    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 235.3k Views 28 Watching
      Albert2002
      I did the steps again to get the (new) Token. Now, I have a new Token and the Gateway again in my Mi Home app. I didn’t updated the Token on the different machine this time.
      I’ve tried out your new config. I still don’t see more than before on the MM, but I don’t have an error log as well, which make it a bit more harder.
      I have checked the IP address of the Gateway, its still the same. Dev is still enabled.
      My config with the new Token.
      		module: 'MMM-xiaomi',
      		position: 'bottom_left',
      		header: 'Temperatur / Feuchtigkeit',  // This is optional
      			interval: 30,
      			gatewayIP: '192.168.2.107',
      			gatewayToken: '050591e66a82f7adc92bfa6b03058cdb',
      			devices: [{ id: '158d00015736a8', name: 'Wohnzimmer' }]
      Edit:
      I get a error when I try to discover with miio:
      pi@MagicMirror:~/MagicMirror/modules/MMM-xiaomi/node_modules/miio $ miio --discover
       INFO  Discovering devices. Press Ctrl+C to stop.
      Device ID: 52238776
      Model info: Unknown
      Address: 192.168.2.107
      Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token
      Support: Unknown
      (node:3626) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
        Albert2002
        Where did miio stored the Token?
        The Token Miio used “Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token”
        is the old one! the new one is 050591e66a82f7adc92bfa6b03058cdb
          mirko3000
          Hmm not sure about miio details, I just know that you can sync the tokens via
          miio --discover --sync
          Else I would try manually setting to the correct (new) token.
          For the MM: try to uncomment line 51 in node_helper.js, this logs all found devices. You could also add some more logs here to see where the program fails.
            Albert2002
            Hi Mirko! Thanks for your reply!
            Before and after I uncommented the line 51 and restartet MM.
            Still with the old Token
            pi@MagicMirror:~ $ miio --discover --sync
            Device ID: 52238776
            Model info: Unknown
            Support: Unknown
            (node:25652) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
            But right now after uncommenting the line the error log is different. In the log i can already see the Temperature and humidity (_properties: { temperature: 19.51, humidity: 62.44 },)!! The next step!
            > magicmirror@2.1.3 start /home/pi/MagicMirror
            > sh run-start.sh
            Starting MagicMirror: v2.1.3
            Loading config ...
            Loading module helpers ...
            Module helper loaded: MMM-DWD-WarnWeather
            Module helper loaded: MMM-PNews
            Module helper loaded: MMM-Remote-Control
            No helper found for module: MMM-Remote-Control-Repository.
            Module helper loaded: internet-monitor
            Module helper loaded: MMM-MovieListings
            Module helper loaded: MMM-Fuel
            Module helper loaded: MMM-NetworkScanner
            Module helper loaded: MMM-nasaastropic
            Module helper loaded: MMM-SystemStats
            Module helper loaded: MMM-Departures
            No helper found for module: MMM-Carousel.
            Module helper loaded: MMM-Events
            Module helper loaded: MMM-xiaomi
            All module helpers loaded.
            You're using a full whitelist configuration to allow for all IPs
            Server started ...
            Connecting socket for: MMM-DWD-WarnWeather
            MMM-DWD-WarnWeather helper started...
            Connecting socket for: MMM-PNews
            Starting module: MMM-PNews
            Starting module: newsfeed
            Connecting socket for: MMM-Remote-Control
            Starting node helper for: MMM-Remote-Control
            Connecting socket for: internet-monitor
            internet-monitor helper started ...
            Connecting socket for: MMM-MovieListings
            MMM-MovieListing helper started...
            Connecting socket for: MMM-Fuel
            Starting module helper: MMM-Fuel
            Connecting socket for: MMM-NetworkScanner
            Starting module: MMM-NetworkScanner
            Connecting socket for: MMM-nasaastropic
            Starting node helper: MMM-nasaastropic
            Connecting socket for: MMM-SystemStats
            Connecting socket for: MMM-Departures
            Connecting socket for: MMM-Events
            Starting node_helper for: MMM-Events
            Connecting socket for: MMM-xiaomi
            Starting xiaomi helper
            Launching application.
            Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/htc.one.m2304%40gmail.com/private-;-)/basic.ics - Interval: 300000
            Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
            Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
            starting internet monitor node helper
            MMM-NetworkScanner received CONFIG
            astro helper: config received
            retrieveAndUpdate()
            Triggering Xiaomi Gateway upate
            MMM-Departures error: Error: getaddrinfo ENOTFOUND transportrest-sbiermann.rhcloud.com transportrest-sbiermann.rhcloud.com:80
            NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/m5_hubblesmessier1024c.jpg
            Magnet {
              domain: null,
              _events: {},
              _eventsCount: 0,
              _maxListeners: undefined,
              model: 'lumi.magnet',
              type: 'magnet',
              capabilities: [],
              _properties: {},
              _propertiesToMonitor: [],
              _propertyDefinitions: {},
              _parent:
               Gateway {
                 domain: null,
                 _events: {},
                 _eventsCount: 0,
                 type: 'gateway',
                 model: 'lumi.gateway.v3',
                 capabilities: [ 'color:rgb', 'brightness', 'sensor', 'illuminance' ],
                 address: '192.168.2.107',
                 port: 54321,
                 writeOnly: false,
                 packet:
                  Packet {
                    header: ,
                    _serverStampTime: 1509842296639,
                    _token: ,
                    _tokenKey: ,
                    _tokenIV: ,
                    data: ,
                    _serverStamp: 48587 },
                 socket:
                  Socket {
                    domain: null,
                    _events: [Object],
                    _eventsCount: 1,
                    _handle: [Object],
                    _receiving: true,
                    _bindState: 2,
                    type: 'udp4',
                    fd: -42,
                    _reuseAddr: undefined,
                    _queue: undefined },
                 _id: 4,
                 _promises: {},
                 _hasFailedToken: false,
                 _properties: { illuminance: 307, rgb: [Object], brightness: 0 },
                 _propertiesToMonitor: [ 'illumination', 'rgb' ],
                 _propertyDefinitions: { illumination: [Object], rgb: [Object] },
                 _reversePropertyDefinitions: { illuminance: 'illumination' },
                 _loadProperties: [Function: bound _loadProperties],
                 management: DeviceManagement { device: [Circular] },
                 debug:
                  { [Function: debug]
                    namespace: 'miio.device.[192.168.2.107]',
                    enabled: false,
                    useColors: false,
                    color: 1,
                    inspectOpts: {} },
                 _devices:
                  { '158d000119fcb2': [Object],
                    '158d00013e28ee': [Object],
                    '158d00015aa973': [Object],
                    '158d00015736a8': [Object] },
                 _monitorInterval: 60000,
                 _propertyMonitor:
                  Timeout {
                    _called: false,
                    _idleTimeout: 60000,
                    _idlePrev: [Object],
                    _idleNext: [Object],
                    _idleStart: 69767,
                    _onTimeout: [Function: bound _loadProperties],
                    _timerArgs: undefined,
                    _repeat: 60000 },
                 _lastToken: 1509842294044,
                 _developerKey: 'xqbs1fvtsq6x4oby',
                 devApi:
                  DeveloperApi {
                    domain: null,
                    _events: [Object],
                    _eventsCount: 2,
                    debug: [Object],
                    socket: [Object],
                    devices: [],
                    ready: false },
                 setRGB: [Function],
                 setBrightness: [Function],
                 _deviceListTimer:
                  Timeout {
                    _called: false,
                    _idleTimeout: 1800000,
                    _idleStart: 72417,
                    _onTimeout: [Function: bound _updateDeviceList],
                    _repeat: 1800000 } },
              management: SubDeviceManagement { _device: [Circular] },
              debug:
               { [Function: debug]
                 namespace: 'miio.device.[192.168.2.107].158d000119fcb2',
                 enabled: false,
                 useColors: false,
                 color: 1,
                 inspectOpts: {} } }
            Switch {
              domain: null,
              _events: {},
              _eventsCount: 0,
              model: 'lumi.switch',
              type: 'controller',
              capabilities: [],
              _properties: {},
              _parent:
               Gateway {
                 domain: null,
                 _events: {},
                 _eventsCount: 0,
                 type: 'gateway',
                 port: 54321,
                 writeOnly: false,
                 packet:
                  Packet {
                    header: ,
                    _token: ,
                    _tokenKey: ,
                    _tokenIV: ,
                    data: ,
                 socket:
                  Socket {
                    domain: null,
                    _events: [Object],
                    _eventsCount: 1,
                    _handle: [Object],
                    _receiving: true,
                    _bindState: 2,
                    type: 'udp4',
                    fd: -42,
                 _id: 4,
                 _promises: {},
                 debug:
                  { [Function: debug]
                    enabled: false,
                    useColors: false,
                    color: 1,
                    inspectOpts: {} },
                 _devices:
                 _propertyMonitor:
                  Timeout {
                    _called: false,
                    _idleStart: 69767,
                    _repeat: 60000 },
                 devApi:
                  DeveloperApi {
                    domain: null,
                    _events: [Object],
                    _eventsCount: 2,
                    debug: [Object],
                    socket: [Object],
                    devices: [],
                    ready: false },
                 setRGB: [Function],
                 _deviceListTimer:
                  Timeout {
                    _called: false,
                    _idleStart: 72417,
              debug:
               { [Function: debug]
                 namespace: 'miio.device.[192.168.2.107].158d00015aa973',
                 enabled: false,
                 useColors: false,
                 color: 3,
                 inspectOpts: {} } }
            SensorHT {
              domain: null,
              _events: {},
              _eventsCount: 0,
              model: 'lumi.sensor_ht',
              type: 'sensor',
              capabilities: [ 'sensor', 'temperature', 'humidity' ],
              _propertiesToMonitor: [ 'temperature', 'humidity' ],
               { temperature: { mapper: [Function] },
                 humidity: { mapper: [Function] } },
              _parent:
               Gateway {
                 domain: null,
                 _events: {},
                 _eventsCount: 0,
                 type: 'gateway',
                 port: 54321,
                 writeOnly: false,
                 packet:
                  Packet {
                    header: ,
                    _token: ,
                    _tokenKey: ,
                    _tokenIV: ,
                    data: ,
                 socket:
                  Socket {
                    domain: null,
                    _events: [Object],
                    _eventsCount: 1,
                    _handle: [Object],
                    _receiving: true,
                    _bindState: 2,
                    type: 'udp4',
                    fd: -42,
                 _id: 4,
                 _promises: {},
                 debug:
                  { [Function: debug]
                    enabled: false,
                    useColors: false,
                    color: 1,
                    inspectOpts: {} },
                 _devices:
                 _propertyMonitor:
                  Timeout {
                    _called: false,
                    _idleStart: 69767,
                    _repeat: 60000 },
                 devApi:
                  DeveloperApi {
                    domain: null,
                    _events: [Object],
                    _eventsCount: 2,
                    debug: [Object],
                    socket: [Object],
                    devices: [],
                    ready: false },
                 setRGB: [Function],
                 _deviceListTimer:
                  Timeout {
                    _called: false,
                    _idleStart: 72417,
              debug:
               { [Function: debug]
                 namespace: 'miio.device.[192.168.2.107].158d00015736a8',
                 enabled: false,
                 useColors: false,
                 color: 6,
                 inspectOpts: {} } }
              Albert2002
              One more. When I run the MM as standalone server (node serveronly) I get this in the Browser console:
              MMM-xiaomi.js:28 received XIAOMI_DATA
              MMM-xiaomi.js:212 Uncaught TypeError: Cannot read property 'id' of null
                  at Class. (MMM-xiaomi.js:212)
                  at Function.each (jquery-2.2.3.min.js:2)
                  at Class.renderText (MMM-xiaomi.js:210)
                  at Class.render (MMM-xiaomi.js:100)
                  at Class.socketNotificationReceived (MMM-xiaomi.js:29)
                  at module.js:183
                  at r. (socketclient.js:25)
                  at r.emit (index.js:133)
                  at r.onevent (socket.js:270)
                  at r.MMSocket.self.socket.onevent (socketclient.js:19)
              (anonymous) @ MMM-xiaomi.js:212
              each @ jquery-2.2.3.min.js:2
              renderText @ MMM-xiaomi.js:210
              render @ MMM-xiaomi.js:100
              socketNotificationReceived @ MMM-xiaomi.js:29
              (anonymous) @ module.js:183
              (anonymous) @ socketclient.js:25
              r.emit @ index.js:133
              r.onevent @ socket.js:270
              MMSocket.self.socket.onevent @ socketclient.js:19
              r.onpacket @ socket.js:228
              (anonymous) @ index.js:21
              r.ondecoded @ manager.js:345
              s.add @ index.js:241
              r.ondata @ manager.js:335
              r.onPacket @ socket.js:457
              (anonymous) @ socket.js:274
              r.onPacket @ transport.js:145
              r.onData @ transport.js:137
              ws.onmessage @ websocket.js:147
                mirko3000
                Try the latest update (git pull), I just checked for null items - even i that should not happen.
                  Albert2002
                  I did so. Restarted MM.
                  No errors in the logs.
                  mm out:
                  Found device with ID 158d000119fcb2 of type magnet
                  Found device with ID 158d00015aa973 of type controller
                  Found device with ID 158d00015736a8 of type sensor
                  This I got from the Browser Debug:
                  main.js:404 Initializing MagicMirror.
                  translator.js:197 Loading core translation file: translations/de.json
                  translator.js:219 Loading core translation fallback file: translations/en.json
                  loader.js:182 Load script: modules/MMM-xiaomi//MMM-xiaomi.js
                  module.js:406 Check MagicMirror version for module 'MMM-xiaomi' - Minimum version:  2.0.0 - Current version: 2.1.3
                  module.js:408 Version is ok!
                  module.js:414 Module registered: MMM-xiaomi
                  loader.js:152 Bootstrapping module: MMM-xiaomi
                  loader.js:182 Load script: modules/MMM-xiaomi/String.format.js
                  String.format.js Failed to load resource: the server responded with a status of 404 (Not Found)
                  loader.js:190 Error on loading script: modules/MMM-xiaomi/String.format.js
                  script.onerror @ loader.js:190
                  loader.js:182 Load script: https://code.jquery.com/jquery-2.2.3.min.js
                  loader.js:157 Scripts loaded for: MMM-xiaomi
                  loader.js:197 Load stylesheet: modules/MMM-xiaomi/MMM-xiaomi.css
                  loader.js:159 Styles loaded for: MMM-xiaomi
                  loader.js:161 Translations loaded for: MMM-xiaomi
                  loader.js:197 Load stylesheet: css/custom.css
                  MMM-xiaomi.js:35 Starting module: MMM-xiaomi
                  main.js:422 All modules started!
                  module.js:117 MMM-xiaomi received a system notification: ALL_MODULES_STARTED
                  module.js:117 MMM-xiaomi received a system notification: DOM_OBJECTS_CREATED
                  MMM-xiaomi.js:242 Uncaught TypeError: this.html.col.format is not a function
                      at Class. (MMM-xiaomi.js:242)
                      at module.js:183
                    mirko3000
                    Ok, now another try :) Forgot to add utility class which was already present from other modules on my instance. Please update from GIT.
                      Albert2002
                      Sometimes a pictures tells you more than words…
                      You did it!
                      You did it! Great job! Thank you! :-)
                      Next step are to integrate te Yeelights ;-)
                        mirko3000
                        Good to hear! :)
                        Suggestions welcome, I have just added ventilation recommendation(see latest update), will also add window sensors - but still unsure how to visualize all that information. Suggestions welcome!
                          Albert2002
                          Looking forward to see the window sensors! I would like to see the current state & the last change of it. Are you planing something like this?
                          Name     State     Last change
                          Kitchen  closed   1.Nov. 18:01
                          What I would like to see on my mirror as well are the sate of the Yeelights ( on / off)
                            barnosch
                            So, sadly the german customs took my whole order from China.
                            No CE sign, no german manual, wirless connection needs to be tested…
                            i could puke.
                            Can someone recommend a company i can order from germany, without getting to the customs (EU-Warenlager) ?
                              A Former User @barnosch
                              @barnosch
                              So sad. I want to know also, is there good IoT set for home in EU(Germany).
                              I’ve tested some “Jinvoo” (another Chinese product?), it works somehow, but API is not opened.
                                Albert2002
                                Most of my Chinese stuff I get from gearbest.com If you choose „Standard Shipping > Germany Express“ you won’t get any problems. Watch out for mi smart home bundles on there website.
                                  barnosch
                                  The order was from gearbest .
                                  Usually you have to choose “priority line” to get it without problems.
                                  It wasn’t available at this time for the ordered stuff.
                                  So i made the mistake.
                                  But anycase, my problem. Don’t want to highjack the thread with some customs problems.
                                  Found now a dealer to order the gateway from EU-warehouse and another dealer to get the sensors via Belgium.
                                  Hopeing for the best ;)
                                    mirko3000
                                    I just recieved my order of another 6 window sensors yesterday :) But I really think they will shut this down soon, guess they (gearbest) are not paying any taxes at all…
                                    Working on the new version, this is what I have in mind:
                                    cowboysdudeC S 2 Replies Last reply Reply Quote 1
                                      Albert2002
                                      This looks great! As far as I understand there is for every room a thermometer & humidity with trent, light indicator (Yeelight?) and Windows sensors? Pretty nice!
                                      Are you going to release this as a new module, or as a change of the old one? I would prefer a new module, because this one takes a lot of space and is hardly to integrate in a single screen. I
                                      I think the same. It already took more time to receive and it’s getting less products you can order with „Standard Shipping > Germany Express“
                                      • cowboysdudeC Offline
                                        I’m in the US and I ordered from Gearbest and did not will not again… I put in my order and it I never got what I ordered so I put a claim in against them … they told me ‘well we now have the items in stock so if you drop your claim…’
                                        According to their site the stuff I ordered was already in stock… when I ordered them.
                                        I said uhhhhhh no. So they refunded me…and I ordered them from another company and hopefully they’ll be here next week :) They shipped them right out and gave me a tracking number… Gearbest… I don’t trust them.
                                          cowboysdude Module Developer @mirko3000
                                          @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                                          window sensors
                                          What is the module your door/window sensors? I find two but not sure which ones to use here.
                                            Albert2002
                                            I have the Xiaomi. I don’t think there is a difference apart from the design:
                                            Xiaomi vs Aqara door/window sensors
                                            • 2 / 8
