    MM is eating all memory and crash!
    18 Posts 5 Posters 11.3k Views 4 Watching
      juergschwarz @juergschwarz
      Is anyone able to show me a list of used modules, memory and uptime ?
        Mykle1 Project Sponsor Module Developer @juergschwarz
        @juergschwarz said in MM is eating all memory and crash!:
        What the hell can i do?
        About three months ago most all of these concerns were addressed by me and a few other fantastic people. We did quite a bit of troubleshooting. You will certainly benefit from reading through this and taking the necessary steps:
        https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
        Note:
        Most, if not all of the people involved, were using a Pi3.
        Some modules present a higher system load than others.
        Opinion:
        Use Jessie, not Stretch
        J Mykle1M 2 Replies Last reply Reply Quote 0
          juergschwarz @Mykle1
          Now i changed to Raspberry 3. After 2h system crashed. 4MB memory left.
          This is my sylog
          Nov 9 22:03:06 raspi32 kernel: [ 5458.473560] Out of memory: Kill process 880 (electron) score 948 or sacrifice child
          Nov 9 22:03:06 raspi32 kernel: [ 5458.473695] Killed process 880 (electron) total-vm:981380kB, anon-rss:671832kB, file-rss:104kB, shmem-rss:7180kB
          Nov 9 22:05:58 raspi32 systemd[1]: Started Session c4 of user pi.
          This is not realy what i can use. I dont like to change to debian 8.
            A memory leak was discussed in the topic I recommended to you. Was that result with the default installation of MM or did you add other modules?
            Your choice, sir. Good luck :-)
              @Mykle1 With Rasp 3 i checked again with this six modules on 1. thread. Whitch Raspi .iso do you guy use for MM? Maybee i should install all things manual instead of this automatic installation? Memory leak not possible couse of Raspi 2 was the same issue and 2 different SD Cards.
                @juergschwarz
                Question:
                Did you read the topic I suggested to you? I’m curious
                  @Mykle1 Yes i read it. All of this suggestions i already checked out. If you tell me to test standard installation whitout any additional modules - what the hell do all this people building such modules when i only can use standard modules?
                  Dont misunderstand me. But i manage two root servers with kvm - lvm and aprox. 30 official domains and nearly 200 email accounts. Longest uptime was 772 days. Nobody can tell me a application with black background and some “only text foreground apps” should not be able to run more than 2 hours or not?
                    Very good. You had the benefit of other people’s time and hard work. Imagine if you had to think of all those tests for yourself.
                    Logically, that would be a starting point, to see if the issue arises before the addition of other modules. If the problem arises afterward, then you can attribute the cause to something that you added. If not, then the cause lies in the OS version, the MM version, or with the Pi itself, or the way it was prepared.
                    I could not be less impressed.
                    Nobody is telling you anything. I thought you wanted help so I started where anyone would start, at the beginning. Instead of some small measure of gratitude, you started spewing your impotent anger at me.
                    I only have one more question for you.
                    With the impressive resume you have, why didn’t you just figure it out and fix it yourself? :-)
                    • cowboysdudeC Offline
                      You are in the minority … I have 3 running, without issues… 1 of them has been running a solid year without any issues what-so-ever.
                      With that being said being rude to someone trying to help you is not really a way to get help…
                      • emloweE Offline
                        emlowe Module Developer
                        $ uptime
                         21:34:37 up 37 days, 58 min,  3 users,  load average: 0.08, 0.13, 0.09
                        $ cat /etc/issue
                        Raspbian GNU/Linux 8 \n \l
                        $ uname -a
                        Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
                        $ free -m
                                     total       used       free     shared    buffers     cached
                        Mem:           923        878         44        149         64        487
                        -/+ buffers/cache:        326        596
                        Swap:           99         99          0
                        $ df -k
                        Filesystem     1K-blocks    Used Available Use% Mounted on
                        /dev/root        5863924 4248140   1294864  77% /
                        devtmpfs          468148       0    468148   0% /dev
                        tmpfs             472756  147656    325100  32% /dev/shm
                        tmpfs             472756   12364    460392   3% /run
                        tmpfs               5120       4      5116   1% /run/lock
                        tmpfs             472756       0    472756   0% /sys/fs/cgroup
                        /dev/mmcblk0p6     66528   21418     45110  33% /boot
                        tmpfs              94552       0     94552   0% /run/user/1000
                        tmpfs              94552       0     94552   0% /run/user/1001
                        /dev/mmcblk0p5     30701     463     27945   2% /media/elowe/SETTINGS
                         $ npm ls | grep -i magicmirror
                        magicmirror@2.1.3
                        $ npm ls | grep electron
                        ├─┬ electron@1.7.5
                        │ ├─┬ electron-download@3.3.0
                        │ ├─┬ electron-chromedriver@1.6.0
                        │ │ ├── electron-download@3.3.0 deduped
                        │ │ │ └── electron-to-chromium@1.3.24
                        Modules:
                        • clock
                        • currentweather
                        • weatherforecast
                        • MMM-MyScoreboard
                        • MMM-EnphaseEnvoy
                        • MMM-CalenderExt
                        • MMM-AirNow
                        • MMM-AutelisPentair
                        • MMM-Globe
                        • MMM-Remote-Control
                        • MMM-PIR-Sensor
