    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 239.3k Views 28 Watching
      mirko3000
      That is the config for the old version. Please check the README carefully:
      https://github.com/mirko3000/MMM-xiaomi#configuration-options
      		module: 'MMM-xiaomi',
      		position: 'bottom_left',
      		header: 'Temperature / Humidity',  // This is optional
      			interval: 30,
      			gatewayIP: '192.168.1.128',
      			gatewayToken: '65764848557cccc2170d1fd8c06b32cb',
      			rooms: [{
      			       name: 'Schlafzimmer temp' ,
                                     devices:[ '158d0001dfdb14'],
                                     sortOrder: 1
      • T
        trividar
        oooo shit…my mistake! It works now… thank’s a lot for your help…your a hero.
        please chack this with WunderGround it would be really nice…
        THANKS A LOT!
        • A
          Albert2002
          I’ve pulled the latest update today. Since this i don’t see the temperature / humidity any more. I don’t have any errors in my logs depending MMM-xiaomi. The config.js is the same as well. Browser debug without errors. The only error which is new in my log is about the module nerwork scanner.
          By the way: Do I add the window sensors the same way as the Temperature sensor? Which lights are supported?
          empty
          mm error:
          TypeError: Cannot read property 'network' of undefined
              at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
              at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:11)
              at emitTwo (events.js:106:13)
              at Socket.emit (events.js:194:7)
              at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:514:12
              at _combinedTickCallback (internal/process/next_tick.js:73:7)
              at process._tickCallback (internal/process/next_tick.js:104:9)
          mm out:
          > magicmirror@2.1.3 start /home/pi/MagicMirror
          > sh run-start.sh
          Starting MagicMirror: v2.1.3
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-Remote-Control
          Module helper loaded: MMM-DWD-WarnWeather
          Module helper loaded: MMM-PNews
          Module helper loaded: internet-monitor
          Module helper loaded: MMM-MovieListings
          Module helper loaded: MMM-Fuel
          Module helper loaded: MMM-NetworkScanner
          Module helper loaded: MMM-nasaastropic
          Module helper loaded: MMM-SystemStats
          No helper found for module: MMM-Carousel.
          Module helper loaded: MMM-Events
          Module helper loaded: MMM-xiaomi
          All module helpers loaded.
          You're using a full whitelist configuration to allow for all IPs
          Server started ...
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-DWD-WarnWeather
          MMM-DWD-WarnWeather helper started...
          Connecting socket for: MMM-PNews
          Starting module: MMM-PNews
          Starting module: newsfeed
          Connecting socket for: internet-monitor
          internet-monitor helper started ...
          Connecting socket for: MMM-MovieListings
          MMM-MovieListing helper started...
          Connecting socket for: MMM-Fuel
          Starting module helper: MMM-Fuel
          Connecting socket for: MMM-NetworkScanner
          Starting module: MMM-NetworkScanner
          Connecting socket for: MMM-nasaastropic
          Starting node helper: MMM-nasaastropic
          Connecting socket for: MMM-SystemStats
          Connecting socket for: MMM-Events
          Starting node_helper for: MMM-Events
          Connecting socket for: MMM-xiaomi
          Starting xiaomi helper
          Launching application.
          MMM-NetworkScanner received SCAN_NETWORK
          MMM-NetworkScanner is performing arp-scan
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/basic.ics - Interval: 300000
          Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
          Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
          starting internet monitor node helper
          MMM-NetworkScanner received CONFIG
          astro helper: config received
          retrieveAndUpdate()
          Sat Nov 18 2017 10:10:53 GMT+0100 (CET): Triggering Xiaomi Gateway connect
          NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/20171117dawnTezel1200c.jpg
          Found device with ID 158d000119fcb2 of type magnet
          Found device with ID 158d00015aa973 of type controller
          Found device with ID 158d00015736a8 of type sensor
          M 1 Reply Last reply
            mirko3000 @Albert2002
            Can you post your configuration for the module? You now need to define your rooms, it looks like the module simply does not find any room to show.
            And yes, you add all devices to your room configuration, the module can identify the type and handle it correspondingly.
            BTW: suggest tracking issues on the github issue tracker: https://github.com/mirko3000/MMM-xiaomi/issues
            • A
              Albert2002
              Am sorry, it was my mistake. I did not checked my config.js. Out of nowhere there was again
              devices:
              instead of
              rooms:
              Thank you for your help!
              I’ve tried to get the icon for the open state of the window sensors working this way:
              The first ID is the temperature sensor, the second one the window sensors:
              		header: 'Temperatur / Feuchtigkeit',  // This is optional
              			gatewayIP: '192.168.2.160',
              			gatewayToken: '6ebf9b84e5c615c09268166a99b95f0a',
              			showWindow: true,
              			rooms: [
              			{ name: 'Wohnzimmer', sortOrder: 30, devices : ['158d00015736a8', '158d000119fcb2'] },
              and this way:
              			rooms: [
              			{ name: 'Wohnzimmer', sortOrder: 30, showWindow: true, devices : ['158d00015736a8', '158d000119fcb2'] },
              Both times MM did not started because of errors in the config. How is the right way to get this solved?
                Your first config is correct, I guess you might have made an error somewhere else in your config, I could run your config successfully.
                • A
                  Albert2002
                  Hmm… I must have had a typo somewhere. Now the config is working for me as well but still no icon.
                  this is how it works so far:
                  			showWindow: true,
                  			rooms: [
                  This is what I get:
                  alt text
                  mm out:
                  > sh run-start.sh
                  Loading config ...
                  Server started ...
                  retrieveAndUpdate()
                  Sat Nov 18 2017 15:55:41 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                  No errors in the log
                    Note that the icon only appears on open windows - its a white star. If the window is closed you will not see any icon. Also I have noticed that the open state is not really reliable, need to check with miio why there are so many false states sent.
                    A 1 Reply Last reply
                    • A
                      Albert2002 @mirko3000
                      @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                      That was the point that i’ve missed! when I open the window, the white star appears impatiently! I love this module! Thank you for your work!
                        Don’t forget to update the npm packages (miio), there is a bugfix which caused wrong close events of the windows. Either ‘npm update’ in the MMM-xiaomi folder, or delete the “node_modules” folder and simply execute ‘npm install’ again.
                        • A
                          Albert2002
                          Now I did so. Thank you for the hint!
                          • A
                            Albert2002
                            My new sensors are arrived… I love it! Great work!
                            alt text
                              mirko3000
                              Check your devices here:
                              https://github.com/aholstenson/miio/blob/master/docs/devices/README.md#models-by-name
                              As you see not all Yeelights are supported, others are untested. My module retrieves all devices of type ‘light’, so it might work for all of them.
                                barnosch
                                hi,
                                finally my gateway arrived today. Great. it is working after a little struggeling to get the correct App to initally configure the stuff.
                                I added 4 temp/humidity sensors and i am wondering how to see in the miio discovery whick one is in which room?
                                Any chance to get that ?
                                I the app itself i sadly can’t see the IDs of the sensors?
                                How did you figured this out?
                                • A
                                  Albert2002
                                  I’ve added them one by one. Remove them all and add them one by one. Or add all of them to the module. Then its easy to discover if you keep one of them somewhere cold, all the other warm. The Id and the temperature will guide you.
                                  • T
                                    trividar
                                    Hi, if i set in the custom css file mmm-xiaomi .xsmall and the text-align: right then the humidity and temerature are going on the right side but the “>” stay. How can I move also “>” to right?
                                    @barnosch I have done it like @Albert2002 described.
                                    THX
                                      barnosch
                                      @trividar
                                      they are not belonging to the same TD so it is not moving aswell.
                                      is it the trending, or what is it good for? i don’t really like it to be honest.
                                      For me it was too close also, i just added some nbsp; to get some spaces between.
                                      thanks for the hints.
                                      i added all the ids and checked in the app, which room is showing the current values and added it to the correct rooms i created in the config.
                                        mirko3000
                                        Yes the identification of the sensors is not really good, did not find a better solution so far.
                                        As for the trend indicators: I pushed a new version where you can disable the trend icons (showTrend: false).
                                        • A
                                          Albert2002
                                          Just want to say that there is no different between the Xiaomi and Aqara Temperature sensor. Both are working like a charm. The only different is that the Aqara shows the Air pressure (in the MiHome app) as well.
                                          @Mirko3000 Thank you for your hard work! You are always improving the module in light-speed!
                                          I was playing around with my Yeelights colorbulbs but I didn’t get it working on MM. Guessing its because of they have they own ID, IP and token. However, thats why am still using the app. :-)
                                            mirko3000
                                            Did you try with the ‘miio --discover’ command line utility? Do the lights show up there?
                                            • 4 / 8
