    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.4k Views 28 Watching
      mirko3000 @trividar
      Can you post the configuration for the Xiaomi module? You need to provide a list of rooms, each of one with the assigned device IDs:
      	            rooms:  [
      		            	sortOrder: 40,
      		            	devices : ['158d010171840d', '158d00016cddae']
      		            	sortOrder: 70,
      		            	devices : ['158d0001735ac2']
      Also please check that you use the latest version.
      About that WunderGround module: I need to test that myself, not sure why there are such kind of interferences.
      • T
        trividar
        I have the latest version and thats my config:
        		module: 'MMM-xiaomi',
        		position: 'bottom_left',
        		header: 'Temperature / Humidity',  // This is optional
        			interval: 30,
        			gatewayIP: '192.168.1.128',
        			gatewayToken: '65764848557cccc2170d1fd8c06b32cb',
        			devices: [{
          mirko3000
          That is the config for the old version. Please check the README carefully:
          https://github.com/mirko3000/MMM-xiaomi#configuration-options
          			interval: 30,
          			rooms: [{
          			       name: 'Schlafzimmer temp' ,
                                         devices:[ '158d0001dfdb14'],
                                         sortOrder: 1
          • T
            trividar
            oooo shit…my mistake! It works now… thank’s a lot for your help…your a hero.
            please chack this with WunderGround it would be really nice…
            THANKS A LOT!
            • A
              Albert2002
              I’ve pulled the latest update today. Since this i don’t see the temperature / humidity any more. I don’t have any errors in my logs depending MMM-xiaomi. The config.js is the same as well. Browser debug without errors. The only error which is new in my log is about the module nerwork scanner.
              By the way: Do I add the window sensors the same way as the Temperature sensor? Which lights are supported?
              empty
              mm error:
              TypeError: Cannot read property 'network' of undefined
                  at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                  at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                  at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:11)
                  at emitTwo (events.js:106:13)
                  at Socket.emit (events.js:194:7)
                  at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:514:12
                  at _combinedTickCallback (internal/process/next_tick.js:73:7)
                  at process._tickCallback (internal/process/next_tick.js:104:9)
              mm out:
              > magicmirror@2.1.3 start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.1.3
              Loading config ...
              Loading module helpers ...
              Module helper loaded: MMM-Remote-Control
              Module helper loaded: MMM-DWD-WarnWeather
              Module helper loaded: MMM-PNews
              Module helper loaded: internet-monitor
              Module helper loaded: MMM-MovieListings
              Module helper loaded: MMM-Fuel
              Module helper loaded: MMM-NetworkScanner
              Module helper loaded: MMM-nasaastropic
              Module helper loaded: MMM-SystemStats
              No helper found for module: MMM-Carousel.
              Module helper loaded: MMM-Events
              Module helper loaded: MMM-xiaomi
              All module helpers loaded.
              You're using a full whitelist configuration to allow for all IPs
              Server started ...
              Connecting socket for: MMM-Remote-Control
              Starting node helper for: MMM-Remote-Control
              Connecting socket for: MMM-DWD-WarnWeather
              MMM-DWD-WarnWeather helper started...
              Connecting socket for: MMM-PNews
              Starting module: MMM-PNews
              Starting module: newsfeed
              Connecting socket for: internet-monitor
              internet-monitor helper started ...
              Connecting socket for: MMM-MovieListings
              MMM-MovieListing helper started...
              Connecting socket for: MMM-Fuel
              Starting module helper: MMM-Fuel
              Connecting socket for: MMM-NetworkScanner
              Starting module: MMM-NetworkScanner
              Connecting socket for: MMM-nasaastropic
              Starting node helper: MMM-nasaastropic
              Connecting socket for: MMM-SystemStats
              Connecting socket for: MMM-Events
              Starting node_helper for: MMM-Events
              Connecting socket for: MMM-xiaomi
              Starting xiaomi helper
              Launching application.
              MMM-NetworkScanner received SCAN_NETWORK
              MMM-NetworkScanner is performing arp-scan
              Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/basic.ics - Interval: 300000
              Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
              Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
              starting internet monitor node helper
              MMM-NetworkScanner received CONFIG
              astro helper: config received
              retrieveAndUpdate()
              Sat Nov 18 2017 10:10:53 GMT+0100 (CET): Triggering Xiaomi Gateway connect
              NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/20171117dawnTezel1200c.jpg
              Found device with ID 158d000119fcb2 of type magnet
              Found device with ID 158d00015aa973 of type controller
              Found device with ID 158d00015736a8 of type sensor
              M 1 Reply Last reply
                mirko3000 @Albert2002
                Can you post your configuration for the module? You now need to define your rooms, it looks like the module simply does not find any room to show.
                And yes, you add all devices to your room configuration, the module can identify the type and handle it correspondingly.
                BTW: suggest tracking issues on the github issue tracker: https://github.com/mirko3000/MMM-xiaomi/issues
                • A
                  Albert2002
                  Am sorry, it was my mistake. I did not checked my config.js. Out of nowhere there was again
                  devices:
                  instead of
                  rooms:
                  Thank you for your help!
                  I’ve tried to get the icon for the open state of the window sensors working this way:
                  The first ID is the temperature sensor, the second one the window sensors:
                  		header: 'Temperatur / Feuchtigkeit',  // This is optional
                  			gatewayIP: '192.168.2.160',
                  			gatewayToken: '6ebf9b84e5c615c09268166a99b95f0a',
                  			showWindow: true,
                  			rooms: [
                  			{ name: 'Wohnzimmer', sortOrder: 30, devices : ['158d00015736a8', '158d000119fcb2'] },
                  and this way:
                  			rooms: [
                  			{ name: 'Wohnzimmer', sortOrder: 30, showWindow: true, devices : ['158d00015736a8', '158d000119fcb2'] },
                  Both times MM did not started because of errors in the config. How is the right way to get this solved?
                    Your first config is correct, I guess you might have made an error somewhere else in your config, I could run your config successfully.
                    • A
                      Albert2002
                      Hmm… I must have had a typo somewhere. Now the config is working for me as well but still no icon.
                      this is how it works so far:
                      			showWindow: true,
                      			rooms: [
                      This is what I get:
                      alt text
                      mm out:
                      > sh run-start.sh
                      Loading config ...
                      Server started ...
                      retrieveAndUpdate()
                      Sat Nov 18 2017 15:55:41 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                      No errors in the log
                        Note that the icon only appears on open windows - its a white star. If the window is closed you will not see any icon. Also I have noticed that the open state is not really reliable, need to check with miio why there are so many false states sent.
                        A 1 Reply Last reply
                        • A
                          Albert2002 @mirko3000
                          @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                          That was the point that i’ve missed! when I open the window, the white star appears impatiently! I love this module! Thank you for your work!
                            Don’t forget to update the npm packages (miio), there is a bugfix which caused wrong close events of the windows. Either ‘npm update’ in the MMM-xiaomi folder, or delete the “node_modules” folder and simply execute ‘npm install’ again.
                            • A
                              Albert2002
                              Now I did so. Thank you for the hint!
                              • A
                                Albert2002
                                My new sensors are arrived… I love it! Great work!
                                alt text
                                  mirko3000
                                  Check your devices here:
                                  https://github.com/aholstenson/miio/blob/master/docs/devices/README.md#models-by-name
                                  As you see not all Yeelights are supported, others are untested. My module retrieves all devices of type ‘light’, so it might work for all of them.
                                    barnosch
                                    hi,
                                    finally my gateway arrived today. Great. it is working after a little struggeling to get the correct App to initally configure the stuff.
                                    I added 4 temp/humidity sensors and i am wondering how to see in the miio discovery whick one is in which room?
                                    Any chance to get that ?
                                    I the app itself i sadly can’t see the IDs of the sensors?
                                    How did you figured this out?
                                    • A
                                      Albert2002
                                      I’ve added them one by one. Remove them all and add them one by one. Or add all of them to the module. Then its easy to discover if you keep one of them somewhere cold, all the other warm. The Id and the temperature will guide you.
                                      • T
                                        trividar
                                        Hi, if i set in the custom css file mmm-xiaomi .xsmall and the text-align: right then the humidity and temerature are going on the right side but the “>” stay. How can I move also “>” to right?
                                        @barnosch I have done it like @Albert2002 described.
                                        THX
                                          barnosch
                                          @trividar
                                          they are not belonging to the same TD so it is not moving aswell.
                                          is it the trending, or what is it good for? i don’t really like it to be honest.
                                          For me it was too close also, i just added some nbsp; to get some spaces between.
                                          thanks for the hints.
                                          i added all the ids and checked in the app, which room is showing the current values and added it to the correct rooms i created in the config.
                                            mirko3000
                                            Yes the identification of the sensors is not really good, did not find a better solution so far.
                                            As for the trend indicators: I pushed a new version where you can disable the trend icons (showTrend: false).
                                            • 4 / 8
