    Choosing mirror. 2 samples
    19 Posts 3 Posters 15.1k Views 3 Watching
      Phate @KirAsh4
      @KirAsh4
      hahahhaahh
      Thinking lighter for sure maybe hmmmm… lol
      Its really intended as a pure dashboard… mirror is not important…
      By the time I get ALL the modules working that I want then it will be a nearly full screen anyway hahahah
      Plus i like the idea of pulling up a second screen if I ever need to…
      Still… Test will be in the actual large piece…
      While your around and helpful… do you see any dramas with the TV I have… 40" cheap VIANO LED LCD
      Will attempt to remove the bezel after and check if the screen is not attached to be able to remove it… Otherwise the glass is close enough to the height of the bezel it may just fit inside bezel nice but to frame it I’ll lose a very small amount of screen space…
      • K Offline
        KirAsh4 Moderator
        I can’t think of any reason not to use a TV, other than power usage. And I’m kinda, sort, every-so-often, pondering the idea of having multiple instances of MM² running, on multiple screens, each with its own config. Consider a large installation of round mirrors (like 10" across), and each one having a screen (like a cheap tablet) behind them displaying a specific module. Could be fun, if not heavy. :)
        Mock up: 8" large circles
        Test pieces cut out of wood: 10" circles: The holes that match the one at the top with a red cover on it are meant to have either a frosted piece of acrylic, or smoke color, with an RGBW LED module under them, so they can all be lit up. The front and back pieces are 1" apart, so a tablet can very easily fit between them.
        • K Offline
          KirAsh4 Moderator
          Here I printed multiple white covers, testing different printing methods, and I also tried doing the connecting pieces in white, just to see how it looks like. I think I like the black ones better. Anyway, you get the idea …
          P 2 Replies Last reply Reply Quote 0
            Phate @KirAsh4
            @KirAsh4
            I’ve thought about multiple instances myself…
            I was thinking a whole bunch of raspberry pi 7’ screens with just one module each spread over a huge window with that film… mmmmmm lol
            That would look awesome as a magic mirror
            I’d also love and RGB controller module… maybe the seed studios gear might be an easy integrate…
            Pi screens might be fairly cheap… probably find 8" I was only thinking the 7" official one for ease compatibility…
            I’d LOVE to see this if you manage it…
              Phate @KirAsh4
              @KirAsh4
              What printer do you have?
              Only just got mine a few months ago Flashforge Dreamer… Working way up on longer prints…
              Cant wait to try the wood and metal filaments…
              • K Offline
                KirAsh4 Moderator
                Problem with using screens attached to the rpi is that they will all display the same thing, whereas a tablet, being a separate device, can load up MM² as an external URL. It doesn’t have to be a tablet, it could be something completely different. For that matter, they can be rpi zero devices with a screen attached. Those things are $5 each and while MM² won’t run on them, you can still load up a browser on them. :)
                • K Offline
                  KirAsh4 Moderator
                  What you see there are laser cut wood pieces. The connectors and light cups are done on an Ultimaker 2.
                    Phate @KirAsh4
                    @KirAsh4
                    hmmmm yes forgot about that rpi Zero… hmmm that does spark some thoughts…
                    I wonder if I am allowed to use this software for displaying info in our small business…
                    Picked up a cheap Nexus 7 tablet recently… 7" I think… still pretty good and lots around… they gave them out with new mobile contracts for a while…
                    • K Offline
                      KirAsh4 Moderator
                      Other than being ‘too much for what you’d use it for’, old tablet are cheap to come by. The trick is going to be keeping them running. I do like the rpi zero idea because they would all be connected to my main network and I can easily push updates to them that way.
                      • K Offline
                        KirAsh4 Moderator
                        For the record, I’m in the same rpi user group that’s chanting: PXE … PXE … PXE … (ideally wireless, but that’s a big overhead to have, ethernet would be fine)
                          molechi
                          Hi
                          Can you provide product info for the 2 you’re comparing? I like the lighter one. Thanks
