    22'' Display + 40cmx50cm IKEA Frame + PIR Sensor
    29 Posts 13 Posters 47.6k Views 15 Watching
      ryck Module Developer @MyMirror
      @MyMirror I don’t get any text on the display when it goes off, maybe the display is smart enough? Are you using the same software to turn it off?
        MyMirror @ryck
        Hi @ryck,
        i think it is python …
        I just get “Python 2 (IDLE)” on my menue.
        I’ll try to force an update with
        sudo apt-get update
        sudo apt-get upgrade
        sudo apt-get install --reinstall python3
        but, after reboot, nothing happens. I’ve got just python2 on my menue.
        (After searching in the main menue Editor …)
        OK - found python3 but without IDLE) - but this should not be the problem, or?
        But if it is “easy” to install the IDLE - can you give me a hint?
        I use pin 14 - as in the pir.py written - nothing happens … :-(
        I think, it is the missing line 7 in the pir.py.
        You wrote:
        You have to change line 7 to the location of the pir.py file like this:
        ExecStart=/usr/bin/python /path/to/your/pir.py
        But in my pir.py i didn’t find a line like this …
        Can you help me?
        MyMirror
          @MyMirror in the pir.py file you need to change only one thing, the GPIO data pin to which the PIR sensor is connected (you can double check yours here: https://pinout.xyz/). The line is this one: https://github.com/deg0nz/MagicMirror-Display-Controller/blob/master/pir.py#L8
          That should be all.
          The line 7 stuff is for the service (ie, run the script automatically every time the Pi reboots) and is in a different file: https://github.com/deg0nz/MagicMirror-Display-Controller/blob/master/pir_sensor.service#L7
            MyMirror
            Merry xmas :-),
            thanks … your script works - my monitor not really :-(
            If your script power off HDMI i’ll get a “HDMI”-Logo and “no Signal” … bad :-(
            It seems that i have to buy a different screen.
            Which one do you use? Is it available as 32’’ ?
            Greets
            MyMirror
              MyMirror
              You can see it here :-(
              –> https://1drv.ms/v/s!ApE0YZ4Ndle9jzjzH7u3vSCmXb7G
                doubleT Module Developer
                Nice mirror. Have you considered leading the cable to the right and down along the corner of the wall? Might look even cleaner. And if it’s a selfmade cable, I’d consider some white cable sleeving.
                  cornusandu @ryck
                  @ryck hello. Please, would you consider making a video on installing software steps for morons like me? I manage to install the module but after that I was lost completely. Following the github Magic Mirror pir control hdmi. If you would be kind enough to make that video please consider every step as I am a complete noob and a moron considering raspbian. I was lucky that there are a great number of videos on how to install Magic Mirror otherwise I would never been able to get it done. Thank you very much.
                  C R 2 Replies Last reply Reply Quote 0
                    cornusandu @cornusandu
                    @cornusandu said in 22’’ Display + 40cmx50cm IKEA Frame + PIR Sensor:
                    PS. I do not understand how to install and get it working Magic Mirror Display Control for the PIR
                      ryck Module Developer @cornusandu
                      @cornusandu I don’t think a video will help you, you just need to follow the instructions here: https://github.com/deg0nz/MagicMirror-Display-Controller
                      Make sure you you set the path and the the pin variable to the correct values and that’s it.
                      • floF
                        flo
                        @ryck Do you know the model you have been using for this (great) mirror? Probably there is something on ebay…
                          ryck Module Developer @flo
                          @flo You mean the monitor model? I don’t know for sure, I think is a viewsonic, but I’ll try to get the model later…
                          But to be honest, anything will do the part, just get anything cheap and start from there :)
                          • floF
                            flo
                            @ryck I just wanted to know the model, because the PIR seems to work well with this model (no input warning when suspending).
                              poopyurinal
                              I know this is an old thread, but do you recall what type of glue you used to glue the two frames together? Wood? Super? I can’t quite tell what the frame coating is made of.
                                ryck Module Developer @poopyurinal
                                @poopyurinal Just " No more nails" from unibond, but any wood glue will work. I don’t recommend superglue though…
                                • ejay-ibmE
                                  ejay-ibm Project Sponsor Module Developer
                                  Very nice idea to glue 2 frame ! I haven’t thought about doing that when I created my mirror . That would have save me lot of time !
                                  I’ll make my same usual request :) : Can we see the back and inside of your mirror ?
                                  Thank you
                                  Ejay
                                    jonno76
                                    Hi all.
                                    Just starting to get into this magic mirror stuff. Looks great!
                                    Anyway, could i ask how you mounted the screen in the two frames?
                                    Did you use additional wood to mount the screen on?
                                    This is the only bit that’s doing my head in!
                                    Cheers.
                                    Jonno.
                                    • G
                                      gkchimz @jonno76
                                      @ryck , yes please a photo will be helpful, just to illustrate.
                                      Also - was the visibility in the film ok? or was it too transparent?
