    Location ID is not displaying the correct weather in the weather module. Why?
    2 Posts 2 Posters 1.3k Views 2 Watching
      croberts3250
      What am I supposed to do? I live in Gainesville, FL. There are numerous location IDs for this area (for some reason). The weather the module is displaying is a couple of degrees off. Why is it not correct? What do I do?
        Mykle1 Project Sponsor Module Developer @croberts3250
        @croberts3250 said in Location ID is not displaying the correct weather in the weather module. Why?:
        It likely means that there are numerous weather stations in that area and you can choose which one is the most accurate for you. The module itself can only display the data coming from the API. The module doesn’t verify that data, it merely reports it.
        What can you do? Choose another station ID that is more accurate for you. Try another weather module, there are several.
