MMM-Fuel
@FreddeHamm any errors?
noob-question: how can i see the log?
@FreddeHamm in the terminal where you start the mirror or pm2 logs, and in the electron console(start the mirror with npm start dev)
i found this
** Message: console message: http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js @117: SyntaxError: Unexpected token ‘(’. Expected a ‘:’ following the property name 'getTranslati$
if i use npm start dev i get this…
1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
2 info using npm@5.5.1
3 info using node@v8.3.0
4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
6 verbose cwd /home/pi
7 verbose Linux 4.9.35+
8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
9 verbose node v8.3.0
10 verbose npm v5.5.1
11 error path /home/pi/package.json
12 error code ENOENT
13 error errno -2
14 error syscall open
15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
16 error enoent This is related to npm not being able to find a file.
17 verbose exit [ -2, true ]I did try to set up another mm … Same problem. only the fuel module doesnt show up. But if i use the browser on my pc it shows up…
@FreddeHamm
Looks like you are not in the MagicMirror folder when runningnpm start dev
Please trycd ~/MagicMirror npm start dev
@FreddeHamm sounds like you are using midori browser or something similar which doesnt support es6 syntax
Hi
great module!
I wanted to use my own header for your module to get the same look as the other moduled.Unfortunately I don‘t understand how to disable the view of your implemented header.
At the moment I have two headers :)
Thanks.
Best regards
@rrrene custom.css
.MMM-Fuel header.align-left { display: none; }
Hi guys I’m from South Africa, I have just started playing with the magic mirror today I have managed to the calendar weather and news for South Africa I would really like to add fuel prices and email notifications to it but don’t know how and can find any videos showing how to do it just that they did it if that makes sence
