npm start doesn't work
I hope someone is able to help me. If i type npm start the following error message appears:
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.1.3 start /home/pi/MagicMirror > sh run-start.sh run-start.sh: 4: run-start.sh: electron: not found npm ERR! magicmirror@2.1.3 start: `sh run-start.sh` npm ERR! Exit status 127 npm ERR! npm ERR! Failed at the magicmirror@2.1.3 start script. npm ERR! This is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sh run-start.sh npm ERR! You can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! System Linux 4.4.34-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "start" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.21 npm ERR! code ELIFECYCLE npm WARN This failure might be due to the use of legacy binary "node" npm WARN For further explanations, please read /usr/share/doc/nodejs/README.Debian npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0 pi@raspberrypi:~/MagicMirror $ -
@Tschanz said in npm start doesn’t work:
npm ERR! npm -v 1.4.21You need to update your node which should also update your npm
I have tried :
$ sudo apt updateand
$ sudo apt install nodejsBut there is still the same error. I hope somebody can help me.:)
