    MMM-MyScoreboard
    277 Posts 60 Posters 559.4k Views 63 Watching
      sanj926 @j.e.f.f
      @j.e.f.f
      Excellent! Love the support for college football groups. Now if only there was a way you could use the top 25 of the conference as a group. The group would continually change, but if only it could be automatic and update off of an ESPN RSS feed or something.
        j.e.f.f Project Sponsor Module Developer @sanj926
        @sanj926 Yeah I’ll look into seeing how feasible this is to do.
          @sanj926 Top 25 now works! Turns out the ranking was in in the feed all along. So if you specify "Top 25" in your groups array for either NCAAF or NCAAM, the games list will filter on teams in the top 25 rankings.
          v2.1.1 released!
          • P-Bo726P Offline
            P-Bo726
            Great work. Thanks again for your hard work and dedication to this module. I hope you enjoy working on it as much as we enjoy using it.
              j.e.f.f Project Sponsor Module Developer @P-Bo726
              @P-Bo726 Thanks! I certainly did enjoy it. I learned a lot!
                sanj926 @j.e.f.f
                @j.e.f.f
                Does the NCAAM not support displaying the teams involved in the NCAA March madness bracket challenge?
                J 3 Replies Last reply Reply Quote 0
                  @sanj926 to be honest I’m not sure. I just assumed that it would be the case as part of the feed I’m using.
                  I’m guessing from your note this is not the case… I’ll see if there’s something I can do to retrieve it.
                    @sanj926 It looks like ESPN groups March Madness differently than . The way my provider system is set up, I can only query for one group at a time. I’ll need to set up March Madness as if it were it’s own league. Stay tuned…
                      @sanj926 OK. Support for March Madness has been added. You configure it as if it were a separate league. I’ve also added a label parameter you can specify to change the name that is displayed in the league separator (if you’re using it). That way you could have it display something like “March Madness” instead of “NCAAM_MM”
                      Example:
                        module: "MMM-MyScoreboard",
                        classes: "default everyone",
                        header: "My Scoreboard",
                          showLeagueSeparators: true,
                          colored: true,
                          viewStyle: "mediumLogos",
                          sports: [
                              league: "NCAAM"    //Division I
                              league: "NCAAM_MM",    //March Madness
                              label: "March Madness"
                      It’s kind of a hacky solution… I would have preferred to treat March Madness as if it were a subgroup, much like specifying a division, but I don’t think it’s possible to retrieve Division I and March Madness in the same API call. It will take a bit of rearchitecting my provider system to allow multiple calls for a single league. This will have to do for now.
                      • F Offline
                        fabbr
                        @j.e.f.f Your module is great! I have been testing it to try to make some changes and notice that the JSON
                        https://www.sportsnet.ca/wp-content/uploads/scoreboard.json
                        doesn’t seem to be updating. I checked the dates and they are wrong. Is that a mistake of mine?
                        I was trying to make it work with Premier League games :)
                        • 10
                        • 11
                        • 27
                        • 28
                        • 9 / 28
