    MMM-Admin-Interface
    29 Posts 12 Posters 36.3k Views 12 Watching
      broberg Project Sponsor @shashank
      @shashank there is one already, mmm-navbar
      • I
        ItayXD
        @shashank thank you. there is a great module called MMM-Remote-Control that does just that. I believe there is a module request forum, if you have any other requests
        • W
          wrumble
          @ItayXD thanks for your help! I have the mirror running now but when i try to access the interface i get Cannot GET /MMM-Admin-Interface/ when i go to http://192.168.0.13:8080/MMM-Admin-Interface/ i have MMM-Remote-Control and when i access http://192.168.0.13:8080/remote.html it woks fine, any ideas why its not working? i dont get any errors in terminal
          • I
            ItayXD
            @wrumble
            can you post your config.js? you can send a link to pastebin. can you also run git status in the module directory and post the output?
            it might also be useful if you post the output in the terminal when you start the MM (npm start).
            • W
              wrumble
              im an idiot, it was still commented out in the config.js thanks for your help, it works great!
                shashank @broberg
                @broberg Thanks for suggesting the Nav bar, i installed the module working great
                • L
                  lolobyte
                  Hello, i made the MM2 update and now i can’t access the admin
                  I can’t insert my ip from my laptop.
                  I want to access MagicMirror from laptop with Admin-Interface, but it’s not possible now with this update.
                  Where i have to insert my ip address in the white-list?
                  How to insert a range?
                  • I
                    ItayXD
                    Hi try putting your laptop’s up it the whitelist, it should probably by 192.168.X.X
                      mochman Module Developer
                      You might also have to add "::ffff:192.168.X.Y" as well. You could also just add "192.168.X.1/24 , ::ffff:192.168.X.1/24" to whitelist all of the IPs in your network (assuming you are using 192.168.X.1-254).
                        rubenlaureys
                        I love your module!
                        I use it to modify my MagicMirror.
                        But, is there a way to choose a module from a list, instead of entering the name myself?
                        I want a dropdown list, just like the list of positions.
                        Is this possible?
                        Thank you.
                        Have a great day,
                        Ruben
                        • I
                          ItayXD @rubenlaureys
                          @rubenlaureys
                          I’m not sure what you mean, there should be a tab list with the modules names on the left like in this photo:
                          is this not the case?
                            shimue
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @shimue
                              @shimue search for ip whitelist on the forum, there plenty of threads
                                shimue
                                1 Reply Last reply Reply Quote -3
                                • Sandy2503S
                                  Sandy2503
                                  @shimue - na dann hast DU das hier ja auch in deiner config.js stehen:
                                  address:"0.0.0.0",
                                  und achte mal auf deinen Ton …
                                  Sandy2503
                                    rockcitiman
                                    Are you still developing this module? I followed all of the instructions but I get nothing.
                                    • A
                                      Arkitct @rockcitiman
                                      @rockcitiman I had to modify the address: line above the ipWhitelist: entry as @Sandy2503 alluded. My line became:
                                      address: ["localhost", "0.0.0.0"],
                                      the localhost may be redundant with the 0.0.0.0, but it works nonetheless (the interface). But … the writing of the config file is in a format that bunged up my mm so it fails to display anything.
