    MMM-TTS
    text-to-speech
    19 Posts 4 Posters 15.0k Views 5 Watching
    • A
      alexyak @strawberry 3.141
      @strawberry-3.141 I could start looking at the module for voice rec. if you don’t mind.
        davericher @strawberry 3.141
        @strawberry-3.141 Not to be a debbie downer, but does electron not expose Chromes built in multi voice text to speech api?
        https://developers.google.com/web/updates/2014/01/Web-apps-that-talk-Introduction-to-the-Speech-Synthesis-API
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @davericher
          @davericher should be, but that wouldn’t work for people with serveronly mode
          D 1 Reply Last reply
            @strawberry-3.141 True, but it would work for every connected client
            • strawberry 3.141S
              @davericher if you like you can create a pr to let the user decide via config if he wants to use festival or speech synthesis :)
              • cowboysdudeC
                Question…this is what I"m trying to do…
                else if (/(HIDE)/g.test(data) && /(CLOCK)/g.test(data)) {
                          this.hide(0, {lockString: 'MMM-voice'});
                          this.sendNotification('MMM-TTS', 'Hiding Clock');
                        }  else if (/(SHOW)/g.test(data) && /(CLOCK)/g.test(data)) {
                          this.show(0, {lockString: 'MMM-voice'});
                        this.sendNotification('MMM-TTS', 'Showing clock');
                It works buttttttttttttttt the 1st time you fire it off it doesn’t stop LOL
                “Showing clock”…“showing clock”…“showing clock”…
                Same for Hiding clock
                Apparently I’m not using it correctly hahahhahhahhaha
                SO which is the correct way?
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                  @cowboysdude where did you put that code piece?
                  • cowboysdudeC
                    cowboysdude Module Developer @strawberry 3.141
                    @strawberry-3.141
                    checkCommands(data) {
                            if (/(HELP)/g.test(data)) {
                                if (/(CLOSE)/g.test(data) || (this.help && !/(OPEN)/g.test(data))) {
                                    this.help = false;
                                    this.interval = this.createInterval();
                                } else if (/(OPEN)/g.test(data) || (!this.help && !/(CLOSE)/g.test(data))) {
                                    this.help = true;
                                    clearInterval(this.interval);
                            } else if (/(HIDE)/g.test(data) && /(CLOCK)/g.test(data)) {
                              this.hide(300, {lockString: 'MMM-voice'});
                             //  if (this.hide){
                             // this.sendNotification('MMM-TTS', 'Hiding Clock');
                              this.show(300, {lockString: 'MMM-voice'});
                            //  this.sendNotification('MMM-TTS', 'Showing clock');
                    • strawberry 3.141S
                      @cowboysdude could it be that the output of tts is putting you in a loop because it is triggering the command again :D try to change the output of tts so it will not trigger any output and then see if it still occurs
                      • cowboysdudeC
                        OK have no idea what that means but I didn’t change anything and now this is all I get…
                        Error: SIOD ERROR: unbound variable : voice_us1_mbrola
                        at Socket. (/home/cowboysdude/MagicMirror/modules/MMM-TTS/node_modules/say/index.js:83:14)
                        at Socket.g (events.js:286:16)
                        at emitOne (events.js:96:13)
                        at Socket.emit (events.js:188:7)
                        at readableAddChunk (_stream_readable.js:176:18)
                        at Socket.Readable.push (_stream_readable.js:134:10)
                        at Pipe.onread (net.js:543:20)
                        • strawberry 3.141S
                          @cowboysdude For me it sounds like the output of tts showing clock triggered the voice module to recognize the command again, so tts said showing clock again -> infinite loop
                          Not sure what this error is
                          • cowboysdudeC
                            Thanks!!! I got it… can’t understand the jibberish it’s saying but I think TTS didn’t install properly…
                            FOR the record in simple form DO NOT use the same phrases in TTS that you use for sentences for voice…
                            if anyone needs examples please let me know I’ll be happy to help.
