    remoteFile in compliments module
    71 Posts 14 Posters 109.9k Views 15 Watching
      jm @roramirez
      @roramirez I meant this comment:
      “As an aside, I’ve noticed that the weather integration technique continually adds to the arrays. So the memory usage will grow and grow at whatever frequency you set the compliment refresh. This isn’t terrible, as straight text doesn’t take a whole lot of memory. But it may have unintended effects”
      I don’t know whether to call this a bug, but you get my point ;) I’m not an experienced coder whatsoever, so I doubt I might be of help, but I am always willing to test / assist.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @jm
        @jm I can’t see that this is still happening on the current code base. Every time it tries to update an array will be generated with all possible values, after that the garbage collector will do his job and delete the array after usage.
        • Z
          ZtM
          Here is how I got the remote file compliments to work:
          1. The config.js settings must name the remote file with no path:
          			module: 'compliments',
          			position: 'bottom_bar',
          				remoteFile: 'compliments.json'
          IMO it would be great if it were possible to put a full path the the remote file so it can be stored in the config directory.
          1. Create a compliments.json file and be sure to put double quotes around the array names like so:
          	"morning" : [
          		"You're good enough, you're smart enough and doggone it, people like you!"
          	"afternoon" : [
          		"Yes those jeans make you look fat."
          	"evening" : [
          		"Please put on some pants."
          1. Put the remote file (compliments.json) into the ~/MagicMirror/modules/default/compliments directory.
          2. Restart MM. It will show the default compliment (usually “Hi Sexy”) for the first interval and then will start showing compliments from the external file.
          Hope this helps
          Reply Quote 2
          • L
            Lahim
            Guys where can be mistake:
            config.js looks like:
            module: “compliments”,
            position: “lower_third”,
            remoteFile: “compliments.json”
            Remote file placed in ~/MagicMirror/modules/default/compliments
            but it still does not work.
            I made all following above written steps and nothing - still oryginal compliments are one the mirror.
            I have no idea what is wrong.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Lahim
              @Lahim
              Your config entry looks okay. However, the curly quotes I see will cause problems. There should not be any in your config.js or your compliments.json file. This is an acceptable quote " but this “ is not. You can post your compliments.json file here (in a code block) so we can take a look at it.
              L 1 Reply Last reply
              • L
                Lahim @Mykle1
                I have “ in oryginal file so I just copied it. I also tried with ' but without luck.
                The compliments.json file looks like:
                    "anytime" : [
                        "Dziala!"
                    "morning" : [
                        "Good morning, sunshine!",
                        "Who needs coffee when you have your smile?",
                        "Go get 'em, Tiger!"
                    "afternoon" : [
                        "dfadfafa",
                        "dffffffff",
                        "fsssss!"
                    "evening" : [
                        "2",
                        "1",
                        "3333"
                In compliments.js
                Module.register("compliments", {
                        // Module config defaults.
                        defaults: {
                                compliments: {
                                        anytime: [
                                                "Hey there sexy!"
                                        morning: [
                                                "Good morning, handsome!",
                                                "Enjoy your day!",
                                                "How was your sleep?"
                                        afternoon: [
                                                "Hello, beauty!",
                                                "You look sexy!",
                                                "Looking good today!"
                                        evening: [
                                                "Wow, you look hot!",
                                                "You look nice!",
                                                "Hi, sexy!"
                                updateInterval: 30000,
                                remoteFile: null,
                                fadeSpeed: 4000
                I see the “anytime” are without "
                so I also tried this in …json file but does not work.
                • Mykle1M
                  @Lahim said in remoteFile in compliments module:
                  So, I copied your example compliments.json file from above and tested it. Here is my config.js entry:
                      disabled: false,
                      module: "compliments",
                      position: "lower_third",
                          fadeSpeed: 1000,
                          remoteFile: "compliments.json", // this file is in the compliments module folder
                  And this was the result:
                  So, as long as you haven’t changed anything else and your config entry is correct, and your compliments.json file is name correctly and in the compliments module folder, it should work, as it does here
                  • L
                    Lahim @Mykle1
                    Thank you for trying and helping but I copied your setup but still the same thing.
                    Does compliments.json file has to be somehow written as json file? Or I can create new text file in nano and save it as compliments.json file? Does it need any special rights?
                    Can you attach your .json file here so I can download and place it in the /compliments/ folder?
                    Here is list of my files in compliments folder
                    • Mykle1M
                      Uhh, it MUST be saved as a .json file. It’s in the README file of compliments module.
                      QUOTE:
                      “This file must be straight JSON. Note that the array names need quotes around them (“morning”, “afternoon”, “evening”, “snow”, “rain”, etc.).”
                      I don’t use nano if I don’t have to. I use notepad++. You don’t need the terminal to use it and it saves files in just about every file format imaginable, including JSON.
                      I will post my file in a moment
                      • Mykle1M
                        You MUST save this as a json file.
                            "anytime" : [
                        		"You look like I need a drink!",
                        		"Did Pop create the Matrix?",
                        		"Why are you looking at yourself?",
                        		"That gut must be embarrassing!",
                        		"There's a zit on your forehead!",
                                "You're fugging ugly!"
                            "morning" : [
                                "Good morning, Pop!",
                        		"How's that dream job?",
                        		"You look like shit!",
                        		"Enjoy your day!",
                        		"Don't work too hard!"
                            "afternoon" : [
                                "When my Bottle Pop?",
                        		"Move your fat ass today!",
                        		"Take a nap!",
                        		"Cowboysdude is a GURU!",
                        		"Is the pool open yet?",
                        		"You are not appreciated!",
                        		"You need a shave!"
                            "evening" : [
                                "Strawberry 3.141 Rocks!",
                        		"What the hell are you?",
                        		"You're one ugly mother fucker!",
                        		"Pop is a fucking genius!",
                        		"You look fat in that dress!",
                        		"Did someone mention SEX?"
                        • Mykle1M
                          compliments.js_original
                          So, you did change something in the module file? That is not recommended and it makes it very difficult for me or anyone else to troubleshoot for you
                          • L
                            Lahim
                            I tried to change
                            remoteFile: null,
                            for remoteFile: ‘compliments.json’ previously but, as you know, did not help.
                            Now I came back to the oryginal file, saved your compliments as json file in Notepad++ as you wrote, and…
                            IT IS WORKING!!!
                            Thank you so much!!!
                            F…ck, so many time I spent tring different solutions and finaly it works.
                            One more time thank you for attention and help!
                            The module - great job!!
                            • L
                              Lahim
                              Ok, I found where was the problem and where is the problem now.
                              Because I am using Pi0 with Midori, with oryginal file the compliments were not show on the mirror but I was able to see them thru LAN.
                              So I found the solution to change:
                              if (this.config.remoteFile != null) {
                                              this.complimentFile((response) => {
                                                      this.config.compliments = JSON.parse(response);
                              to:
                                                      function(response){
                              and yes, that make my compliments shown on mirror but in same time the text is only from compliments.js file.
                              So now, to see the compliments I have to copy own text to .js file :(
                              That is the problem.
                              • Mykle1M
                                IT IS WORKING!!!
                                Fantastic! You’re welcome. :-)
                                • L
                                  Lahim
                                  Will you be able to find the solution to the problem I described above?
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @Lahim
                                    @Lahim because you changed the context by removing the arrow function, to preserve the context you have to do something like:
                                      var self = this;
                                      this.complimentFile(function(response){
                                        self.config.compliments = JSON.parse(response);
                                    Reply Quote 3
                                    • L
                                      Lahim
                                      I found it in the meantime but now I tested it - yes, it works!!!
                                      Thank you!
                                      • Z
                                        zeal
                                        has anyone tried to get the compliments in an file on a external Server?
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @zeal
                                          @zeal
                                          I have not. By default, the compliments module looks for the compliments.json file in the compliments module folder. I suppose you could try using the path to the file on your server in your config entry
                                          remoteFile: "PATH_TO_FILE_ON_SERVER/comliments.json",
                                          Dunno if that will work though.
                                          • 4 / 4
