    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.4k Views 28 Watching
    • A
      Albert2002
      Maybe you can get it tomorrow? Would be great to figure out.
      Something crossed my mind. When I set up the Developer mode in the Gateway there is a password too. I know that I need this one for OpenHAB. Maybe I need it for this module as well?
      M 1 Reply Last reply
        mirko3000 @Albert2002
        So I just read through the documentation of miio and found this:
        https://github.com/aholstenson/miio/blob/master/docs/management.md#getting-the-token-of-a-device
        or:
        https://github.com/aholstenson/miio/blob/master/docs/management.md#setting-the-token-of-a-device
        My device seems to provide the token “via auto-token”, in your case it seems it does not. Maybe try either of the above.
        IDs are same with me, maybe my documentation is wrong here.
          mirko3000
          When I run the discover tool I get the following:
          Device ID: 56804143
          Model info: Unknown
          Address: 192.168.0.9 (xiaomi-gateway.fritz.box)
          Token: cfbdb315c0825ccc971918e36923febe via auto-token
          Support: Unknown
          Device ID: 158d0001635bb3
          Model info: lumi.sensor_ht (sensor)
          Address: Owned by 56804143
          Token: Automatic via parent device
          Support: At least basic
          • A
            Albert2002
            I am a step ahead!
            I followed the instructions to get the token “Getting the token when using the Mi Home app”
            This was working. I could see all the connected devices to the Gateway.
            pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover --sync
             INFO  Discovering devices. Press Ctrl+C to stop.
            Device ID: 52238776
            Model info: Unknown
            Address: 192.168.13.1
            Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via auto-token
            Support: Unknown
            Device ID: 158d000119fcb2
            Model info: lumi.magnet (magnet)
            Address: Owned by 52238776
            Device ID: 158d00013e28ee
            Model info: lumi.plug (power-plug)
            Device ID: 158d00015aa973
            Model info: lumi.switch (controller)
            Device ID: 158d00015736a8
            At this point I had to switch over to the Pi with the installed MagicMirror:
            pi@MagicMirror:~ $ miio --discover
            Device ID: 52238776
            Model info: Unknown
            Address: 192.168.2.107
            Token: ???
            Support: Unknown
            I’ve updated the Token as described:
            pi@MagicMirror:~ $ miio --update 52238776 --token 6eea5ac1eb475bfedbfff98aab7c2bc7
             INFO  Attempting to update 52238776
             INFO  Device updated
            I’ve searched for devices again. Now with success!
            Device ID: 52238776
            Model info: Unknown
            Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token
            Support: Unknown
            The problem so far is, that I still don’t get any informations visible in MM. I’ve tried ‘158d00015736a8’ and as well ‘52238776’ as id.
            The second problem is, that I’ve lost the Gateway in my Mi Home app after updating the Token!
            The question is, how to copy ( Store?) over the Token to a different Machine?
            mm error:
            error: Token could not be auto-discovered
                at Device._tokenResolve (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:141:13)
                at Device._onMessage (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:80:9)
                at emitTwo (events.js:106:13)
                at Socket.emit (events.js:194:7)
                at UDP.onMessage [as onmessage] (dgram.js:545:8)
              mirko3000
              Ok at least some progress. So first to enable your manual token just update the configuration:
              	 interval: 30,
              	 gatewayIP: '192.168.13.1',
              	 gatewayToken: '6eea5ac1eb475bfedbfff98aab7c2bc7',
              	 devices : [{
              You only need the IDs from your sensors, not the gateway.
              About the Mi Home App and your lost token, I would try once this works to reconfigure your gateway with the Mi Home app, and then try to fetch the auto-token again (in your first sample it seems to provide auto-token).
              • A
                Albert2002
                I did the steps again to get the (new) Token. Now, I have a new Token and the Gateway again in my Mi Home app. I didn’t updated the Token on the different machine this time.
                I’ve tried out your new config. I still don’t see more than before on the MM, but I don’t have an error log as well, which make it a bit more harder.
                I have checked the IP address of the Gateway, its still the same. Dev is still enabled.
                My config with the new Token.
                		module: 'MMM-xiaomi',
                		position: 'bottom_left',
                		header: 'Temperatur / Feuchtigkeit',  // This is optional
                			interval: 30,
                			gatewayIP: '192.168.2.107',
                			gatewayToken: '050591e66a82f7adc92bfa6b03058cdb',
                			devices: [{ id: '158d00015736a8', name: 'Wohnzimmer' }]
                Edit:
                I get a error when I try to discover with miio:
                pi@MagicMirror:~/MagicMirror/modules/MMM-xiaomi/node_modules/miio $ miio --discover
                Device ID: 52238776
                Model info: Unknown
                Support: Unknown
                (node:3626) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
                • A
                  Albert2002
                  Where did miio stored the Token?
                  The Token Miio used “Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token”
                  is the old one! the new one is 050591e66a82f7adc92bfa6b03058cdb
                    mirko3000
                    Hmm not sure about miio details, I just know that you can sync the tokens via
                    Else I would try manually setting to the correct (new) token.
                    For the MM: try to uncomment line 51 in node_helper.js, this logs all found devices. You could also add some more logs here to see where the program fails.
                    • A
                      Albert2002
                      Hi Mirko! Thanks for your reply!
                      Before and after I uncommented the line 51 and restartet MM.
                      Still with the old Token
                      pi@MagicMirror:~ $ miio --discover --sync
                      Device ID: 52238776
                      Model info: Unknown
                      Support: Unknown
                      (node:25652) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
                      But right now after uncommenting the line the error log is different. In the log i can already see the Temperature and humidity (_properties: { temperature: 19.51, humidity: 62.44 },)!! The next step!
                      > magicmirror@2.1.3 start /home/pi/MagicMirror
                      > sh run-start.sh
                      Starting MagicMirror: v2.1.3
                      Loading config ...
                      Loading module helpers ...
                      Module helper loaded: MMM-DWD-WarnWeather
                      Module helper loaded: MMM-PNews
                      Module helper loaded: MMM-Remote-Control
                      No helper found for module: MMM-Remote-Control-Repository.
                      Module helper loaded: internet-monitor
                      Module helper loaded: MMM-MovieListings
                      Module helper loaded: MMM-Fuel
                      Module helper loaded: MMM-NetworkScanner
                      Module helper loaded: MMM-nasaastropic
                      Module helper loaded: MMM-SystemStats
                      Module helper loaded: MMM-Departures
                      No helper found for module: MMM-Carousel.
                      Module helper loaded: MMM-Events
                      Module helper loaded: MMM-xiaomi
                      All module helpers loaded.
                      You're using a full whitelist configuration to allow for all IPs
                      Server started ...
                      Connecting socket for: MMM-DWD-WarnWeather
                      MMM-DWD-WarnWeather helper started...
                      Connecting socket for: MMM-PNews
                      Starting module: MMM-PNews
                      Starting module: newsfeed
                      Connecting socket for: MMM-Remote-Control
                      Starting node helper for: MMM-Remote-Control
                      Connecting socket for: internet-monitor
                      internet-monitor helper started ...
                      Connecting socket for: MMM-MovieListings
                      MMM-MovieListing helper started...
                      Connecting socket for: MMM-Fuel
                      Starting module helper: MMM-Fuel
                      Connecting socket for: MMM-NetworkScanner
                      Starting module: MMM-NetworkScanner
                      Connecting socket for: MMM-nasaastropic
                      Starting node helper: MMM-nasaastropic
                      Connecting socket for: MMM-SystemStats
                      Connecting socket for: MMM-Departures
                      Connecting socket for: MMM-Events
                      Starting node_helper for: MMM-Events
                      Connecting socket for: MMM-xiaomi
                      Starting xiaomi helper
                      Launching application.
                      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/htc.one.m2304%40gmail.com/private-;-)/basic.ics - Interval: 300000
                      Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
                      Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
                      starting internet monitor node helper
                      MMM-NetworkScanner received CONFIG
                      astro helper: config received
                      retrieveAndUpdate()
                      Triggering Xiaomi Gateway upate
                      MMM-Departures error: Error: getaddrinfo ENOTFOUND transportrest-sbiermann.rhcloud.com transportrest-sbiermann.rhcloud.com:80
                      NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/m5_hubblesmessier1024c.jpg
                      Magnet {
                        domain: null,
                        _events: {},
                        _eventsCount: 0,
                        _maxListeners: undefined,
                        model: 'lumi.magnet',
                        type: 'magnet',
                        capabilities: [],
                        _properties: {},
                        _propertiesToMonitor: [],
                        _propertyDefinitions: {},
                        _parent:
                         Gateway {
                           domain: null,
                           _events: {},
                           _eventsCount: 0,
                           type: 'gateway',
                           model: 'lumi.gateway.v3',
                           capabilities: [ 'color:rgb', 'brightness', 'sensor', 'illuminance' ],
                           address: '192.168.2.107',
                           port: 54321,
                           writeOnly: false,
                           packet:
                            Packet {
                              header: ,
                              _serverStampTime: 1509842296639,
                              _token: ,
                              _tokenKey: ,
                              _tokenIV: ,
                              data: ,
                              _serverStamp: 48587 },
                           socket:
                            Socket {
                              domain: null,
                              _events: [Object],
                              _eventsCount: 1,
                              _handle: [Object],
                              _receiving: true,
                              _bindState: 2,
                              type: 'udp4',
                              fd: -42,
                              _reuseAddr: undefined,
                              _queue: undefined },
                           _id: 4,
                           _promises: {},
                           _hasFailedToken: false,
                           _properties: { illuminance: 307, rgb: [Object], brightness: 0 },
                           _propertiesToMonitor: [ 'illumination', 'rgb' ],
                           _propertyDefinitions: { illumination: [Object], rgb: [Object] },
                           _reversePropertyDefinitions: { illuminance: 'illumination' },
                           _loadProperties: [Function: bound _loadProperties],
                           management: DeviceManagement { device: [Circular] },
                           debug:
                            { [Function: debug]
                              namespace: 'miio.device.[192.168.2.107]',
                              enabled: false,
                              useColors: false,
                              color: 1,
                              inspectOpts: {} },
                           _devices:
                            { '158d000119fcb2': [Object],
                              '158d00013e28ee': [Object],
                              '158d00015aa973': [Object],
                              '158d00015736a8': [Object] },
                           _monitorInterval: 60000,
                           _propertyMonitor:
                            Timeout {
                              _called: false,
                              _idleTimeout: 60000,
                              _idlePrev: [Object],
                              _idleNext: [Object],
                              _idleStart: 69767,
                              _onTimeout: [Function: bound _loadProperties],
                              _timerArgs: undefined,
                              _repeat: 60000 },
                           _lastToken: 1509842294044,
                           _developerKey: 'xqbs1fvtsq6x4oby',
                           devApi:
                            DeveloperApi {
                              domain: null,
                              _events: [Object],
                              _eventsCount: 2,
                              debug: [Object],
                              socket: [Object],
                              devices: [],
                              ready: false },
                           setRGB: [Function],
                           setBrightness: [Function],
                           _deviceListTimer:
                            Timeout {
                              _called: false,
                              _idleTimeout: 1800000,
                              _idleStart: 72417,
                              _onTimeout: [Function: bound _updateDeviceList],
                              _repeat: 1800000 } },
                        management: SubDeviceManagement { _device: [Circular] },
                        debug:
                         { [Function: debug]
                           namespace: 'miio.device.[192.168.2.107].158d000119fcb2',
                           enabled: false,
                           useColors: false,
                           color: 1,
                           inspectOpts: {} } }
                      Switch {
                        domain: null,
                        _events: {},
                        _eventsCount: 0,
                        model: 'lumi.switch',
                        type: 'controller',
                        capabilities: [],
                        _properties: {},
                        _parent:
                         Gateway {
                           domain: null,
                           _events: {},
                           _eventsCount: 0,
                           type: 'gateway',
                           port: 54321,
                           writeOnly: false,
                           packet:
                            Packet {
                              header: ,
                              _token: ,
                              _tokenKey: ,
                              _tokenIV: ,
                              data: ,
                           socket:
                            Socket {
                              domain: null,
                              _events: [Object],
                              _eventsCount: 1,
                              _handle: [Object],
                              _receiving: true,
                              _bindState: 2,
                              type: 'udp4',
                              fd: -42,
                           _id: 4,
                           _promises: {},
                           debug:
                            { [Function: debug]
                              enabled: false,
                              useColors: false,
                              color: 1,
                              inspectOpts: {} },
                           _devices:
                           _propertyMonitor:
                            Timeout {
                              _called: false,
                              _idleStart: 69767,
                              _repeat: 60000 },
                           devApi:
                            DeveloperApi {
                              domain: null,
                              _events: [Object],
                              _eventsCount: 2,
                              debug: [Object],
                              socket: [Object],
                              devices: [],
                              ready: false },
                           setRGB: [Function],
                           _deviceListTimer:
                            Timeout {
                              _called: false,
                              _idleStart: 72417,
                        debug:
                         { [Function: debug]
                           namespace: 'miio.device.[192.168.2.107].158d00015aa973',
                           enabled: false,
                           useColors: false,
                           color: 3,
                           inspectOpts: {} } }
                      SensorHT {
                        domain: null,
                        _events: {},
                        _eventsCount: 0,
                        model: 'lumi.sensor_ht',
                        type: 'sensor',
                        capabilities: [ 'sensor', 'temperature', 'humidity' ],
                        _propertiesToMonitor: [ 'temperature', 'humidity' ],
                         { temperature: { mapper: [Function] },
                           humidity: { mapper: [Function] } },
                        _parent:
                         Gateway {
                           domain: null,
                           _events: {},
                           _eventsCount: 0,
                           type: 'gateway',
                           port: 54321,
                           writeOnly: false,
                           packet:
                            Packet {
                              header: ,
                              _token: ,
                              _tokenKey: ,
                              _tokenIV: ,
                              data: ,
                           socket:
                            Socket {
                              domain: null,
                              _events: [Object],
                              _eventsCount: 1,
                              _handle: [Object],
                              _receiving: true,
                              _bindState: 2,
                              type: 'udp4',
                              fd: -42,
                           _id: 4,
                           _promises: {},
                           debug:
                            { [Function: debug]
                              enabled: false,
                              useColors: false,
                              color: 1,
                              inspectOpts: {} },
                           _devices:
                           _propertyMonitor:
                            Timeout {
                              _called: false,
                              _idleStart: 69767,
                              _repeat: 60000 },
                           devApi:
                            DeveloperApi {
                              domain: null,
                              _events: [Object],
                              _eventsCount: 2,
                              debug: [Object],
                              socket: [Object],
                              devices: [],
                              ready: false },
                           setRGB: [Function],
                           _deviceListTimer:
                            Timeout {
                              _called: false,
                              _idleStart: 72417,
                        debug:
                         { [Function: debug]
                           namespace: 'miio.device.[192.168.2.107].158d00015736a8',
                           enabled: false,
                           useColors: false,
                           color: 6,
                           inspectOpts: {} } }
                      • A
                        Albert2002
                        One more. When I run the MM as standalone server (node serveronly) I get this in the Browser console:
                        MMM-xiaomi.js:28 received XIAOMI_DATA
                        MMM-xiaomi.js:212 Uncaught TypeError: Cannot read property 'id' of null
                            at Class. (MMM-xiaomi.js:212)
                            at Function.each (jquery-2.2.3.min.js:2)
                            at Class.renderText (MMM-xiaomi.js:210)
                            at Class.render (MMM-xiaomi.js:100)
                            at Class.socketNotificationReceived (MMM-xiaomi.js:29)
                            at module.js:183
                            at r. (socketclient.js:25)
                            at r.emit (index.js:133)
                            at r.onevent (socket.js:270)
                            at r.MMSocket.self.socket.onevent (socketclient.js:19)
                        (anonymous) @ MMM-xiaomi.js:212
                        each @ jquery-2.2.3.min.js:2
                        renderText @ MMM-xiaomi.js:210
                        render @ MMM-xiaomi.js:100
                        socketNotificationReceived @ MMM-xiaomi.js:29
                        (anonymous) @ module.js:183
                        (anonymous) @ socketclient.js:25
                        r.emit @ index.js:133
                        r.onevent @ socket.js:270
                        MMSocket.self.socket.onevent @ socketclient.js:19
                        r.onpacket @ socket.js:228
                        (anonymous) @ index.js:21
                        r.ondecoded @ manager.js:345
                        s.add @ index.js:241
                        r.ondata @ manager.js:335
                        r.onPacket @ socket.js:457
                        (anonymous) @ socket.js:274
                        r.onPacket @ transport.js:145
                        r.onData @ transport.js:137
                        ws.onmessage @ websocket.js:147
                          mirko3000
                          Try the latest update (git pull), I just checked for null items - even i that should not happen.
                          • A
                            Albert2002
                            I did so. Restarted MM.
                            No errors in the logs.
                            mm out:
                            Found device with ID 158d000119fcb2 of type magnet
                            Found device with ID 158d00015aa973 of type controller
                            Found device with ID 158d00015736a8 of type sensor
                            This I got from the Browser Debug:
                            main.js:404 Initializing MagicMirror.
                            translator.js:197 Loading core translation file: translations/de.json
                            translator.js:219 Loading core translation fallback file: translations/en.json
                            loader.js:182 Load script: modules/MMM-xiaomi//MMM-xiaomi.js
                            module.js:406 Check MagicMirror version for module 'MMM-xiaomi' - Minimum version:  2.0.0 - Current version: 2.1.3
                            module.js:408 Version is ok!
                            module.js:414 Module registered: MMM-xiaomi
                            loader.js:152 Bootstrapping module: MMM-xiaomi
                            loader.js:182 Load script: modules/MMM-xiaomi/String.format.js
                            String.format.js Failed to load resource: the server responded with a status of 404 (Not Found)
                            loader.js:190 Error on loading script: modules/MMM-xiaomi/String.format.js
                            script.onerror @ loader.js:190
                            loader.js:182 Load script: https://code.jquery.com/jquery-2.2.3.min.js
                            loader.js:157 Scripts loaded for: MMM-xiaomi
                            loader.js:197 Load stylesheet: modules/MMM-xiaomi/MMM-xiaomi.css
                            loader.js:159 Styles loaded for: MMM-xiaomi
                            loader.js:161 Translations loaded for: MMM-xiaomi
                            loader.js:197 Load stylesheet: css/custom.css
                            MMM-xiaomi.js:35 Starting module: MMM-xiaomi
                            main.js:422 All modules started!
                            module.js:117 MMM-xiaomi received a system notification: ALL_MODULES_STARTED
                            module.js:117 MMM-xiaomi received a system notification: DOM_OBJECTS_CREATED
                            MMM-xiaomi.js:242 Uncaught TypeError: this.html.col.format is not a function
                                at Class. (MMM-xiaomi.js:242)
                                at module.js:183
                              mirko3000
                              Ok, now another try :) Forgot to add utility class which was already present from other modules on my instance. Please update from GIT.
                              • A
                                Albert2002
                                Sometimes a pictures tells you more than words…
                                You did it!
                                You did it! Great job! Thank you! :-)
                                Next step are to integrate te Yeelights ;-)
                                  mirko3000
                                  Good to hear! :)
                                  Suggestions welcome, I have just added ventilation recommendation(see latest update), will also add window sensors - but still unsure how to visualize all that information. Suggestions welcome!
                                  • A
                                    Albert2002
                                    Looking forward to see the window sensors! I would like to see the current state & the last change of it. Are you planing something like this?
                                    Name     State     Last change
                                    Kitchen  closed   1.Nov. 18:01
                                    What I would like to see on my mirror as well are the sate of the Yeelights ( on / off)
                                      barnosch
                                      So, sadly the german customs took my whole order from China.
                                      No CE sign, no german manual, wirless connection needs to be tested…
                                      i could puke.
                                      Can someone recommend a company i can order from germany, without getting to the customs (EU-Warenlager) ?
                                      ? 1 Reply Last reply
                                        A Former User @barnosch
                                        @barnosch
                                        So sad. I want to know also, is there good IoT set for home in EU(Germany).
                                        I’ve tested some “Jinvoo” (another Chinese product?), it works somehow, but API is not opened.
                                        • A
                                          Albert2002
                                          Most of my Chinese stuff I get from gearbest.com If you choose „Standard Shipping > Germany Express“ you won’t get any problems. Watch out for mi smart home bundles on there website.
                                            barnosch
                                            The order was from gearbest .
                                            Usually you have to choose “priority line” to get it without problems.
                                            It wasn’t available at this time for the ordered stuff.
                                            So i made the mistake.
                                            But anycase, my problem. Don’t want to highjack the thread with some customs problems.
                                            Found now a dealer to order the gateway from EU-warehouse and another dealer to get the sensors via Belgium.
                                            Hopeing for the best ;)
                                            • 2 / 8
