    Choosing mirror. 2 samples
    19 Posts 3 Posters 15.3k Views 3 Watching
    • KirAsh4K
      KirAsh4 Moderator
      I can’t think of any reason not to use a TV, other than power usage. And I’m kinda, sort, every-so-often, pondering the idea of having multiple instances of MM² running, on multiple screens, each with its own config. Consider a large installation of round mirrors (like 10" across), and each one having a screen (like a cheap tablet) behind them displaying a specific module. Could be fun, if not heavy. :)
      Mock up: 8" large circles
      Test pieces cut out of wood: 10" circles: The holes that match the one at the top with a red cover on it are meant to have either a frosted piece of acrylic, or smoke color, with an RGBW LED module under them, so they can all be lit up. The front and back pieces are 1" apart, so a tablet can very easily fit between them.
      • KirAsh4K
        KirAsh4 Moderator
        Here I printed multiple white covers, testing different printing methods, and I also tried doing the connecting pieces in white, just to see how it looks like. I think I like the black ones better. Anyway, you get the idea …
        P 2 Replies Last reply
          Phate @KirAsh4
          @KirAsh4
          I’ve thought about multiple instances myself…
          I was thinking a whole bunch of raspberry pi 7’ screens with just one module each spread over a huge window with that film… mmmmmm lol
          That would look awesome as a magic mirror
          I’d also love and RGB controller module… maybe the seed studios gear might be an easy integrate…
          Pi screens might be fairly cheap… probably find 8" I was only thinking the 7" official one for ease compatibility…
          I’d LOVE to see this if you manage it…
            Phate @KirAsh4
            @KirAsh4
            What printer do you have?
            Only just got mine a few months ago Flashforge Dreamer… Working way up on longer prints…
            Cant wait to try the wood and metal filaments…
            • KirAsh4K
              KirAsh4 Moderator
              Problem with using screens attached to the rpi is that they will all display the same thing, whereas a tablet, being a separate device, can load up MM² as an external URL. It doesn’t have to be a tablet, it could be something completely different. For that matter, they can be rpi zero devices with a screen attached. Those things are $5 each and while MM² won’t run on them, you can still load up a browser on them. :)
              • KirAsh4K
                KirAsh4 Moderator
                What you see there are laser cut wood pieces. The connectors and light cups are done on an Ultimaker 2.
                P 1 Reply Last reply
                  Phate @KirAsh4
                  @KirAsh4
                  hmmmm yes forgot about that rpi Zero… hmmm that does spark some thoughts…
                  I wonder if I am allowed to use this software for displaying info in our small business…
                  Picked up a cheap Nexus 7 tablet recently… 7" I think… still pretty good and lots around… they gave them out with new mobile contracts for a while…
                  • KirAsh4K
                    KirAsh4 Moderator
                    Other than being ‘too much for what you’d use it for’, old tablet are cheap to come by. The trick is going to be keeping them running. I do like the rpi zero idea because they would all be connected to my main network and I can easily push updates to them that way.
                    • KirAsh4K
                      KirAsh4 Moderator
                      For the record, I’m in the same rpi user group that’s chanting: PXE … PXE … PXE … (ideally wireless, but that’s a big overhead to have, ethernet would be fine)
                        molechi
                        Hi
                        Can you provide product info for the 2 you’re comparing? I like the lighter one. Thanks
