Space between 2 modules
6 Posts 5 Posters 4.0k Views 3 Watching
    PointPubMedia
    I trying to reduce the space between 2 modules at the same location!
    Bottom right!
    I’m using MMM-ip and mmm-systemtemperature… I would like to be able to have no free space between these 2!
    • O Offline
      onetwankyfive
      +1 for this… I toyed with the css and even tried to combine the modules into one, but no such luck
        MichMich Admin
        This should be possible with some custom css, but it might require some fiddling.
          you can just put .module { margin-top: 10px;} in the custom.css this should work
          • K Offline
            KirAsh4 Moderator
            That would affect all modules though. Just keep that in mind.
              MichMich Admin
              Using the classes property in the config you can add custom classes to a module. After that you can use:
              .custom-class {
                  margin-top: 10px;
