    Really confused
    23 Posts 5 Posters 13.9k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @Duke86
      @Duke86
      We would have to know the error message to attempt to help you. So, run the mirror and make note of the error message, in its entirety. Then post it here in a code block using the </> option above your message window
        Duke86
        pi@raspberrypi:~ $ npm start
        npm ERR! Linux 4.9.59-v7+
        npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”
        npm ERR! node v6.12.3
        npm ERR! npm v3.10.10
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
        npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR! /home/pi/npm-debug.log
        pi@raspberrypi:~ $ ^C
        pi@raspberrypi:~ $
        Mykle1M N 2 Replies Last reply Reply Quote 0
          @Duke86
          You running npm start in the wrong directory.
          First enter cd MagicMirror and enter
          Then run npm start
          • N Offline
            ninjabreadman @Duke86
            @Duke86 Hi Duke, start with cd MagicMirror/ … you’re probably trying to start MM out of the wrong folder.
              Duke86
              @Mykle1 said in Really confused:
              npm start
              pi@raspberrypi:~ $ cd MagicMirror
              magicmirror@2.2.2 start /home/pi/MagicMirror
              sh run-start.sh
              /home/pi/MagicMirror/node_modules/electron/index.js:9
              throw new Error(‘Electron failed to install correctly, please delete node_modules/’ + path.basename(__dirname) + ’ and try installing again’)
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
              at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
              at Module._compile (module.js:570:32)
              at Object.Module._extensions…js (module.js:579:10)
              at Module.load (module.js:487:32)
              at tryModuleLoad (module.js:446:12)
              at Function.Module._load (module.js:438:3)
              at Module.require (module.js:497:17)
              at require (internal/module.js:20:19)
              at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              npm ERR! code ELIFECYCLE
              npm ERR! magicmirror@2.2.2 start: sh run-start.sh
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.2.2 start script ‘sh run-start.sh’.
              npm ERR! If you do, this is most likely a problem with the magicmirror package,
              npm ERR! not with npm itself.
              npm ERR! sh run-start.sh
              npm ERR! npm bugs magicmirror
              npm ERR! Or if that isn’t available, you can get their info via:
              npm ERR! npm owner ls magicmirror
              npm ERR! /home/pi/MagicMirror/npm-debug.log
              N Mykle1M 2 Replies Last reply Reply Quote 0
              • N Offline
                @Duke86 said in Really confused:
                Try rm -rf /home/pi/MagicMirror/node_modules/electron. Then run npm install electron.
                  The error message is telling you what you have to do. So, in your GUI, you can navigate to your MagicMirror/node_modules/ folder and delete the electron folder. Then open a terminal and cd MagicMirror and npm install
                    Duke86
                    I removed the folder and this happened
                    pi@raspberrypi:~/MagicMirror $ cd MagicMirror
                    bash: cd: MagicMirror: No such file or directory
                    pi@raspberrypi:~/MagicMirror $ nmp install
                    bash: nmp: command not found
                    pi@raspberrypi:~/MagicMirror $ ^C
                    D cruunnerrC 2 Replies Last reply Reply Quote 0
                      doubleT Module Developer @Duke86
                      You are already in the directory “MagicMirror”. cd (change directory to) can’t find the directory because you are already inside.
                      Just a typo, it’s “npm”, not “nmp”.
                        Duke86
                        npm ERR! errno -2
                        npm ERR! enoent
                        pi@raspberrypi:~ $
                          Sorry if this sounds a bit harsh, but to be honest, that’s an easy one that you can answer yourself with all the information you have in this thread already. You’re making the same mistake as yesterday.
                          Hint: Check where you are. Use “ls” (list content of current directory) and “cd”. Learn to read the path to know where you are.
                          • cruunnerrC Offline
                            cruunnerr @Duke86
                            u used “nmp install” instead of “npm install”
                            do exactly this:
                            cd
                            cd MagicMirror
                            npm install
                            wait for Installation complete. This will take a while. Just wait UNTIL u see the “pi@raspberrypi:” again and u are able to type new commands. Even if u can’t see an installation progress bar.
                            then type npm start or if u use ssh: DISPLAY=:0 npm start
                              Duke86
                              thanks you it has worked up until it said I need a config file
                                I guess you have to create a config file. ;) Did you read the Readme @ https://github.com/MichMich/MagicMirror (scroll down a little)?
                                The MagicMirror, as the readme points out, comes with a config example. Create a config file by copying the example file with this command:
                                cp config/config.js.sample config/config.js Use this command from the MagicMirror folder!
                                (The way this works is: copy | original/file.js | target/file.js)
                                  Duke86
                                  thanks, I think it works I will try now I really appreciate your help
                                  I will put the code down below
                                  pi@raspberrypi:~/MagicMirror $ npm run config:check
                                  magicmirror@2.2.2 config:check /home/pi/MagicMirror
                                  node tests/configs/check_config.js
                                  Checking file… /home/pi/MagicMirror/config/config.js
                                  Line 96 col 5 Label ‘file’ on statement.
                                  Line 96 col 5 Unexpected early end of program.
                                  Line 97 col 1 Unrecoverable syntax error. (100% scanned).
                                    Did you copy the config.js.example to config.js with the code above? Have you made any changes inside config.js yet?
                                    Can you cd into the config folder and tell us what ls (list) is showing?
                                      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                                        Duke86
                                        follwed your guide still got the same messsage
                                          cruunnerr
                                          In the sample config there is no line 96 !!!
                                          don’t know what u did, but maybe u should read a little more accurate as doubleT said before. I don’t want to attack you.
                                          Just delete your config file, copy this here and rename it to “config.js” and put it in your config folder. This should work
                                            Duke86
