Run module
Good evening,
do you know if there is a module running a command that runs an external program?
I use the Carousel module and I would like to be able to insert a command in some slides that does something.Thank you, Alberto
I’m looking for someway to run a script. Did you have any luck
@dasbooter
No :( -
Did you manage to solve this somehow? I’m trying to run a Linux command or script from inside a module.
@autonomus you can do that in the node_helper, it’s also already done by some modules
@strawberry-3.141 Thanks for the quick reply!
