    MMM-PIR-Sensor Guide with Edits and Updates
    20 Posts 15 Posters 19.9k Views 17 Watching
    • F Offline
      FruityBebbles @DavA
      @StacheEnthusiast @DavA Hey, I just decided to try and install MMM-PIR-Sensor but am running into the same issue.
      I was wondering if you ever did get this working as the directions have stated…
        msherwood
        shit, this killed my MM build…it’s all blank…crap
          ardentaardvark
          @msherwood Hey FYI I just got my lastest build (from scratch yesterday) working with MMM-PIR-Sensor:
          I also found that npm install wiring-pi installed the old (2.25) version for me. I found a newer library:
          npm install wiring-pi-2019
          which installs version 2.5 (this one works on my pi4!).
          I also found that the location of the tvservice binary has changed, so I just used the following bash commands:
          sudo chmod u+s `which tvservice`
          sudo chmod u+s `which chvt`
          It then worked for me (Note, I did not modify the node_helper.js script at all.)
            dubalda
            Hi all, unfortunately I’m not too familiar with coding but had this module failed to update today having followed the steps above which worked fine with the previous version.
            Has anyone else experienced this?
            • FoziF Offline
              Fozi Project Sponsor @dubalda
              @dubalda can you elaborate more detailed the failure, e.g, error message or similar?
              • Feedy88F Offline
                Feedy88
                I am curious to know if there is a benefit by using the MM-Module for the PIR vs. the executable script which can be autostarted with pm2 (as per this tutorial). Can anyone help?
                  dubalda @Fozi
                  @Fozi thank you for coming back to me. Here are the error messages I’m getting…apologies if it’s quite long! I unfortunately wasn’t able to upload the log file.
                  pi@pi:~/MagicMirror/modules/MMM-PIR-Sensor $ git pull
                  Updating be81cf0…d4831f2
                  Fast-forward
                  README.md | 14 ++++++++++++++
                  node_helper.js | 46 ++++++++++++++++++++++++++++++++++++++++++++±
                  2 files changed, 59 insertions(+), 1 deletion(-)
                  pi@pi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                  Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                  electron-rebuild -e …/…/node_modules/electron
                  â Rebuild Failed
                  An unhandled error occurred inside electron-rebuild
                  make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019/build’
                  CXX(target) Release/obj.target/wiringPi/src/addon.o
                  In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                  from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                  from …/src/addon.h:4,
                  from …/src/addon.cc:1:
                  /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
                  declarator attribute((deprecated(message)))
                  /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                  V8_DEPRECATE_SOON("Use WithData version.",
                  /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                  In file included from …/src/addon.cc:1:
                  …/src/addon.h:12:28: error: ‘Handle’ is not a member of ‘v8’
                  bool HasInstance(v8::Handlev8::Value val);
                  …/src/addon.h:12:44: error: expected primary-expression before ‘>’ token
                  …/src/addon.h:12:46: error: ‘val’ was not declared in this scope
                  …/src/addon.h:13:28: error: redefinition of ‘bool node::Buffer::HasInstance’
                  bool HasInstance(v8::Handlev8::Object val);
                  …/src/addon.h:12:12: note: ‘bool node::Buffer::HasInstance’ previously defined here
                  …/src/addon.h:13:28: error: ‘Handle’ is not a member of ‘v8’
                  …/src/addon.h:13:45: error: expected primary-expression before ‘>’ token
                  …/src/addon.h:13:47: error: ‘val’ was not declared in this scope
                  …/src/addon.h:14:22: error: ‘Handle’ is not a member of ‘v8’
                  char
                  Data(v8::Handlev8::Value val);
                  …/src/addon.h:14:38: error: expected primary-expression before ‘>’ token
                  char
                  …/src/addon.h:14:40: error: ‘val’ was not declared in this scope
                  char* Data(v8::Handlev8::Value val);
                  …/src/addon.h:15:22: error: redefinition of ‘char* node::Buffer::Data’
                  char* Data(v8::Handlev8::Object val);
                  …/src/addon.h:14:13: note: ‘char* node::Buffer::Data’ previously defined here
                  …/src/addon.h:15:22: error: ‘Handle’ is not a member of ‘v8’
                  …/src/addon.h:15:39: error: expected primary-expression before ‘>’ token
                  …/src/addon.h:15:41: error: ‘val’ was not declared in this scope
                  …/src/addon.h:16:25: error: ‘Handle’ is not a member of ‘v8’
                  size_t Length(v8::Handlev8::Value val);
                  …/src/addon.h:16:41: error: expected primary-expression before ‘>’ token
                  …/src/addon.h:16:43: error: ‘val’ was not declared in this scope
                  …/src/addon.h:17:25: error: redefinition of ‘size_t node::Buffer::Length’
                  size_t Length(v8::Handlev8::Object val);
                  …/src/addon.h:16:14: note: ‘size_t node::Buffer::Length’ previously defined here
                  …/src/addon.h:17:25: error: ‘Handle’ is not a member of ‘v8’
                  …/src/addon.h:17:42: error: expected primary-expression before ‘>’ token
                  …/src/addon.h:17:44: error: ‘val’ was not declared in this scope
                  …/src/addon.cc: In function ‘void throw_error(v8::Isolate*, const char*, …)’:
                  …/src/addon.cc:35:90: error: no matching function for call to ‘v8::Exception::Error(v8::MaybeLocalv8::String)’
                  isolate->ThrowException(v8::Exception::Error(v8::String::NewFromUtf8(isolate, buffer)));
                  In file included from …/src/addon.h:4,
                  /home/pi/.electron-gyp/6.1.7/include/node/v8.h:6538:23: note: candidate: ‘static v8::Localv8::Value v8::Exception::Error(v8::Localv8::String)’
                  static Local Error(Local message);
                  /home/pi/.electron-gyp/6.1.7/include/node/v8.h:6538:23: note: no known conversion for argument 1 from ‘v8::MaybeLocalv8::String’ to ‘v8::Localv8::String’
                  make: *** [wiringPi.target.mk:147: Release/obj.target/wiringPi/src/addon.o] Error 1
                  make: Leaving directory ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019/build’
                  gyp ERR! build error
                  gyp ERR! stack Error: make failed with exit code: 2
                  gyp ERR! stack at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/build.js:194:23)
                  gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                  gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                  gyp ERR! System Linux 4.19.118-v7l+
                  gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp” “rebuild” “–target=6.1.7” “–arch=arm” “–dist-url=https://www.electronjs.org/headers” “–build-from-source”
                  gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019
                  gyp ERR! node -v v10.21.0
                  gyp ERR! node-gyp -v v6.1.0
                  gyp ERR! not ok
                  Failed with exit code: 1
                  Error: make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi-2019/build’
                  char
                  char
                  gyp ERR! not ok
                  at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
                  at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
                  at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
                  at Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                  at Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                  at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                  at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                  at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
                  at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 255
                  npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron
                  npm ERR! Exit status 255
                  npm ERR!
                  npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script.
                  npm ERR! /home/pi/.npm/_logs/2020-07-16T09_45_07_608Z-debug.log
                  [0_1595277021862_PIR-Sensor Error logs.txt](Uploading 100%)
                  • FoziF Offline
                    I‘d delete the module and re-install it. Obviously you haven’t changed any code (no info on stashing in the log). Your configuration will not be affected when you delete the module, it‘ll persist in config. js.
                    1. stop all processes with entering pm2 stop all.
                    2. cd to the module folder and enter: sudo rm -R MMM-PIR-Sensor. This will recursively remove the MMM-PIR-Sensor folder and it’s contents.
                    3. Re-install the module as described on GitHub. The installation build process should run through without errors.
                    4. Reboot
                      sdetweil @Fozi
                      @Fozi rm -rf foldername will recursively remove all folders and content from foldername
                        @sdetweil looks like the wrong compiler level being used for the recompile.
                          dubalda
                          Thanks guys, sorry for the late response! It’s the summer holidays so I’ve been doing daddy day care. I’ll try removing the module and reinstalling it. I’ll keep you posted.
                            sebfas @Feedy88
                            @Feedy88
                            Works with out any problems, much better solution then MMM-PIR-Sensor.
                            • bugsounetB Offline
                              bugsounet Banned
                              Please no ads of any of my modules
                              If no one respect this rules. I will make private it
                                sparxx @bugsounet
                                @bugsounet my apologies. I have deleted the post.
