    Memory effect with MM2
    16 Posts 8 Posters 11.6k Views 8 Watching
    • lolobyteL Offline
      lolobyte
      Hello girls and boy’s.
      I’m worry about a memory effect problem with the static text om my screen with MagicMirror.
      Can somebody explain us if my concern is right or is there no problem with this kind of permanent static text presentation.
      • schlachtkreuzer6S Offline
        schlachtkreuzer6
        It depends on the displaytechnology you are using. Generally you are right about that. But it is not that bad. https://en.wikipedia.org/wiki/Screen_burn-in
        Anyway my idea (the basic idea is very old, currently google is using something in android wear) is a module, with a Screen-burn-in protection that periodically shift the contents of the screen by a few pixels :)
        MMM-Anti-screen-burn-in ? :P
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
          @schlachtkreuzer6 you could create a class and add this to the body where the margin is different than the basic 60px and toggle the class to the body every 6 hours or so
          schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
            schlachtkreuzer6 @strawberry 3.141
            @strawberry-3.141 yeah but i´m a css noob. maybe you can explain that a little? many thanks!
              @schlachtkreuzer6
              MMM-Anti-Screen-Burn-In.css
              .MMM-Anti-Screen-Burn-In {
                  margin: 55px 55px 65px 65px; /*this would shift it 5 pixels higher and 5 pixels to the right side than the standard of 60px on each side*/
              MMM-Anti-Screen-Burn-In.js
              start: function(){
                  setInterval(() => {
                      document.querySelector("body").classList.toggle("MMM-Anti-Screen-Burn-In");
                  }, 6 * 60 * 60 * 1000); // every 6 hours
              getStyles: function(){
                  return ["MMM-Anti-Screen-Burn-In.css"];
              schlachtkreuzer6S lolobyteL K 3 Replies Last reply Reply Quote 1
                @strawberry-3.141 WOW! Nice :) Thanks!
                • lolobyteL Offline
                  lolobyte @strawberry 3.141
                  @strawberry-3.141
                  Great, i’ll try it!
                  • K Offline
                    kj3rra @strawberry 3.141
                    @strawberry-3.141 Hi. This is exactly what I need. However, I dont know how to proceed with the information. Yes, I made the .css and .js file and put them in a new folder inside the module folder, but how do I then “activate” this? Could someone be so kind and explain step by step how to make this work?
                    Sorry for not knowing this I presume is quite basic, but so far I only installed ready made modules :)
                    • W Offline
                      wladek
                      @strawberry-3.141 I tried to get your class into my MM but I don’t know where to put the .css and .js files and how to toggle them.
                        sdetweil @wladek
                        @wladek you add the css file to your module folder… and then modify your module.js code per the instructions above to load the css, and the timer code to invoke the other css…
                        you could also make a complete new module with a little more code…
                        make a folder
                        MM/modules/MMM-Anti-Screen-Burn-In
                        put the css file in that folder
                        create a new file in that folder
                        Module.register("MMM-Anti-Screen-Burn-In", {
                        start: function(){
                            setInterval(() => {
                        getDom: function(){
                          return wrapper
                        and the module to config.js
                           module: "MMM-Anti-Screen-Burn-In",
                           position: middle
                        • W Offline
                          wladek @sdetweil
                          @sdetweil Tried that before, somehow works now though, thanks!
                          Only problem I have now is that the module displays two line of text right across the rest of my modules:
                          module_8_MMM-Anti-Screen-Burn-In
                          I didn’t add any text to the .js or .css file tho and I can’t figure out how to get rid of it.
                            sdetweil @wladek
                            @wladek oops… if no getDom(), MM puts out some content
                            replace the js file with this
                            start: function(){
                                setInterval(() => {
                            getDom: function(){
                              return wrapper
                            • W Offline
                              wladek @sdetweil
                              @sdetweil That has fixed it, thank you so much!
                              • T Offline
                                toucherts
                                how do I then “activate” it?
                                Speed Test Scrabble Word Finder Solitaire
                                  sdetweil @toucherts
                                  @toucherts every 6 hours it toggles the class used to present the screen.
                                  I just made a little module package on github
                                  https://github.com/sdetweil/MMM-Anti-Screen-Burn-In
                                    moali6705 @sdetweil
                                    @sdetweil said in Memory effect with MM2:
                                    OK GOOD
