    Unrecognized Config file
    14 Posts 5 Posters 9.5k Views 3 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @dejayou
      @dejayou i can find a couple of errors in your config
      module: 'alert',  // remove comma
      module: ‘wuforecast’, // you often used wrong single quotes
      module: ‘newsfeed’,
      position: ‘bottom_bar’,
      feeds: [{
      title: “New York Times”,
      url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
      showSourceTitle: true,
      showPublishDate: true
      }, ]  // remove comma
        dejayou
        Thanks Strawberry, I still seem to be having some issues and receiving the same error message even after I made these edits. Any chance you could take another quick look and see if anything here seems out of place?
        /* Magic Mirror Config Sample
        • MIT Licensed.
          var config = {
          port: 8080,
          language: ‘en’,
          timeFormat: 24,
          units: ‘metric’,
          modules: [{
          module: “alert”
          module: “wuforecast”,
          position: “top_right”, // This can be any of the regions.
          // Best results in left or right regions.
          // See ‘Configuration options’ for more information.
          appid: “5095830b868b90bcc31affdad4911325” //wunderground.com API key.
          module: “clock”,
          position: “top_left”
          module: “calendar”,
          header: “US Holidays”,
          position: “top_left”,
          calendars: [{
          symbol: 'calendar-check-o ',
          url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
          module: “compliments”,
          position: “lower_third”
          module: “currentweather”,
          locationID: “4614088”, //ID from bulk.openweather.org/sample/
          module: “weatherforecast”,
          header: “Weather Forecast”,
          module: “newsfeed”,
          position: “bottom_bar”,
          feeds: [{
        if (typeof module !== “undefined”) {
        module.exports = config;
        • strawberry 3.141S
          @dejayou you’re still using the wrong ones
              MIT Licensed.
              var config = {
              port: 8080,
              language: 'en',
              timeFormat: 24,
              units: 'metric',
              modules: [{
              module: 'alert'
              module: 'wuforecast',
              position: 'top_right', // This can be any of the regions.
              appid: '5095830b868b90bcc31affdad4911325' //wunderground.com API key.
              module: 'clock',
              position: 'top_left'
              module: 'calendar',
              header: 'US Holidays',
              position: 'top_left',
              calendars: [{
              module: 'compliments',
              position: 'lower_third'
              module: 'currentweather',
              locationID: '4614088', //ID from bulk.openweather.org/sample/
              module: 'weatherforecast',
              header: 'Weather Forecast',
              module: 'newsfeed',
              position: 'bottom_bar',
              feeds: [{
              title: 'New York Times',
              url: 'http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml'
          if (typeof module !== 'undefined') {
            dejayou
            That’s odd. In the actual source code I am using the double quotes, but then in your yellow block text readout is somehow reverts back to single quotes in those same instances. Is this a Javascript thing?
              dejayou @strawberry 3.141
              @strawberry-3.141 So i’ve gone back through on the Linux system and checked that OS system and sure enough, when copying and pasting from a PC (here) and to a Linux, or vice versa, these quote marks have a tendency to alter.
              At any rate, the code in the config file is now in a place where everything checks out ok in both the JSHint and JSLint tools, save for the last portion beneath the final line of demarcation where it reads not to edit the lines of code.
              Here the error reads:
              undeclared ‘module’.
              unexpected ‘typeof’. Use ‘===’ to compare directly with undefined.
              undeclared 'module"
              Is this why the config file ultimately won’t be recognized by my raspberry pi/magic mirror program?
              • K
                KirAsh4 Moderator
                Do not copy/paste from one OS to another, the language translations between them will be different, UTF-8, Windows, it’s all foobar. Edit the config file ON the rpi. You can use the command 'nano' for that, as in 'nano config.js'. Doing the copy/paste is why your ‘'’, ‘"’ and others get translated wrong.
                  dejayou
                  Thanks KirAsh4. I am assuming that you meant to open the actual Terminal and edit the config file directly from within that environment, which is what I did with still no luck.
                  At this point I really don’t know what else to do. I am going to try and essentially start over from the beginning and see if I have better luck.
                  • K
                    KirAsh4 Moderator
                    Yep, open Terminal and edit there, or use an SSH client remotely. The config is a bit finicky I discovered. Try not to change the layout too much, like for example, in your pastes above, I see this:
                    … in between modules. While I don’t think that would cause a problem, it also wouldn’t surprise me if that’s tripping up the parser. Keep them on separate lines:
                      dejayou
                      Hi KirAsh4 -
                      After walking back through this setup tutorial again (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/) I am happy to report that I am no longer getting the error message asking about setting up a config file. Instead I now arrive at a blank black screen, absent any copy or modules. Do you know what might be causing this to occur?
                      • K
                        KirAsh4 Moderator
                        Likely a bug recently discovered. Follow the instructions in the first post here to try the 'develop' branch:
                        https://forum.magicmirror.builders/topic/445/looking-for-beta-testers
                        • L
                          L_i_v_e
