    MMM-Globe
    119 Posts 39 Posters 235.7k Views 40 Watching
      Peter @iMAGiC
      @iMAGiC , what do you mean with " full"?
      Is there a good link to the side of the earth with Europe?
      Peter
      iMAGiCI 1 Reply Last reply Reply Quote 0
      • iMAGiCI Offline
        iMAGiC @Peter
        @Peter
        sorry, I meaning use hi-res url instead of it.
        for example:
        this.imageUrls = {
        			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
        @Peter said in MMM-Globe:
        Peter
        Choice * Judgment * Values
        • dasbooterD Offline
          dasbooter @Peter
          @Peter I agree with the post about changing the link. I had the same problem then I changed sources and have had no issue.
            Peter @iMAGiC
            @iMAGiC , I used your link: MM starts, I see half of the globe and MM stops, starts again with half of the globe and stops again; like a loop.
            Maybe because I use a RPI 2?
            Peter
              Peter @dasbooter
              @dasbooter , what link do you use?
              peter
                Pimagical @Peter
                @Peter I fixed this problem with improving my wifi signal/range!
                Check your wifi signal quality if around 37/70 this will cause problems for sure, it should be at least above 45/70 or higher check your signal with:
                sudo iwconfig wlan0
                My bad wifi signal caused problems like not loading the globe images and freezing agenda items and not loading the newsfeed items.
                Solutions are
                1. Change the accespoint location or
                2. Buy a WIFI USB adapter to improve the wifi range because the Pi 3 default wifi/bluetooth is very bad: Pi 3 Wifi problems or
                3. DIY Modification option External antenna modifications for the Raspberry :Pi 3
                Good Luck!
                • iMAGiCI Offline
                  iMAGiC @Peter
                  @Peter do you set updateInterval correctly?
                  btw, I use Pi 3 with LAN.
                  only thing is loading time is longer, but OK.
                    Peter
                    Wifi signal is 49/70.
                    I use the original update interval.
                    Peter
                    • iMAGiCI Offline
                      iMAGiC @Peter
                      @Peter I think there is a problem, but not link I provided. may you check others, it shouldn’t cause MM stop or restart.
                        Peter
                        I rest my case.
                        I can’t get it working the way I want.
                        Thanks everybody for your help.
                        Peter
                        • FlatPepsiF Offline
                          FlatPepsi
                          For those seeking North American globe views, I have great news - GEOS-16 (aka GEOS-East) is now publishing live color (yes, COLOR) images!
                          See web site here:
                          https://www.star.nesdis.noaa.gov/GOES/GOES16_FullDisk.php
                          There are a few links for the latest image, depending on the resolution you want. (Watch out -many of the web site’s URLs are date and time specific) I’m using: https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/678x678.jpg
                          Until a proper GIT update is done on this module, you can edit your setup to get this new image. In the folder:
                          /home/pi/MagicMirror/modules/MMM-Globe
                          Edit the file: MMM-Globe.js
                          Find the lines with ‘centralAmericaDiscNat’: , and put the new URL in there. In my case, I used:
                          		'centralAmericaDiscNat': 'https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/678x678.jpg'
                          Do note that the code has 2 sections for different resolutions- you may need to update both.
                          Enjoy!
                            pugsly @FlatPepsi
                            @flatpepsi said in MMM-Globe:
                            centralAmericaDiscNat’: 'https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/678x678.jpg
                            I put the URL above for high res but since I only use 200px use this url for low res
                            https://cdn.star.nesdis.noaa.gov/GOES16/ABI/FD/GEOCOLOR/thumbnail.jpg
                              chris1971
                              MMM Globe - The Image Gallery has moved!
                              Hi has anybody solved the issues with the MMM Globe.
                              I am using MMM Globe, but the pictures/ jpgs are not longer available on the EUMETSAT server. Does anybody have a solution?
                              Thx, Chris
                              • StoffbeuteluweS Offline
                                Stoffbeuteluwe Project Sponsor @chris1971
                                @chris1971 try the link of the new path in…
                                ownpath: “link of new path“
                                in MMM-Globe config…
                                  chris1971
                                  … could you please explain more in detail…
                                  Thanks, Chris
                                    I’ll contact you later when I’m at home
                                      chris1971
                                      would be great!!!
                                        @chris1971
                                                    module: 'MMM-Globe',
                                                    position: 'middle_center',
                                                    style: 'europeDiscNat',
                                                    imageSize: 600,
                                                    ownImagePath:'https://eumetview.eumetsat.int/static-images/MSG/RGB/NATURALCOLOR/FULLRESOLUTION/IMAGESDisplay/VazIBqHF9k665',
                                                    updateInterval: 10*60*1000
                                        I hope this ok for you…
                                          Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
                                          @Stoffbeuteluwe ist that ok?
                                            chris1971
                                            Great!!!
                                            It’s working with the link… where did you find it?
                                            Regards, Christoph
                                            • 5 / 6
