    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.4k Views 28 Watching
    • G
      gauka12345
      Hi i got different problem am trying to install Miio to discover the sensors Numbers but i got error messages :
      pi@raspberrypi:~ $ npm install --save miio
      npm WARN saveError ENOENT: no such file or directory, open ‘/home/pi/package.json’
      /home/pi
      └── miio@0.14.0
      npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      • G
        gauka12345
        fix -
        sudo npm install -g miio
          barnosch
          I have now also the Yeelight Bulbs (Color) but i guess its not working to show the status in the mirror?
          or has @Albert2002 managed to get it working?
          I also only get a short id beginning with 56 or something wit the miio tool.
          I needed to install the Yeelight App in order to get the stuff discovered by the Amazon Echo . With the Mi Home app it was working to stear them, but not recognized in the Amazon App (took me a while to figure that out)
          • A
            Albert2002
            It’s still not working for me. I just think those are two different modules we need for. MMM-xiaomi is only for displaying the different Temperature readings and the state of the Windows sensors. And this does pretty well!
            I tried Openhub with the Yeelight binding. The idea was to get it on the mirror with mmm-openhabfloorplan
            I was only able to see my Yeelights in Openhab and the remote but whitout being able to switch them. Only to make them visible on the mirror its a bit to much effort I think. Maybe I did something wrong.
            As far as I understood the most important point is that you have to chose Singapore if you want to control your Yeelignts with Alexa. For Everything else there are a lot to tutorials around.
              mirko3000
              Yes the Yeelights are still not supported, I will need to order one for myself to actually implement that. Should not be an issue, at least the miio library seems to support it. Hope to get it running within the next months…
              • garblefluxG
                garbleflux Project Sponsor
                Hi mirko3000
                I’m very happy, thank you for the work. Your modul runs excellent, it’s exactly what I want.
                Thanks to your good dokumentation, my three xiaomi temperature sensors are working fine, I did order
                additional twelfe temperature- und window sensors.
                With the miio software, I’ ve got an token for the xiaomi smart hub. Any idea to use it? (chance LED color, etc.)
                Is there also a way to set a maximum temperature for warning, so it could be used as an additional fire sensor?
                It’s minimal: I’m trying to set the size of the charakters a few points up - with no success in the the css-file.
                Can you give me a hint?
                Thank you in advance
                Mike
                M 1 Reply Last reply
                  mirko3000 @garbleflux
                  Hi garbleflux,
                  happy to hear you like the module! :)
                  The token for the hub is required for the whole module to work, so I guess you are already using it (directly or via auto-token). If you want to use features of the smart hub, currently I have not implemented anything here. Need to check what the miio lib provides, maybe setting the light colors?
                  Maximum temperature could be implemented, but I doubt you really want to use this as fire sensor! :) Not much help if your mirror warns you about a fire.
                  About the character size: I use the default css classes “small” and “xsmall”. You could simply override them for the xiaomi elements via:
                  .xm-xiaomi .small {
                    font-size: 24px;
                  Best regards,
                  Mirko
                  • garblefluxG
                    Hi mirko3000
                    thank you for your kind reply. No, I dont want to use the xiaomi-sensor as a fire sensor ;-)
                    But I have a fine storeroom for some goods, so the temperature should be in a range from 14 and 18
                    degrees celcius. Otherwise I must take the goods and move them in the summertime in the colder
                    basement. Thats my intention to wish a maximum temperature.
                    Thanks again for your great work and your support!
                    Best wishes from Mike
                      Ok got it :) Here you go, added max temperature setting with latest version.
                      Best regards,
                      Mirko
                      • A
                        Albert2002
                        Am still impressed by your speed and your skill! Thank you for sharing your work with us!
                        • garblefluxG
                          Hi Mirko3000,
                          thank you! Great work.
                            pepebc
                            Mirko3000,
                            excellent module, I am about to receive the gateway. Now I have several RGB yelight bulbs and two Wi-Fi sockets.
                            I hope you add someday the management of sockets and yeelight.
                            At the moment I am managing it with scripts.
                              shgmongohh @Albert2002
                              @Albert2002
                              I have some problems to get the token. See my errors here.
                              Can anybody help me with the token?
                              Sebastian
                                shgmongohh
                                I like to change the colour and the font size of the values in the css. But nothing change.
                                Can anybody please explain, how to change?
                                .xm-xiaomi .small {
                                  font-size: 24px;
                                .xm-xiaomi {
                                    position: relative;
                                .xm-disabled {
                                  color: black;
                                .xm-icon {
                                  padding-left: 8px;
                                .xm-room-item {
                                  font-size: 22px;
                                  margin-bottom: -15px;
                                  z-index: 5;
                                .xm-room-title {
                                  display: inline-block;
                                  width: 40%;
                                  z-index: 5;
                                .xm-room-bars {
                                  width: 60%;
                                  z-index: 5;
                                .xm-legend-temp {
                                  position: absolute;
                                  height: 100%;
                                  width: 3px;
                                  background-color: #FF1493;
                                  left: 9%;
                                  z-index: 0;
                                .xm-legend-humid {
                                  position: absolute;
                                  height: 100%;
                                  width: 3px;
                                  background-color: blue;
                                  left: 42%;
                                  z-index: 0;
                                .xm-room-container
                                    height: 100%;
                                    min-height: 100%;
                                    height: 200px;
                                .xm-room {
                                    width: 33.33%;
                                    height: 33.33%;
                                  background-color: #228B22;
                                .xm-room-header {
                                  border-bottom-style : solid;
                                  border-width: 1px;
                                 margin: 5px;
                                 //padding: 5px;
                                .xm-left {
                                  float: left;
                                .xm-right {
                                  float: right;
                                .xm-room-temp-humid {
                                   margin: 5px;
                                .xm-room-temp {
                                    float: left;
                                    width: 50%;
                                    padding-top:2px;
                                .xm-room-humid {
                                    float: right;
                                    width: 50%;
                                    text-align: right;
                                    padding-top:2px;
                                .xm-room-icons {
                                   margin: 5px;
                                   vertical-align: bottom;
                                  // height: 100%;
                                .xm-door-icon {
                                  float: left;
                                  width: 33%;
                                  padding-top:5px;
                                .xm-light-icon {
                                  float: left;
                                  width: 33%;
                                  text-align: center;
                                  padding-top:5px;
                                .xm-vent-icon {
                                  float: right;
                                  width: 33%;
                                  text-align: right;
                                  padding-top:5px;
                                  mirko3000
                                  Hi, sorry I did not reply to your last comment, did you solve the issues there?
                                  About the CSS: basically you are at the right spot, adjusting these values (e.g. font-size) should change font size. What did you edit exactly? Did you try restarting MM after the changes?
                                    blinky1989dk
                                      barnosch
                                      @blinky1989dk said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                                      to my config file. that’s fine, but it can not connect to the gateway. but as soon as I add more then it will be the case
                                      so when i restart it does not start up :( what can i do? some have some bids
                                      sorry i have no idea, what you try to say with that sentence.
                                      B 1 Reply Last reply
                                        blinky1989dk @barnosch
                                        @barnosch my config file works. but as soon as i add mmm.xiaomi to config. then my config file does not work anymore and my mirror does not start up
                                        • yawnsY
                                          yawns Moderator
                                          Your config looks a bit misconfigured. Please remove these lines.
                                          If this is still not working, then please paste your entire config.
                                            blinky1989dk @yawns
                                            @yawns is dot work. so i had try to send config fil to you on pb
                                            • 5 / 8
