Don't know what to do next...
So I’ve successfully gotten Raspbian installed on my pi. I got the Magic Mirror to successfully auto-open at login. I cannot figure out how to get to and edit the config.js file on my pi, or through ssh’ing via terminal (I’m on a Mac).
I’d like to remove the compliments and newsfeed, (I get really annoyed with NYT) and add a couple modules of my own as well as making the 24-hr clock a 12-hour clock. I feel like once I’m able to view the config.js file everything will fall into place lol.
I don’t know if I need to figure out how to ‘quit’ the MM application or if I should edit it through terminal.
Just need some clarification! Thanks in advance! -
This will get you to the config file. Then you can edit at your leisure.
https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
You can quit MM by pressing your
Altkey. Menu bar at the top will drop down. Far left menu has Exit in it. This brings you to your desktop.If you’ve installed PM2, you’ll have to minimize MM (from the menu bar mentioned above) and run
pm2 stop mmin your terminal so it doesn’t relaunch MM -
Thank you so much! I’ll try this out!
