    This Day in History ticker?
    14 Posts 4 Posters 7.4k Views 3 Watching
    • yawnsY Offline
      yawns Moderator @donutsoup
      @donutsoup
      You mean just showing an excerpt of the actual text? You could try to fiddle around with CSS using text-overflow: ellipsis; but this does not support multiline text. So it would be very ugly :) Besides that, this is not possible at this point.
      Should be easy to implement something like maxLength: 200, to cut the text after 200 characters and to show a … at the end to indicate there is more text. I don’t see the use, as you cannot tap the … to see the whole text.
      I submitted a Pull Request, let’s see if cowboysdude accepts my changes to his module :)
      D cowboysdudeC 3 Replies Last reply Reply Quote 1
        donutsoup @yawns
        @yawns Thank you! Solid suggestions. Yeah an excerpt would work. I just want less info on the screen at a time, and more of them. What I was envisioning is like what pops up when you type a date into Wikipedia (is that a faux pas? Noob here…). This was under the “Feb 12” entry: 0_1518501360438_Screen Shot 2018-02-12 at 11.53.57 PM.png
          donutsoup @yawns
          @yawns Ok I think I found what I’m looking for here: http://history.muffinlabs.com
          Now how do I get it on my Magic Mirror? Again, Noob here.
          • cowboysdudeC Offline
            Just write a module.
              cowboysdude Module Developer @yawns
              @yawns said in This Day in History ticker?:
              @donutsoup
              I wouldn’t have a problem with that if it’s a config option. :)
              • yawnsY Offline
                yawns Moderator @cowboysdude
                @cowboysdude said in This Day in History ticker?:
                That’s exactly what I submitted: https://github.com/cowboysdude/MMM-History/pulls
                cowboysdudeC 1 Reply Last reply Reply Quote 3
                  Then request accepted :) Thank you! It’s done!
                  • N Offline
                    ninjabreadman @donutsoup
                    @donutsoup @cowboysdude That would make a slick module. You could cobble it together from various others, like MMM-json-feed to fetch your data and newsfeed to display it in discrete elements/items.
                      Wouldn’t need another module to get the data it already comes in json format… just put the info in rotating fashion and you’d have a new module … ;)
                      I started it here… Long day I’ll work on it more tomorrow ;)
                      https://github.com/cowboysdude/MMM-TDH
                      • N Offline
                        ninjabreadman @cowboysdude
                        @cowboysdude Agreed, I meant if @xela is looking to find code examples to construct a single module. Sorry if that wasn’t clear; best to keep in a single module.
