    This Day in History ticker?
    14 Posts 4 Posters 7.5k Views 3 Watching
      donutsoup @yawns
      @yawns Ok I think I found what I’m looking for here: http://history.muffinlabs.com
      Now how do I get it on my Magic Mirror? Again, Noob here.
      • cowboysdudeC Offline
        Just write a module.
          cowboysdude Module Developer @yawns
          @yawns said in This Day in History ticker?:
          @donutsoup
          You mean just showing an excerpt of the actual text? You could try to fiddle around with CSS using text-overflow: ellipsis; but this does not support multiline text. So it would be very ugly :) Besides that, this is not possible at this point.
          Should be easy to implement something like maxLength: 200, to cut the text after 200 characters and to show a … at the end to indicate there is more text. I don’t see the use, as you cannot tap the … to see the whole text.
          I submitted a Pull Request, let’s see if cowboysdude accepts my changes to his module :)
          I wouldn’t have a problem with that if it’s a config option. :)
          • yawnsY Offline
            yawns Moderator @cowboysdude
            @cowboysdude said in This Day in History ticker?:
            That’s exactly what I submitted: https://github.com/cowboysdude/MMM-History/pulls
            cowboysdudeC 1 Reply Last reply Reply Quote 3
              Then request accepted :) Thank you! It’s done!
              • N Offline
                ninjabreadman @donutsoup
                @donutsoup @cowboysdude That would make a slick module. You could cobble it together from various others, like MMM-json-feed to fetch your data and newsfeed to display it in discrete elements/items.
                  Wouldn’t need another module to get the data it already comes in json format… just put the info in rotating fashion and you’d have a new module … ;)
                  I started it here… Long day I’ll work on it more tomorrow ;)
                  https://github.com/cowboysdude/MMM-TDH
                  • N Offline
                    ninjabreadman @cowboysdude
                    @cowboysdude Agreed, I meant if @xela is looking to find code examples to construct a single module. Sorry if that wasn’t clear; best to keep in a single module.
                      cowboysdude Module Developer @ninjabreadman
                      @ninjabreadman said in This Day in History ticker?:
                      That’s okay you guys can finish it… I’m super busy… it’s there and the data part is done and coming in. Someone wants to make a complete module please let me sign it over. :)
