tried your suggestion first as yours was the first suggestion.
          I added a var for random number between 1 and 99
          var randomNumber = Math.floor(Math.random() * 99);
          And inserted that into the url
          img.src = "http://api.usno.navy.mil/imagery/earth.png?date=today&seed=" + randomNumber;
          Console log reporting that the random number is being generated
          http://api.usno.navy.mil/imagery/earth.png?date=today&seed=16
          MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=5
          MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=75
          MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=31
          MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=12
          MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=16
          Many thanks to you, Sean. The module IS updating now!
          Now, on to try @strawberry’s suggestion!
          EDIT
          I set the above to run on my MacBuntu laptop running MM so I could monitor it. It was updating nicely for a while but then something odd happened. An update resulted in an earlier image being loaded. I think this is because random numbers between 1 - 99 will at some point choose the same number.
          I’ll continue to work on it. I have an idea!
            A Former User @Mykle1
            @Mykle1 I think 99 is somehow too small. Use bigger values or timestamp for preventing duplicated.
              Yes, see the edit to my post. I was writing that as you posted.
              I’ll report back
                Mykle1 Project Sponsor Module Developer @strawberry 3.141
                @strawberry-3.141
                So, after having tried Sean’s suggestion I realized my mistake in using a random number instead of timestamp. As I was about to try your suggestion I realized that I could use a part of Sean’s suggestion and a part of your suggestion.
                I had already set up a var for random numbers, so I changed that to var getTimeStamp = new Date().getTime(); which was your idea added to Sean’s idea of a random value. A quick check in the console showed me it was working.
                http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717386975
                MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717686862
                MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717686866
                MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717987939
                MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717987944
                MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508718287819
                MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508718287823
                Then a simple edit to the url which was kinda, sorta, like the ideas you both had.
                img.src = "http://api.usno.navy.mil/imagery/earth.png?date=today&seed=" + getTimeStamp;
                And BOOM! Success! I’ll leave it running all night and check it in the morning but I don’t foresee any problems
                So, thank you Strawberry and thank you Sean. You guys are truly amazing!!!
                Commence embarrassment recovery
                  So far, so good. I have it running on my MacBuntu laptop. Here is a 2 frame animation so you get the idea. Obviously, there are quite a few updates absent from the gif and the shadow will move much more slowly and not jump across the planet. hehe
                    I am happy to report that the module ran for the last 11 hours without a hitch. The visual image shows day and night exactly where it should.
                      I find myself in a similar situation, again. :-)
                      This is my cry for help. I only do this when I’ve tried all the things I know
                      and googled the things I don’t know. I’ve even tried free form improvising but coding
                      seems to reject that sort of thing, at least in my case.
                      About 2 weeks ago I wrote a module that gets system stats from a PC board running
                      ubuntu and MM. There is just one more thing that I want to include. I want to get the system
                      temperature (CPU?) and/or the temps of any other system components.
                      So, it is with the utmost humility that I ask for your help, suggestions or directions. I won’t
                      object to any modifications that anyone cares to make, if that is the case. If it can’t be done,
                      I can live with that, too. Even if you look at the module and never make any comments regarding
                      my request, I still thank you for your time and interest.
                      https://github.com/mykle1/MMM-PC-Stats
                      Peace
                      • N Offline
                        ninjabreadman @Mykle1
                        @Mykle1 It doesn’t seem that pc-stats has all the info you require. You might consider switching to the systeminformation package.
                        You can then use si.cpu() for your CPU stats and si.cpuTemperature() to retrieve an object that (if I read the docs right) looks like { main: 0, max: 0, cores: [0, 0] } with your core temps. You can then combine the two responses (or you may be able to have it return all within one request) and return those in a single sendNotification() call.
                        • 1 / 4
