    Choosing mirror. 2 samples
    19 Posts 3 Posters 15.3k Views 3 Watching
    • KirAsh4K
      KirAsh4 Moderator
      The only reason I ask is because you can do one of three things here:
      • pick the best reflective mirror and just deal with the lesser light shining through, or
      • use the lighter one and when you want to use it as a mirror, you can either:
        a) turn off all the modules, but the TV remains on, or
        b) turn off the TV all together
      Using the lighter one is contingent on how well it reflects when there’s nothing being displayed or the TV is completely turned off. But if it reflects better, then that may be the way to go.
      I realize the last option may be somewhat annoying but it would work. And turning off the modules is a piece of cake. Or you could even turn off the HDMI output on the rpi, but the TV remains on … although some (most?) TV will then also turn off the screen’s backlight if they don’t detect an HDMI signal. Mine does. It stays on for a few seconds then the backlight turns off. The TV is still on, but the screen is off completely.
      P 1 Reply Last reply
        Phate @KirAsh4
        @KirAsh4
        Thanks for the advice…
        Hard to choose… I think? that I will be able to get away with the lighter stuff…
        Not that fussed about the mirror part… just the kewl factor…
        I wish now that I had gotten bigger bits to test with to really be able to see but the guy was nice enough to just give me these test bits… I think he even cut them to size as I originally asked when enquired for a size roughly the size of a pi 7" screen…
        No mirror colour test
        Light Mirror
        Dark Mirror
        • KirAsh4K
          KirAsh4 Moderator
          Yeah, I definitely like the lighter one better (specially with the TV completely off!), but you need to decide on the reflective property. If it doesn’t suit you (you can’t quite see the mustache hair), then you’ll have to figure something else out.
            Phate @KirAsh4
            @KirAsh4
            hahahhaahh
            Thinking lighter for sure maybe hmmmm… lol
            Its really intended as a pure dashboard… mirror is not important…
            By the time I get ALL the modules working that I want then it will be a nearly full screen anyway hahahah
            Plus i like the idea of pulling up a second screen if I ever need to…
            Still… Test will be in the actual large piece…
            While your around and helpful… do you see any dramas with the TV I have… 40" cheap VIANO LED LCD
            Will attempt to remove the bezel after and check if the screen is not attached to be able to remove it… Otherwise the glass is close enough to the height of the bezel it may just fit inside bezel nice but to frame it I’ll lose a very small amount of screen space…
            • KirAsh4K
              KirAsh4 Moderator
              I can’t think of any reason not to use a TV, other than power usage. And I’m kinda, sort, every-so-often, pondering the idea of having multiple instances of MM² running, on multiple screens, each with its own config. Consider a large installation of round mirrors (like 10" across), and each one having a screen (like a cheap tablet) behind them displaying a specific module. Could be fun, if not heavy. :)
              Mock up: 8" large circles
              Test pieces cut out of wood: 10" circles: The holes that match the one at the top with a red cover on it are meant to have either a frosted piece of acrylic, or smoke color, with an RGBW LED module under them, so they can all be lit up. The front and back pieces are 1" apart, so a tablet can very easily fit between them.
              • KirAsh4K
                KirAsh4 Moderator
                Here I printed multiple white covers, testing different printing methods, and I also tried doing the connecting pieces in white, just to see how it looks like. I think I like the black ones better. Anyway, you get the idea …
                P 2 Replies Last reply
                  Phate @KirAsh4
                  @KirAsh4
                  I’ve thought about multiple instances myself…
                  I was thinking a whole bunch of raspberry pi 7’ screens with just one module each spread over a huge window with that film… mmmmmm lol
                  That would look awesome as a magic mirror
                  I’d also love and RGB controller module… maybe the seed studios gear might be an easy integrate…
                  Pi screens might be fairly cheap… probably find 8" I was only thinking the 7" official one for ease compatibility…
                  I’d LOVE to see this if you manage it…
                    Phate @KirAsh4
                    @KirAsh4
                    What printer do you have?
                    Only just got mine a few months ago Flashforge Dreamer… Working way up on longer prints…
                    Cant wait to try the wood and metal filaments…
                    • KirAsh4K
                      KirAsh4 Moderator
                      Problem with using screens attached to the rpi is that they will all display the same thing, whereas a tablet, being a separate device, can load up MM² as an external URL. It doesn’t have to be a tablet, it could be something completely different. For that matter, they can be rpi zero devices with a screen attached. Those things are $5 each and while MM² won’t run on them, you can still load up a browser on them. :)
                      • KirAsh4K
                        KirAsh4 Moderator
                        What you see there are laser cut wood pieces. The connectors and light cups are done on an Ultimaker 2.
                          Phate @KirAsh4
                          @KirAsh4
                          hmmmm yes forgot about that rpi Zero… hmmm that does spark some thoughts…
                          I wonder if I am allowed to use this software for displaying info in our small business…
                          Picked up a cheap Nexus 7 tablet recently… 7" I think… still pretty good and lots around… they gave them out with new mobile contracts for a while…
                          • KirAsh4K
                            KirAsh4 Moderator
                            Other than being ‘too much for what you’d use it for’, old tablet are cheap to come by. The trick is going to be keeping them running. I do like the rpi zero idea because they would all be connected to my main network and I can easily push updates to them that way.
                            • KirAsh4K
                              KirAsh4 Moderator
                              For the record, I’m in the same rpi user group that’s chanting: PXE … PXE … PXE … (ideally wireless, but that’s a big overhead to have, ethernet would be fine)
                                molechi
                                Hi
                                Can you provide product info for the 2 you’re comparing? I like the lighter one. Thanks
