    Run module
    6 Posts 4 Posters 2.8k Views 4 Watching
      alverman
      Good evening,
      do you know if there is a module running a command that runs an external program?
      I use the Carousel module and I would like to be able to insert a command in some slides that does something.
      Thank you, Alberto
      dasbooterD 1 Reply Last reply Reply Quote 0
      • dasbooterD Offline
        dasbooter @alverman
        @alverman
        I’m looking for someway to run a script. Did you have any luck
          alverman @dasbooter
          @dasbooter
          No :(
            autonomus
            Did you manage to solve this somehow? I’m trying to run a Linux command or script from inside a module.
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @autonomus
              @autonomus you can do that in the node_helper, it’s also already done by some modules
              e.g. https://nodejs.org/dist/latest-v8.x/docs/api/child_process.html#child_process_child_process_exec_command_options_callback
                autonomus @strawberry 3.141
                @strawberry-3.141 Thanks for the quick reply!
