    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 239.3k Views 28 Watching
    • T
      trividar
      could someone help me? I installed it how described but it didn’t show any informations on the MM just temperature/humidity. At the beginning i see connecting to xiaomi getway and after that nothing. In the MM out i get this:
      Found device with ID 158.... of type sensor
      but no errors.
      Once I saw this, but just once (but nothing on the mirror):
        mirko3000 @trividar
        So technically your gateway and sensors seem to be working properly. What exactly is the problem? Did you configure your rooms and devices as described? Do you see anything on the MM? “just temperature/humidity” - that is actually the main feature :)
        • T
          trividar
          Hi mirko,
          the problem is, that i did’t see any values on the MM:
          and also something strange, if i start this module my WunderGround module change the top of it:
          if I disable this module it looks like usual, i changed in other positions but the same things.
          Why is this happen?
          What you mean with: “Did you configure your rooms and devices as described?” I did exactly what was on github.
          THX a lot for your help
            mirko3000 @trividar
            Can you post the configuration for the Xiaomi module? You need to provide a list of rooms, each of one with the assigned device IDs:
            	            rooms:  [
            		            	sortOrder: 40,
            		            	devices : ['158d010171840d', '158d00016cddae']
            		            	sortOrder: 70,
            		            	devices : ['158d0001735ac2']
            Also please check that you use the latest version.
            About that WunderGround module: I need to test that myself, not sure why there are such kind of interferences.
            • T
              trividar
              I have the latest version and thats my config:
              		module: 'MMM-xiaomi',
              		position: 'bottom_left',
              		header: 'Temperature / Humidity',  // This is optional
              			interval: 30,
              			gatewayIP: '192.168.1.128',
              			gatewayToken: '65764848557cccc2170d1fd8c06b32cb',
              			devices: [{
                mirko3000
                That is the config for the old version. Please check the README carefully:
                https://github.com/mirko3000/MMM-xiaomi#configuration-options
                			interval: 30,
                			rooms: [{
                			       name: 'Schlafzimmer temp' ,
                                               devices:[ '158d0001dfdb14'],
                                               sortOrder: 1
                • T
                  trividar
                  oooo shit…my mistake! It works now… thank’s a lot for your help…your a hero.
                  please chack this with WunderGround it would be really nice…
                  THANKS A LOT!
                  • A
                    Albert2002
                    I’ve pulled the latest update today. Since this i don’t see the temperature / humidity any more. I don’t have any errors in my logs depending MMM-xiaomi. The config.js is the same as well. Browser debug without errors. The only error which is new in my log is about the module nerwork scanner.
                    By the way: Do I add the window sensors the same way as the Temperature sensor? Which lights are supported?
                    empty
                    mm error:
                    TypeError: Cannot read property 'network' of undefined
                        at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                        at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                        at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:11)
                        at emitTwo (events.js:106:13)
                        at Socket.emit (events.js:194:7)
                        at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:514:12
                        at _combinedTickCallback (internal/process/next_tick.js:73:7)
                        at process._tickCallback (internal/process/next_tick.js:104:9)
                    mm out:
                    > magicmirror@2.1.3 start /home/pi/MagicMirror
                    > sh run-start.sh
                    Starting MagicMirror: v2.1.3
                    Loading config ...
                    Loading module helpers ...
                    Module helper loaded: MMM-Remote-Control
                    Module helper loaded: MMM-DWD-WarnWeather
                    Module helper loaded: MMM-PNews
                    Module helper loaded: internet-monitor
                    Module helper loaded: MMM-MovieListings
                    Module helper loaded: MMM-Fuel
                    Module helper loaded: MMM-NetworkScanner
                    Module helper loaded: MMM-nasaastropic
                    Module helper loaded: MMM-SystemStats
                    No helper found for module: MMM-Carousel.
                    Module helper loaded: MMM-Events
                    Module helper loaded: MMM-xiaomi
                    All module helpers loaded.
                    You're using a full whitelist configuration to allow for all IPs
                    Server started ...
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: MMM-DWD-WarnWeather
                    MMM-DWD-WarnWeather helper started...
                    Connecting socket for: MMM-PNews
                    Starting module: MMM-PNews
                    Starting module: newsfeed
                    Connecting socket for: internet-monitor
                    internet-monitor helper started ...
                    Connecting socket for: MMM-MovieListings
                    MMM-MovieListing helper started...
                    Connecting socket for: MMM-Fuel
                    Starting module helper: MMM-Fuel
                    Connecting socket for: MMM-NetworkScanner
                    Starting module: MMM-NetworkScanner
                    Connecting socket for: MMM-nasaastropic
                    Starting node helper: MMM-nasaastropic
                    Connecting socket for: MMM-SystemStats
                    Connecting socket for: MMM-Events
                    Starting node_helper for: MMM-Events
                    Connecting socket for: MMM-xiaomi
                    Starting xiaomi helper
                    Launching application.
                    MMM-NetworkScanner received SCAN_NETWORK
                    MMM-NetworkScanner is performing arp-scan
                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/basic.ics - Interval: 300000
                    Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
                    Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
                    starting internet monitor node helper
                    MMM-NetworkScanner received CONFIG
                    astro helper: config received
                    retrieveAndUpdate()
                    Sat Nov 18 2017 10:10:53 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                    NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/20171117dawnTezel1200c.jpg
                    Found device with ID 158d000119fcb2 of type magnet
                    Found device with ID 158d00015aa973 of type controller
                    Found device with ID 158d00015736a8 of type sensor
                      mirko3000 @Albert2002
                      Can you post your configuration for the module? You now need to define your rooms, it looks like the module simply does not find any room to show.
                      And yes, you add all devices to your room configuration, the module can identify the type and handle it correspondingly.
                      BTW: suggest tracking issues on the github issue tracker: https://github.com/mirko3000/MMM-xiaomi/issues
                      • A
                        Albert2002
                        Am sorry, it was my mistake. I did not checked my config.js. Out of nowhere there was again
                        devices:
                        instead of
                        rooms:
                        Thank you for your help!
                        I’ve tried to get the icon for the open state of the window sensors working this way:
                        The first ID is the temperature sensor, the second one the window sensors:
                        		header: 'Temperatur / Feuchtigkeit',  // This is optional
                        			gatewayIP: '192.168.2.160',
                        			gatewayToken: '6ebf9b84e5c615c09268166a99b95f0a',
                        			showWindow: true,
                        			rooms: [
                        			{ name: 'Wohnzimmer', sortOrder: 30, devices : ['158d00015736a8', '158d000119fcb2'] },
                        and this way:
                        			rooms: [
                        			{ name: 'Wohnzimmer', sortOrder: 30, showWindow: true, devices : ['158d00015736a8', '158d000119fcb2'] },
                        Both times MM did not started because of errors in the config. How is the right way to get this solved?
                          Your first config is correct, I guess you might have made an error somewhere else in your config, I could run your config successfully.
                          • A
                            Albert2002
                            Hmm… I must have had a typo somewhere. Now the config is working for me as well but still no icon.
                            this is how it works so far:
                            			showWindow: true,
                            			rooms: [
                            This is what I get:
                            alt text
                            mm out:
                            > sh run-start.sh
                            Loading config ...
                            Server started ...
                            retrieveAndUpdate()
                            Sat Nov 18 2017 15:55:41 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                            No errors in the log
                              Note that the icon only appears on open windows - its a white star. If the window is closed you will not see any icon. Also I have noticed that the open state is not really reliable, need to check with miio why there are so many false states sent.
                              • A
                                Albert2002 @mirko3000
                                @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                                That was the point that i’ve missed! when I open the window, the white star appears impatiently! I love this module! Thank you for your work!
                                  Don’t forget to update the npm packages (miio), there is a bugfix which caused wrong close events of the windows. Either ‘npm update’ in the MMM-xiaomi folder, or delete the “node_modules” folder and simply execute ‘npm install’ again.
                                  • A
                                    Albert2002
                                    Now I did so. Thank you for the hint!
                                    • A
                                      Albert2002
                                      My new sensors are arrived… I love it! Great work!
                                      alt text
                                        mirko3000
                                        Check your devices here:
                                        https://github.com/aholstenson/miio/blob/master/docs/devices/README.md#models-by-name
                                        As you see not all Yeelights are supported, others are untested. My module retrieves all devices of type ‘light’, so it might work for all of them.
                                          barnosch
                                          hi,
                                          finally my gateway arrived today. Great. it is working after a little struggeling to get the correct App to initally configure the stuff.
                                          I added 4 temp/humidity sensors and i am wondering how to see in the miio discovery whick one is in which room?
                                          Any chance to get that ?
                                          I the app itself i sadly can’t see the IDs of the sensors?
                                          How did you figured this out?
                                          • A
                                            Albert2002
                                            I’ve added them one by one. Remove them all and add them one by one. Or add all of them to the module. Then its easy to discover if you keep one of them somewhere cold, all the other warm. The Id and the temperature will guide you.
                                            • 3 / 8
