    MMM-PIR-Sensor Guide with Edits and Updates
    20 Posts 15 Posters 18.5k Views 17 Watching
      StacheEnthusiast
      I recently got the MMM-PIR-Sensor up and going and it’s working flawlessly. I wanted to give a little information as I had to parse this from different sources and some of the info is a bit dated.
      I am relatively new to pi in general so definitely point it out if something isn’t right.
      Below is a step by step for MMM-PIR-Sensor by paviro.
      Navigate to your modules folder at cd ~/MagicMirror/modules
      Execute git clone https://github.com/paviro/MMM-PIR-Sensor.git
      Navigate to cd ~/MagicMirror/modules/MMM-PIR-Sensor
      This is one area I got held up
      The guide states to perform an npm install where a dated version(2.25) of wiring-pi would be installed.
      When issuing the command gpio -v, I would get an error message “Unable to determine hardware version. I see: Hardware : BCM2835 - expecting BCM2708 or BCM2709. Please report this to project@drogon.net”.
      Instead use npm install wiring-pi inside your MMM-PIR-Sensor folder. This will install the updated version(2.44) which you can verify with gpio -v.
      Then issue command sudo usermod -a -G gpio pi
      Then sudo chmod u+s /opt/vc/bin/tvservice && sudo chmod u+s /bin/chvt
      The guide says to reboot here but after that, it still wasn’t working for me. Then I stumbled on some excellent advice from the forums here from @JamesMM with @strawberry 3.141 contributing.
      Their focus was on the node_helper.js within the module. These are their edits.
      First, rename the current file. mv node_helper.js node_helper_backup.js
      Now, create a new file called node_helper.js using sudo nano node_helper.js
      Copy and paste this code
      'use strict';
      /* Magic Mirror
       * Module: MMM-PIR-Sensor
       * By Paul-Vincent Roll http://paulvincentroll.com
       * MIT Licensed.
      const NodeHelper = require('node_helper');
      const Gpio = require('onoff').Gpio;
      const exec = require('child_process').exec;
        start: function()
          this.started = false;
        activateMonitor: function()
          if (this.config.relayPIN != false)
              this.relay.writeSync(this.config.relayOnState);
          else if (this.config.relayPIN == false)
              // Check if hdmi output is already on
              exec("/opt/vc/bin/tvservice -s").stdout.on('data', function(data) {
                  if (data.indexOf("0x120002") !== -1)
                      exec("/opt/vc/bin/tvservice --preferred && chvt 6 && chvt 7", null);
        deactivateMonitor: function()
              this.relay.writeSync(this.config.relayOffState);
              exec("/opt/vc/bin/tvservice -o", null);
        // Subclass socketNotificationReceived received.
        socketNotificationReceived: function(notification, payload)
          if (notification === 'CONFIG' && this.started == false)
              const self = this;
              this.config = payload;
              self.timer = null;
              self.onState = 0;
              // Setup value which represent on and off
              const valueOn = this.config.invertSensorValue ? 0 : 1;
              const valueOff = this.config.invertSensorValue ? 1 : 0;
              //Log.info('PIR: ' + this.name);
              //Setup pins
              this.pir = new Gpio(this.config.sensorPIN, 'in', 'both');
              if (this.config.relayPIN)
                  this.relay = new Gpio(this.config.relayPIN, 'out');
                  exec("/opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7", null);
              //Detected movement
              this.pir.watch(function(err, value) {
                  if (value == 1)
                      clearTimeout(self.timer);
                      if (self.onState != 1)
                          self.sendSocketNotification("USER_PRESENCE", true);
                          if (self.config.powerSaving)
                              self.activateMonitor();
                              self.onState = 1;
                  else if (value == 0)
                      if (self.onState != 0)
                          self.timer = setTimeout(function(){
                              self.sendSocketNotification("USER_PRESENCE", false);
                                  self.deactivateMonitor();
                                  self.onState = 0;
                          }, self.config.offDelay);
              this.started = true;
          else if (notification === 'SCREEN_WAKEUP')
              this.activateMonitor();
      This creates a new config called offDelay and it is in configurable in milliseconds.
      Reboot your pi.
      Then add the modules configuration to MM’s config.js. I used this but obviously adjust it to your own needs.
      		module: 'MMM-PIR-Sensor',
      			sensorPIN: 22,
      			powerSaving: true,
      			offDelay: 30000,
      The offDelay of 30000 is 30 seconds.
      Mykle1M 1 Reply Last reply Reply Quote 7
        Mykle1 Project Sponsor Module Developer @StacheEnthusiast
        @StacheEnthusiast
        I like people who write guides! I don’t use a PIR sensor but I do appreciate the time and effort you put in on everyone’s behalf.
        S 1 Reply Last reply Reply Quote 3
          StacheEnthusiast @Mykle1
          @Mykle1
          Thanks!
            DavA
            I followed your guide but i still get version 2.25 when i use npm install wiring-pi.
            Any ideas why?
            G F 2 Replies Last reply Reply Quote 1
              SvenT
              • G Offline
                greenwaydev @DavA
                • F Offline
                  FruityBebbles @DavA
                  @StacheEnthusiast @DavA Hey, I just decided to try and install MMM-PIR-Sensor but am running into the same issue.
                  I was wondering if you ever did get this working as the directions have stated…
                    msherwood
                    shit, this killed my MM build…it’s all blank…crap
                      ardentaardvark
                      @msherwood Hey FYI I just got my lastest build (from scratch yesterday) working with MMM-PIR-Sensor:
                      I also found that npm install wiring-pi installed the old (2.25) version for me. I found a newer library:
                      npm install wiring-pi-2019
                      which installs version 2.5 (this one works on my pi4!).
                      I also found that the location of the tvservice binary has changed, so I just used the following bash commands:
                      sudo chmod u+s `which tvservice`
                      sudo chmod u+s `which chvt`
                      It then worked for me (Note, I did not modify the node_helper.js script at all.)
                        dubalda
                        Hi all, unfortunately I’m not too familiar with coding but had this module failed to update today having followed the steps above which worked fine with the previous version.
                        Has anyone else experienced this?
