    Choosing mirror. 2 samples
    19 Posts 3 Posters 15.2k Views 3 Watching
      Phate @KirAsh4
      @KirAsh4
      I was hoping you might chime in lol :-)
      I’ll check and see… whats the chances of a touch monitor working thru the glass… slim to none from my guess lol
        Phate
        Darker one on the left…
        Screen on with nothing displayed
        Screen off
          Phate
          I’ll take a photo of a normal pic to show colour diff…
          • K
            KirAsh4 Moderator
            The only reason I ask is because you can do one of three things here:
            • pick the best reflective mirror and just deal with the lesser light shining through, or
            • use the lighter one and when you want to use it as a mirror, you can either:
              a) turn off all the modules, but the TV remains on, or
              b) turn off the TV all together
            Using the lighter one is contingent on how well it reflects when there’s nothing being displayed or the TV is completely turned off. But if it reflects better, then that may be the way to go.
            I realize the last option may be somewhat annoying but it would work. And turning off the modules is a piece of cake. Or you could even turn off the HDMI output on the rpi, but the TV remains on … although some (most?) TV will then also turn off the screen’s backlight if they don’t detect an HDMI signal. Mine does. It stays on for a few seconds then the backlight turns off. The TV is still on, but the screen is off completely.
              Phate @KirAsh4
              @KirAsh4
              Thanks for the advice…
              Hard to choose… I think? that I will be able to get away with the lighter stuff…
              Not that fussed about the mirror part… just the kewl factor…
              I wish now that I had gotten bigger bits to test with to really be able to see but the guy was nice enough to just give me these test bits… I think he even cut them to size as I originally asked when enquired for a size roughly the size of a pi 7" screen…
              No mirror colour test
              Light Mirror
              Dark Mirror
              • K
                KirAsh4 Moderator
                Yeah, I definitely like the lighter one better (specially with the TV completely off!), but you need to decide on the reflective property. If it doesn’t suit you (you can’t quite see the mustache hair), then you’ll have to figure something else out.
                  Phate @KirAsh4
                  @KirAsh4
                  hahahhaahh
                  Thinking lighter for sure maybe hmmmm… lol
                  Its really intended as a pure dashboard… mirror is not important…
                  By the time I get ALL the modules working that I want then it will be a nearly full screen anyway hahahah
                  Plus i like the idea of pulling up a second screen if I ever need to…
                  Still… Test will be in the actual large piece…
                  While your around and helpful… do you see any dramas with the TV I have… 40" cheap VIANO LED LCD
                  Will attempt to remove the bezel after and check if the screen is not attached to be able to remove it… Otherwise the glass is close enough to the height of the bezel it may just fit inside bezel nice but to frame it I’ll lose a very small amount of screen space…
                  • K
                    KirAsh4 Moderator
                    I can’t think of any reason not to use a TV, other than power usage. And I’m kinda, sort, every-so-often, pondering the idea of having multiple instances of MM² running, on multiple screens, each with its own config. Consider a large installation of round mirrors (like 10" across), and each one having a screen (like a cheap tablet) behind them displaying a specific module. Could be fun, if not heavy. :)
                    Mock up: 8" large circles
                    Test pieces cut out of wood: 10" circles: The holes that match the one at the top with a red cover on it are meant to have either a frosted piece of acrylic, or smoke color, with an RGBW LED module under them, so they can all be lit up. The front and back pieces are 1" apart, so a tablet can very easily fit between them.
                    • K
                      KirAsh4 Moderator
                      Here I printed multiple white covers, testing different printing methods, and I also tried doing the connecting pieces in white, just to see how it looks like. I think I like the black ones better. Anyway, you get the idea …
                      P 2 Replies Last reply Reply Quote 0
                        Phate @KirAsh4
                        @KirAsh4
                        I’ve thought about multiple instances myself…
                        I was thinking a whole bunch of raspberry pi 7’ screens with just one module each spread over a huge window with that film… mmmmmm lol
                        That would look awesome as a magic mirror
                        I’d also love and RGB controller module… maybe the seed studios gear might be an easy integrate…
                        Pi screens might be fairly cheap… probably find 8" I was only thinking the 7" official one for ease compatibility…
                        I’d LOVE to see this if you manage it…
                          Phate @KirAsh4
                          @KirAsh4
                          What printer do you have?
                          Only just got mine a few months ago Flashforge Dreamer… Working way up on longer prints…
                          Cant wait to try the wood and metal filaments…
                          • K
                            KirAsh4 Moderator
                            Problem with using screens attached to the rpi is that they will all display the same thing, whereas a tablet, being a separate device, can load up MM² as an external URL. It doesn’t have to be a tablet, it could be something completely different. For that matter, they can be rpi zero devices with a screen attached. Those things are $5 each and while MM² won’t run on them, you can still load up a browser on them. :)
                            • K
                              KirAsh4 Moderator
                              What you see there are laser cut wood pieces. The connectors and light cups are done on an Ultimaker 2.
                                Phate @KirAsh4
                                @KirAsh4
                                hmmmm yes forgot about that rpi Zero… hmmm that does spark some thoughts…
                                I wonder if I am allowed to use this software for displaying info in our small business…
                                Picked up a cheap Nexus 7 tablet recently… 7" I think… still pretty good and lots around… they gave them out with new mobile contracts for a while…
                                • K
                                  KirAsh4 Moderator
                                  Other than being ‘too much for what you’d use it for’, old tablet are cheap to come by. The trick is going to be keeping them running. I do like the rpi zero idea because they would all be connected to my main network and I can easily push updates to them that way.
                                  • K
                                    KirAsh4 Moderator
                                    For the record, I’m in the same rpi user group that’s chanting: PXE … PXE … PXE … (ideally wireless, but that’s a big overhead to have, ethernet would be fine)
                                      molechi
                                      Hi
                                      Can you provide product info for the 2 you’re comparing? I like the lighter one. Thanks
