    MMM-RandomQuranAyah
    Scheduled Pinned Locked Moved Education
    34 Posts 7 Posters 27.0k Views 7 Watching
    • slametpsS
      slametps @slametps
      @MichMich If you may, can add this module to the 3rd party MM-modules list. Thx in advance.
      regards,
      Slamet PS
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @slametps
        @slametps you can add that yourself https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules/_edit
        slametpsS 1 Reply Last reply
        • slametpsS
          slametps @strawberry 3.141
          @strawberry-3.141 Thx. Done.
          regards,
          Slamet PS
          • Z
            zam
            Jazakallah , if you can please try to implement a Module for ADAN it will be very usefull :)
            slametpsS 2 Replies Last reply
            • slametpsS
              slametps @zam
              @zam I’m still working on a new module MMM-PrayerTime including playing Adzan. Hope it will release in this weekend.
              regards,
              Slamet PS
              • slametpsS
                slametps @zam
                @zam said in MMM-RandomQuranAyah:
                @zam It is available now, MMM-PrayerTime for displaying praying time with adhan recital.
                regards,
                Slamet PS
                Z G 2 Replies Last reply
                • Z
                  zam @slametps
                  @slametps Wonderfull Let me try first , Sukran Jaseelan :)
                  • slametpsS
                    slametps @zam
                    @zam you’re welcome.
                    regards,
                    Slamet PS
                    Z 1 Reply Last reply
                    • Z
                      zzaidi148 @slametps
                      @slametps I tried setting up this module put it doesnt allow my magic mirror to work. I downloaded the module, put the config in my config.js and got a failed config. I put it in jshint and found nothing. Below is my config. Please help. Thank You.
                      		module: 'MMM-RandomQuranAyah',
                      		position: 'top_bar',
                      			apiVersion: '1.0' /
                      			showArabic: true,
                      			showTranslation: true,
                      			surahArabicName:false,
                      			translationLang:'id.indonesian',
                      			updateInterval: 3600 * 1000,
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar",
                      			module: "clock",
                      • slametpsS
                        slametps @zzaidi148
                        @zzaidi148 said in MMM-RandomQuranAyah:
                        			apiVersion: '1.0' /
                        			showArabic: true,
                        			module: "alert",
                        			module: "clock",
                        You should remove update_notification module (or change the location) because it override the same location.
                        regards,
                        Slamet PS
                        • Z
                          zzaidi148 @slametps
                          @slametps Tried that but still didn’t load up magic mirror
                          • slametpsS
                            slametps @zzaidi148
                            Can you post the pm2 or MM log?
                            regards,
                            Slamet PS
                            • Z
                              zzaidi148 @slametps
                              @slametps I’m a noob at this but this is the log on my terminal:
                              > magicmirror@2.1.3 start /home/pi/MagicMirror
                              > sh run-start.sh
                              Starting MagicMirror: v2.1.3
                              Loading config ...
                              WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                              Loading module helpers ...
                              No helper found for module: helloworld.
                              All module helpers loaded.
                              Server started ...
                              Launching application.
                              • slametpsS
                                slametps @zzaidi148
                                > sh run-start.sh
                                Loading config ...
                                Server started ...
                                What you got on the screen? Pls post the screen capture here.
                                regards,
                                Slamet PS
                                • Z
                                  zzaidi148 @slametps
                                  @slametps it just said to recheck your config
                                  • slametpsS
                                    slametps @zzaidi148
                                    Can you post your whole config? It seems your config is the problem.
                                    regards,
                                    Slamet PS
                                    • slametpsS
                                      slametps @slametps
                                      @slametps said in MMM-RandomQuranAyah:
                                      There is character / after config ApiVersion. Pls remove it.
                                      regards,
                                      Slamet PS
                                      • Z
                                        zzaidi148 @slametps
                                        @slametps I took the character off but still something wrong
                                        /* Magic Mirror Config Sample
                                         * MIT Licensed.
                                        var config = {
                                        	port: 8080,
                                        	language: "en",
                                        	timeFormat: 12,
                                        	units: "imperial",
                                        			apiVersion: '1.0'
                                        			showArabic: true,
                                        			module: "alert",
                                        			module: "clock",
                                        			header: "US Holidays",
                                        					symbol: "calendar-check-o",
                                        					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                        			module: "compliments",
                                        			position: "lower_third",
                                        			module: "currentweather",
                                        				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        				appid: "private",
                                        			module: "weatherforecast",
                                        			header: "Weather Forecast",
                                        				appid: "",
                                        			module: "newsfeed",
                                        			position: "bottom_bar",
                                        				feeds: [
                                        						title: "New York Times",
                                        						title: "ESPN",
                                        						url: "http://www.espnfc.com/english-premier-league/23/rss"
                                        				showSourceTitle: true,
                                        				showPublishDate: true
                                                    	        module: 'MMM-GoogleMapsTraffic',
                                        			position: 'top_left',
                                                        	   key: '',
                                                        	   lat: 33.033184,
                                                        	   lng: -96.625225,
                                                        	   height: '350px',
                                                        	   width: '400px',
                                        • slametpsS
                                          slametps @zzaidi148
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: "en",
                                          	timeFormat: 12,
                                          	units: "imperial",
                                          			apiVersion: '1.0'
                                          			showArabic: true,
                                          			module: "alert",
                                          			module: "clock",
                                          				appid: "private",
                                          				appid: "",
                                          			module: "newsfeed",
                                          				feeds: [
                                          						title: "ESPN",
                                                          	   key: '',
                                                          	   lat: 33.033184,
                                                          	   lng: -96.625225,
                                                          	   height: '350px',
                                                          	   width: '400px',
                                          There is missing character comma (,) after apiVersion: '1.0'.
                                          regards,
                                          Slamet PS
                                          • Z
                                            zzaidi148 @slametps
                                            @slametps Alhumdulillah, actually worked! Is there any way to change the translation beside en.yusufali in english. Also, my arabic font is different from your screenshot. How do I get your arabic font? Thank you so much!
