    This Day in History ticker?
    14 Posts 4 Posters 7.9k Views 3 Watching
      donutsoup
      Hi folks,
      I’ve found a handful of This Day in History modules and even RSS feeds, but they all show one fact per day. What I have in mind is a TDIH that’s like a news ticker. For example, if today were Feb. 23, then it would display “1836 - Battle of Alamo in Texas” and then four seconds later show “1887 - French Riviera hit by earthquake” and so on. Does such a thing already exist? If not, could someone help me code it?
      N 1 Reply Last reply Reply Quote 1
      • N Offline
        ninjabreadman @donutsoup
        @donutsoup I think @cowboysdude’s module should do what you want: https://forum.magicmirror.builders/topic/1803/mmm-history/9
        It’s a TDIH module that cycles through different years and their significance.
        D 1 Reply Last reply Reply Quote 2
          donutsoup @ninjabreadman
          @ninjabreadman Thank you! I wonder if there’s a way to make it display not quite so much info? Like just a little blurb before moving on to the next event on the day in question?
          • yawnsY Offline
            yawns Moderator @donutsoup
            @donutsoup
            You mean just showing an excerpt of the actual text? You could try to fiddle around with CSS using text-overflow: ellipsis; but this does not support multiline text. So it would be very ugly :) Besides that, this is not possible at this point.
            Should be easy to implement something like maxLength: 200, to cut the text after 200 characters and to show a … at the end to indicate there is more text. I don’t see the use, as you cannot tap the … to see the whole text.
            I submitted a Pull Request, let’s see if cowboysdude accepts my changes to his module :)
            D cowboysdudeC 3 Replies Last reply Reply Quote 1
              donutsoup @yawns
              @yawns Thank you! Solid suggestions. Yeah an excerpt would work. I just want less info on the screen at a time, and more of them. What I was envisioning is like what pops up when you type a date into Wikipedia (is that a faux pas? Noob here…). This was under the “Feb 12” entry: 0_1518501360438_Screen Shot 2018-02-12 at 11.53.57 PM.png
                donutsoup @yawns
                @yawns Ok I think I found what I’m looking for here: http://history.muffinlabs.com
                Now how do I get it on my Magic Mirror? Again, Noob here.
                • cowboysdudeC Offline
                  Just write a module.
                    cowboysdude Module Developer @yawns
                    @yawns said in This Day in History ticker?:
                    @donutsoup
                    I wouldn’t have a problem with that if it’s a config option. :)
                    • yawnsY Offline
                      yawns Moderator @cowboysdude
                      @cowboysdude said in This Day in History ticker?:
                      That’s exactly what I submitted: https://github.com/cowboysdude/MMM-History/pulls
                      cowboysdudeC 1 Reply Last reply Reply Quote 3
                        Then request accepted :) Thank you! It’s done!
                        • N Offline
                          @donutsoup @cowboysdude That would make a slick module. You could cobble it together from various others, like MMM-json-feed to fetch your data and newsfeed to display it in discrete elements/items.
                            Wouldn’t need another module to get the data it already comes in json format… just put the info in rotating fashion and you’d have a new module … ;)
                            I started it here… Long day I’ll work on it more tomorrow ;)
                            https://github.com/cowboysdude/MMM-TDH
                            • N Offline
                              ninjabreadman @cowboysdude
                              @cowboysdude Agreed, I meant if @xela is looking to find code examples to construct a single module. Sorry if that wasn’t clear; best to keep in a single module.
                                cowboysdude Module Developer @ninjabreadman
                                @ninjabreadman said in This Day in History ticker?:
                                That’s okay you guys can finish it… I’m super busy… it’s there and the data part is done and coming in. Someone wants to make a complete module please let me sign it over. :)
