    DHT22 Sensor
    16 Posts 3 Posters 13.6k Views 6 Watching
    • W
      Wilco89
      https://github.com/momenso/node-dht-sensor?files=1
      Think it might be possible. Think it can Be useable.
      First hit in Google btw.
      Spit through code And learn? Or wait utill someone will have some sparetime.
        stefanh @Wilco89
        @Wilco89
        Thank your for great googeling :-)
        I will try to integrate it myself.
          Bangee Module Developer
          Where will I need to install node-dht-sensor using it with MagicMirror?
          a: ~/MagicMirror/ folder
          b: ~/MagicMirror/modules/ folder
          c: ~/MagicMirror/modules/MMM-Temperature/ folder
          using this command: npm install node-dht-sensor
          I would like to use it in node_helper.js inside a new module.
          Thanks!
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Bangee
            @Bangee go into the directory of your new module e.g. ~/MagicMirror/modules/MMM-Temperature/ and type npm init and follow the instructions, after that type npm install --save node-dht-sensor
              @strawberry-3-141 thank you! that worked for me.
              But now i’ve got this error:
              mm-0 App threw an error during load
              mm-0 Error: Module version mismatch. Expected 49, got 48.
              mm-0     at Error (native)
              mm-0     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:167:20)
              mm-0     at Object.Module._extensions..node (module.js:568:18)
              mm-0     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:167:20)
              mm-0     at Module.load (module.js:458:32)
              mm-0     at tryModuleLoad (module.js:417:12)
              mm-0     at Function.Module._load (module.js:409:3)
              mm-0     at Module.require (module.js:468:17)
              mm-0     at require (internal/module.js:20:19)
              mm-0     at Object.<anonymous> (/home/pi/MagicMirror/modules/temperature/node_helper.js:2:17)
              mm-0 Whoops! There was an uncaught exception...
              mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              mm-0 Launching application.
              On line 2:
              var sensorLib = require("node-dht-sensor");
              Node Version
              pi@raspberrypi:~/MagicMirror/modules $ node -v
              v6.3.1
              • strawberry 3.141S
                @Bangee depending on your other post about this problem in a different thread I assume you have a newer node version installed as you had on your old sd card, so maybe this will help you https://docs.npmjs.com/cli/rebuild
                  @strawberry-3-141 I’ve tried this before, but did not work for me. I’ve also made a reboot.
                  Will i need to have a downgrade?
                  • strawberry 3.141S
                    @Bangee never had such an issue before, did a clean install instead of copying images on sdcard, is there a reason why you copied an old image?
                      ah no, I’ve made a new installation on a brand new sd card.
                      I moved my own moduls. the temperature module is a new one.
                      But I’ve got the same with @paviro PIR moudle… :-(
                      • strawberry 3.141S
                        did you copy all the node_modules directories? if so this is propably the issue go to the module remove the directories and run npm install
                          No, I’ve installed the node_modules with npm install.
                          https://github.com/paviro/MMM-PIR-Sensor/issues/9
                          • strawberry 3.141S
                            then I have no clue sry
                              I could fix this with the same workaround as the PIR Sensor.
                              now its runnig but electron start up everything and crashes after loading all data.
                              Any idea howto debug this? ther is nothing in my error logs…
                              /var/log/messages:
                              pi@raspberrypi:~/MagicMirror/modules/temperature $ tail -f /var/log/messages
                              Sep 14 13:16:05 raspberrypi kernel: [706942.834881] gpiomem-bcm2835 3f200000.gpiomem: gpiomem device opened.
                              Sep 14 13:16:32 raspberrypi kernel: [706969.575020] gpiomem-bcm2835 3f200000.gpiomem: gpiomem device opened.
                              Sep 14 13:17:00 raspberrypi kernel: [706997.192894] gpiomem-bcm2835 3f200000.gpiomem: gpiomem device opened.
                              thats all… :-(
                              node_helper.js:
                              'use strict';
                              /* Magic Mirror
                               * Module: temperatur.js
                               * By Benjamin Angst
                               * MIT Licensed.
                              const NodeHelper = require('node_helper');
                              const sensorLib = require('node-dht-sensor');
                              		 start: function () {
                              			 console.log('Temperatur helper started ...');
                              		 // Subclass socketNotificationReceived received.
                              		   const self = this;
                              		   if (notification === 'REQUEST') {
                              			 var sensor = {
                              			     initialize: function () {
                              			         return sensorLib.initialize(22, 27);
                              			     read: function () {
                              			         var readout = sensorLib.read();
                              			         console.log('Temperature: ' + readout.temperature.toFixed(2) + 'C, ' +
                              			             'humidity: ' + readout.humidity.toFixed(2) + '%');
                              			         setTimeout(function () {
                              			             sensor.read();
                              			         }, 2000);
                              			         // Send Temperatur
                              			         self.sendSocketNotification('DATA',{
                              							temp: readout.temperature.toFixed(2),
                              							humidity: readout.humidity.toFixed(2)
                              			 if (sensor.initialize()) {
                              			     sensor.read();
                              			 } else {
                              			     console.warn('Failed to initialize sensor');
                              temperature.js
                              /* Magic Mirror
                               * By Benjamin Angst
                               * MIT Licensed.
                              Module.register("temperature",{
                                  // Default module config.
                                  defaults: {
                                      gpioPIN: 27,
                                      sensorType: 22, // Can be 22 or 11
                                      prependString: "Temperatur ",
                                  // Override dom generator.
                                  getDom: function() {
                                      wrapper.innerHTML = "T: " + this.temperature + " °C / H: " + this.humidity + " %";
                                      return wrapper;
                                  start: function() {
                                      this.temperature = 'fetching...';
                                      this.sendSocketNotification('REQUEST');
                                  if (notification === 'DATA') {
                                      this.temperature = payload.temp;
                                      this.humidity = payload.humidity;
                                      this.updateDom();
                                STEFF92
                                Hi, i’m a totally beginner and the temperature/ humidity sensor is one of my first modules i want to install by myself. Here is the github link:
                                https://github.com/bernardpletikosa/MMM-DHT-Sensor
                                This were the first things i did:
                                pi@raspberrypi:~ $ cd ~/MagicMirror/modules
                                pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/bernardpletikosa/MMM-DHT-Sensor.git
                                Klone nach 'MMM-DHT-Sensor'...
                                remote: Counting objects: 18, done.
                                remote: Total 18 (delta 0), reused 0 (delta 0), pack-reused 18
                                Entpacke Objekte: 100% (18/18), Fertig.
                                Prüfe Konnektivität... Fertig.
                                pi@raspberrypi:~/MagicMirror/modules $ cd MMM-DHT-Sensor
                                pi@raspberrypi:~/MagicMirror/modules/MMM-DHT-Sensor $ npm install
                                But then there came these lines:
                                npm WARN prefer global node-gyp@3.6.0 should be installed with -g
                                > rpi-dht-sensor@0.1.1 install /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor
                                > node-gyp rebuild
                                make: Entering directory '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/build'
                                  CC(target) Release/obj.target/node_dht_sensor/src/bcm2835.o
                                  CXX(target) Release/obj.target/node_dht_sensor/src/node-dht-sensor.o
                                  SOLINK_MODULE(target) Release/obj.target/node_dht_sensor.node
                                  COPY Release/node_dht_sensor.node
                                make: Leaving directory '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/build'
                                > Magic-Mirror-Module-DHT-Sensor@1.0.0 postinstall /home/pi/MagicMirror/modules/MMM-DHT-Sensor
                                > electron-rebuild -e ../../node_modules/electron-prebuilt
                                An unhandled error occurred inside electron-rebuild
                                Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                    at _callee$ (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                                    at tryCatch (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                                    at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                                    at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                                    at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                                    at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                                    at /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                                    at Object. (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                                    at Module._compile (module.js:570:32)
                                    at Object.Module._extensions..js (module.js:579:10)
                                    at Module.load (module.js:487:32)
                                    at tryModuleLoad (module.js:446:12)
                                    at Function.Module._load (module.js:438:3)
                                    at Module.runMain (module.js:604:10)
                                    at run (bootstrap_node.js:394:7)
                                    at startup (bootstrap_node.js:149:9)
                                npm WARN Magic-Mirror-Module-DHT-Sensor@1.0.0 No repository field.
                                npm WARN Magic-Mirror-Module-DHT-Sensor@1.0.0 No license field.
                                npm ERR! Linux 4.4.34-v7+
                                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                                npm ERR! node v6.10.0
                                npm ERR! npm  v3.10.10
                                npm ERR! code ELIFECYCLE
                                npm ERR! Magic-Mirror-Module-DHT-Sensor@1.0.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                                npm ERR! Exit status 255
                                npm ERR!
                                npm ERR! Failed at the Magic-Mirror-Module-DHT-Sensor@1.0.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-DHT-Sensor package,
                                npm ERR! not with npm itself.
                                npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                                npm ERR!     npm bugs Magic-Mirror-Module-DHT-Sensor
                                npm ERR! Or if that isn't available, you can get their info via:
                                npm ERR!     npm owner ls Magic-Mirror-Module-DHT-Sensor
                                npm ERR!     /home/pi/MagicMirror/modules/MMM-DHT-Sensor/npm-debug.log
                                The way i connected the dht11 sensor is shown in the following picture:
                                alt text
                                I dont know what i did wrong, can anyone help me please?
