    MMM-xiaomi - Temperature and Humidity from your smarthome
    141 Posts 27 Posters 231.6k Views 27 Watching
      Albert2002
      I am a step ahead!
      I followed the instructions to get the token “Getting the token when using the Mi Home app”
      This was working. I could see all the connected devices to the Gateway.
      pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover --sync
       INFO  Discovering devices. Press Ctrl+C to stop.
      Device ID: 52238776
      Model info: Unknown
      Address: 192.168.13.1
      Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via auto-token
      Support: Unknown
      Device ID: 158d000119fcb2
      Model info: lumi.magnet (magnet)
      Address: Owned by 52238776
      Token: Automatic via parent device
      Support: At least basic
      Device ID: 158d00013e28ee
      Model info: lumi.plug (power-plug)
      Device ID: 158d00015aa973
      Model info: lumi.switch (controller)
      Device ID: 158d00015736a8
      Model info: lumi.sensor_ht (sensor)
      At this point I had to switch over to the Pi with the installed MagicMirror:
      pi@MagicMirror:~ $ miio --discover
      Device ID: 52238776
      Model info: Unknown
      Address: 192.168.2.107
      Token: ???
      Support: Unknown
      I’ve updated the Token as described:
      pi@MagicMirror:~ $ miio --update 52238776 --token 6eea5ac1eb475bfedbfff98aab7c2bc7
       INFO  Attempting to update 52238776
       INFO  Device updated
      I’ve searched for devices again. Now with success!
      Device ID: 52238776
      Model info: Unknown
      Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token
      Support: Unknown
      The problem so far is, that I still don’t get any informations visible in MM. I’ve tried ‘158d00015736a8’ and as well ‘52238776’ as id.
      The second problem is, that I’ve lost the Gateway in my Mi Home app after updating the Token!
      The question is, how to copy ( Store?) over the Token to a different Machine?
      mm error:
      error: Token could not be auto-discovered
          at Device._tokenResolve (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:141:13)
          at Device._onMessage (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:80:9)
          at emitTwo (events.js:106:13)
          at Socket.emit (events.js:194:7)
          at UDP.onMessage [as onmessage] (dgram.js:545:8)
        mirko3000
        Ok at least some progress. So first to enable your manual token just update the configuration:
        	 interval: 30,
        	 gatewayIP: '192.168.13.1',
        	 gatewayToken: '6eea5ac1eb475bfedbfff98aab7c2bc7',
        	 devices : [{
        You only need the IDs from your sensors, not the gateway.
        About the Mi Home App and your lost token, I would try once this works to reconfigure your gateway with the Mi Home app, and then try to fetch the auto-token again (in your first sample it seems to provide auto-token).
          Albert2002
          I did the steps again to get the (new) Token. Now, I have a new Token and the Gateway again in my Mi Home app. I didn’t updated the Token on the different machine this time.
          I’ve tried out your new config. I still don’t see more than before on the MM, but I don’t have an error log as well, which make it a bit more harder.
          I have checked the IP address of the Gateway, its still the same. Dev is still enabled.
          My config with the new Token.
          		module: 'MMM-xiaomi',
          		position: 'bottom_left',
          		header: 'Temperatur / Feuchtigkeit',  // This is optional
          			interval: 30,
          			gatewayIP: '192.168.2.107',
          			gatewayToken: '050591e66a82f7adc92bfa6b03058cdb',
          			devices: [{ id: '158d00015736a8', name: 'Wohnzimmer' }]
          Edit:
          I get a error when I try to discover with miio:
          pi@MagicMirror:~/MagicMirror/modules/MMM-xiaomi/node_modules/miio $ miio --discover
          Device ID: 52238776
          Model info: Unknown
          Support: Unknown
          (node:3626) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
            Albert2002
            Where did miio stored the Token?
            The Token Miio used “Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token”
            is the old one! the new one is 050591e66a82f7adc92bfa6b03058cdb
              mirko3000
              Hmm not sure about miio details, I just know that you can sync the tokens via
              Else I would try manually setting to the correct (new) token.
              For the MM: try to uncomment line 51 in node_helper.js, this logs all found devices. You could also add some more logs here to see where the program fails.
                Albert2002
                Hi Mirko! Thanks for your reply!
                Before and after I uncommented the line 51 and restartet MM.
                Still with the old Token
                pi@MagicMirror:~ $ miio --discover --sync
                Device ID: 52238776
                Model info: Unknown
                Support: Unknown
                (node:25652) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
                But right now after uncommenting the line the error log is different. In the log i can already see the Temperature and humidity (_properties: { temperature: 19.51, humidity: 62.44 },)!! The next step!
                > magicmirror@2.1.3 start /home/pi/MagicMirror
                > sh run-start.sh
                Starting MagicMirror: v2.1.3
                Loading config ...
                Loading module helpers ...
                Module helper loaded: MMM-DWD-WarnWeather
                Module helper loaded: MMM-PNews
                Module helper loaded: MMM-Remote-Control
                No helper found for module: MMM-Remote-Control-Repository.
                Module helper loaded: internet-monitor
                Module helper loaded: MMM-MovieListings
                Module helper loaded: MMM-Fuel
                Module helper loaded: MMM-NetworkScanner
                Module helper loaded: MMM-nasaastropic
                Module helper loaded: MMM-SystemStats
                Module helper loaded: MMM-Departures
                No helper found for module: MMM-Carousel.
                Module helper loaded: MMM-Events
                Module helper loaded: MMM-xiaomi
                All module helpers loaded.
                You're using a full whitelist configuration to allow for all IPs
                Server started ...
                Connecting socket for: MMM-DWD-WarnWeather
                MMM-DWD-WarnWeather helper started...
                Connecting socket for: MMM-PNews
                Starting module: MMM-PNews
                Starting module: newsfeed
                Connecting socket for: MMM-Remote-Control
                Starting node helper for: MMM-Remote-Control
                Connecting socket for: internet-monitor
                internet-monitor helper started ...
                Connecting socket for: MMM-MovieListings
                MMM-MovieListing helper started...
                Connecting socket for: MMM-Fuel
                Starting module helper: MMM-Fuel
                Connecting socket for: MMM-NetworkScanner
                Starting module: MMM-NetworkScanner
                Connecting socket for: MMM-nasaastropic
                Starting node helper: MMM-nasaastropic
                Connecting socket for: MMM-SystemStats
                Connecting socket for: MMM-Departures
                Connecting socket for: MMM-Events
                Starting node_helper for: MMM-Events
                Connecting socket for: MMM-xiaomi
                Starting xiaomi helper
                Launching application.
                Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/htc.one.m2304%40gmail.com/private-;-)/basic.ics - Interval: 300000
                Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
                Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
                starting internet monitor node helper
                MMM-NetworkScanner received CONFIG
                astro helper: config received
                retrieveAndUpdate()
                Triggering Xiaomi Gateway upate
                MMM-Departures error: Error: getaddrinfo ENOTFOUND transportrest-sbiermann.rhcloud.com transportrest-sbiermann.rhcloud.com:80
                NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/m5_hubblesmessier1024c.jpg
                Magnet {
                  domain: null,
                  _events: {},
                  _eventsCount: 0,
                  _maxListeners: undefined,
                  model: 'lumi.magnet',
                  type: 'magnet',
                  capabilities: [],
                  _properties: {},
                  _propertiesToMonitor: [],
                  _propertyDefinitions: {},
                  _parent:
                   Gateway {
                     domain: null,
                     _events: {},
                     _eventsCount: 0,
                     type: 'gateway',
                     model: 'lumi.gateway.v3',
                     capabilities: [ 'color:rgb', 'brightness', 'sensor', 'illuminance' ],
                     address: '192.168.2.107',
                     port: 54321,
                     writeOnly: false,
                     packet:
                      Packet {
                        header: ,
                        _serverStampTime: 1509842296639,
                        _token: ,
                        _tokenKey: ,
                        _tokenIV: ,
                        data: ,
                        _serverStamp: 48587 },
                     socket:
                      Socket {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 1,
                        _handle: [Object],
                        _receiving: true,
                        _bindState: 2,
                        type: 'udp4',
                        fd: -42,
                        _reuseAddr: undefined,
                        _queue: undefined },
                     _id: 4,
                     _promises: {},
                     _hasFailedToken: false,
                     _properties: { illuminance: 307, rgb: [Object], brightness: 0 },
                     _propertiesToMonitor: [ 'illumination', 'rgb' ],
                     _propertyDefinitions: { illumination: [Object], rgb: [Object] },
                     _reversePropertyDefinitions: { illuminance: 'illumination' },
                     _loadProperties: [Function: bound _loadProperties],
                     management: DeviceManagement { device: [Circular] },
                     debug:
                      { [Function: debug]
                        namespace: 'miio.device.[192.168.2.107]',
                        enabled: false,
                        useColors: false,
                        color: 1,
                        inspectOpts: {} },
                     _devices:
                      { '158d000119fcb2': [Object],
                        '158d00013e28ee': [Object],
                        '158d00015aa973': [Object],
                        '158d00015736a8': [Object] },
                     _monitorInterval: 60000,
                     _propertyMonitor:
                      Timeout {
                        _called: false,
                        _idleTimeout: 60000,
                        _idlePrev: [Object],
                        _idleNext: [Object],
                        _idleStart: 69767,
                        _onTimeout: [Function: bound _loadProperties],
                        _timerArgs: undefined,
                        _repeat: 60000 },
                     _lastToken: 1509842294044,
                     _developerKey: 'xqbs1fvtsq6x4oby',
                     devApi:
                      DeveloperApi {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 2,
                        debug: [Object],
                        socket: [Object],
                        devices: [],
                        ready: false },
                     setRGB: [Function],
                     setBrightness: [Function],
                     _deviceListTimer:
                      Timeout {
                        _called: false,
                        _idleTimeout: 1800000,
                        _idleStart: 72417,
                        _onTimeout: [Function: bound _updateDeviceList],
                        _repeat: 1800000 } },
                  management: SubDeviceManagement { _device: [Circular] },
                  debug:
                   { [Function: debug]
                     namespace: 'miio.device.[192.168.2.107].158d000119fcb2',
                     enabled: false,
                     useColors: false,
                     color: 1,
                     inspectOpts: {} } }
                Switch {
                  domain: null,
                  _events: {},
                  _eventsCount: 0,
                  model: 'lumi.switch',
                  type: 'controller',
                  capabilities: [],
                  _properties: {},
                  _parent:
                   Gateway {
                     domain: null,
                     _events: {},
                     _eventsCount: 0,
                     type: 'gateway',
                     port: 54321,
                     writeOnly: false,
                     packet:
                      Packet {
                        header: ,
                        _token: ,
                        _tokenKey: ,
                        _tokenIV: ,
                        data: ,
                     socket:
                      Socket {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 1,
                        _handle: [Object],
                        _receiving: true,
                        _bindState: 2,
                        type: 'udp4',
                        fd: -42,
                     _id: 4,
                     _promises: {},
                     debug:
                      { [Function: debug]
                        enabled: false,
                        useColors: false,
                        color: 1,
                        inspectOpts: {} },
                     _devices:
                     _propertyMonitor:
                      Timeout {
                        _called: false,
                        _idleStart: 69767,
                        _repeat: 60000 },
                     devApi:
                      DeveloperApi {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 2,
                        debug: [Object],
                        socket: [Object],
                        devices: [],
                        ready: false },
                     setRGB: [Function],
                     _deviceListTimer:
                      Timeout {
                        _called: false,
                        _idleStart: 72417,
                  debug:
                   { [Function: debug]
                     namespace: 'miio.device.[192.168.2.107].158d00015aa973',
                     enabled: false,
                     useColors: false,
                     color: 3,
                     inspectOpts: {} } }
                SensorHT {
                  domain: null,
                  _events: {},
                  _eventsCount: 0,
                  model: 'lumi.sensor_ht',
                  type: 'sensor',
                  capabilities: [ 'sensor', 'temperature', 'humidity' ],
                  _propertiesToMonitor: [ 'temperature', 'humidity' ],
                   { temperature: { mapper: [Function] },
                     humidity: { mapper: [Function] } },
                  _parent:
                   Gateway {
                     domain: null,
                     _events: {},
                     _eventsCount: 0,
                     type: 'gateway',
                     port: 54321,
                     writeOnly: false,
                     packet:
                      Packet {
                        header: ,
                        _token: ,
                        _tokenKey: ,
                        _tokenIV: ,
                        data: ,
                     socket:
                      Socket {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 1,
                        _handle: [Object],
                        _receiving: true,
                        _bindState: 2,
                        type: 'udp4',
                        fd: -42,
                     _id: 4,
                     _promises: {},
                     debug:
                      { [Function: debug]
                        enabled: false,
                        useColors: false,
                        color: 1,
                        inspectOpts: {} },
                     _devices:
                     _propertyMonitor:
                      Timeout {
                        _called: false,
                        _idleStart: 69767,
                        _repeat: 60000 },
                     devApi:
                      DeveloperApi {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 2,
                        debug: [Object],
                        socket: [Object],
                        devices: [],
                        ready: false },
                     setRGB: [Function],
                     _deviceListTimer:
                      Timeout {
                        _called: false,
                        _idleStart: 72417,
                  debug:
                   { [Function: debug]
                     namespace: 'miio.device.[192.168.2.107].158d00015736a8',
                     enabled: false,
                     useColors: false,
                     color: 6,
                     inspectOpts: {} } }
                  Albert2002
                  One more. When I run the MM as standalone server (node serveronly) I get this in the Browser console:
                  MMM-xiaomi.js:28 received XIAOMI_DATA
                  MMM-xiaomi.js:212 Uncaught TypeError: Cannot read property 'id' of null
                      at Class. (MMM-xiaomi.js:212)
                      at Function.each (jquery-2.2.3.min.js:2)
                      at Class.renderText (MMM-xiaomi.js:210)
                      at Class.render (MMM-xiaomi.js:100)
                      at Class.socketNotificationReceived (MMM-xiaomi.js:29)
                      at module.js:183
                      at r. (socketclient.js:25)
                      at r.emit (index.js:133)
                      at r.onevent (socket.js:270)
                      at r.MMSocket.self.socket.onevent (socketclient.js:19)
                  (anonymous) @ MMM-xiaomi.js:212
                  each @ jquery-2.2.3.min.js:2
                  renderText @ MMM-xiaomi.js:210
                  render @ MMM-xiaomi.js:100
                  socketNotificationReceived @ MMM-xiaomi.js:29
                  (anonymous) @ module.js:183
                  (anonymous) @ socketclient.js:25
                  r.emit @ index.js:133
                  r.onevent @ socket.js:270
                  MMSocket.self.socket.onevent @ socketclient.js:19
                  r.onpacket @ socket.js:228
                  (anonymous) @ index.js:21
                  r.ondecoded @ manager.js:345
                  s.add @ index.js:241
                  r.ondata @ manager.js:335
                  r.onPacket @ socket.js:457
                  (anonymous) @ socket.js:274
                  r.onPacket @ transport.js:145
                  r.onData @ transport.js:137
                  ws.onmessage @ websocket.js:147
                    mirko3000
                    Try the latest update (git pull), I just checked for null items - even i that should not happen.
                      Albert2002
                      I did so. Restarted MM.
                      No errors in the logs.
                      mm out:
                      Found device with ID 158d000119fcb2 of type magnet
                      Found device with ID 158d00015aa973 of type controller
                      Found device with ID 158d00015736a8 of type sensor
                      This I got from the Browser Debug:
                      main.js:404 Initializing MagicMirror.
                      translator.js:197 Loading core translation file: translations/de.json
                      translator.js:219 Loading core translation fallback file: translations/en.json
                      loader.js:182 Load script: modules/MMM-xiaomi//MMM-xiaomi.js
                      module.js:406 Check MagicMirror version for module 'MMM-xiaomi' - Minimum version:  2.0.0 - Current version: 2.1.3
                      module.js:408 Version is ok!
                      module.js:414 Module registered: MMM-xiaomi
                      loader.js:152 Bootstrapping module: MMM-xiaomi
                      loader.js:182 Load script: modules/MMM-xiaomi/String.format.js
                      String.format.js Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:190 Error on loading script: modules/MMM-xiaomi/String.format.js
                      script.onerror @ loader.js:190
                      loader.js:182 Load script: https://code.jquery.com/jquery-2.2.3.min.js
                      loader.js:157 Scripts loaded for: MMM-xiaomi
                      loader.js:197 Load stylesheet: modules/MMM-xiaomi/MMM-xiaomi.css
                      loader.js:159 Styles loaded for: MMM-xiaomi
                      loader.js:161 Translations loaded for: MMM-xiaomi
                      loader.js:197 Load stylesheet: css/custom.css
                      MMM-xiaomi.js:35 Starting module: MMM-xiaomi
                      main.js:422 All modules started!
                      module.js:117 MMM-xiaomi received a system notification: ALL_MODULES_STARTED
                      module.js:117 MMM-xiaomi received a system notification: DOM_OBJECTS_CREATED
                      MMM-xiaomi.js:242 Uncaught TypeError: this.html.col.format is not a function
                          at Class. (MMM-xiaomi.js:242)
                          at module.js:183
                        mirko3000
                        Ok, now another try :) Forgot to add utility class which was already present from other modules on my instance. Please update from GIT.
                          Albert2002
                          Sometimes a pictures tells you more than words…
                          You did it!
                          You did it! Great job! Thank you! :-)
                          Next step are to integrate te Yeelights ;-)
                            mirko3000
                            Good to hear! :)
                            Suggestions welcome, I have just added ventilation recommendation(see latest update), will also add window sensors - but still unsure how to visualize all that information. Suggestions welcome!
                              Albert2002
                              Looking forward to see the window sensors! I would like to see the current state & the last change of it. Are you planing something like this?
                              Name     State     Last change
                              Kitchen  closed   1.Nov. 18:01
                              What I would like to see on my mirror as well are the sate of the Yeelights ( on / off)
                                barnosch
                                So, sadly the german customs took my whole order from China.
                                No CE sign, no german manual, wirless connection needs to be tested…
                                i could puke.
                                Can someone recommend a company i can order from germany, without getting to the customs (EU-Warenlager) ?
                                  A Former User @barnosch
                                  @barnosch
                                  So sad. I want to know also, is there good IoT set for home in EU(Germany).
                                  I’ve tested some “Jinvoo” (another Chinese product?), it works somehow, but API is not opened.
                                    Albert2002
                                    Most of my Chinese stuff I get from gearbest.com If you choose „Standard Shipping > Germany Express“ you won’t get any problems. Watch out for mi smart home bundles on there website.
                                      barnosch
                                      The order was from gearbest .
                                      Usually you have to choose “priority line” to get it without problems.
                                      It wasn’t available at this time for the ordered stuff.
                                      So i made the mistake.
                                      But anycase, my problem. Don’t want to highjack the thread with some customs problems.
                                      Found now a dealer to order the gateway from EU-warehouse and another dealer to get the sensors via Belgium.
                                      Hopeing for the best ;)
                                        mirko3000
                                        I just recieved my order of another 6 window sensors yesterday :) But I really think they will shut this down soon, guess they (gearbest) are not paying any taxes at all…
                                        Working on the new version, this is what I have in mind:
                                        cowboysdudeC S 2 Replies Last reply Reply Quote 1
                                          Albert2002
                                          This looks great! As far as I understand there is for every room a thermometer & humidity with trent, light indicator (Yeelight?) and Windows sensors? Pretty nice!
                                          Are you going to release this as a new module, or as a change of the old one? I would prefer a new module, because this one takes a lot of space and is hardly to integrate in a single screen. I
                                          I think the same. It already took more time to receive and it’s getting less products you can order with „Standard Shipping > Germany Express“
                                          • cowboysdudeC Offline
                                            I’m in the US and I ordered from Gearbest and did not will not again… I put in my order and it I never got what I ordered so I put a claim in against them … they told me ‘well we now have the items in stock so if you drop your claim…’
                                            According to their site the stuff I ordered was already in stock… when I ordered them.
                                            I said uhhhhhh no. So they refunded me…and I ordered them from another company and hopefully they’ll be here next week :) They shipped them right out and gave me a tracking number… Gearbest… I don’t trust them.
                                            • 2 / 8
