This Day in History ticker?
Hi folks,
I’ve found a handful of This Day in History modules and even RSS feeds, but they all show one fact per day. What I have in mind is a TDIH that’s like a news ticker. For example, if today were Feb. 23, then it would display “1836 - Battle of Alamo in Texas” and then four seconds later show “1887 - French Riviera hit by earthquake” and so on. Does such a thing already exist? If not, could someone help me code it?
@donutsoup I think @cowboysdude’s module should do what you want: https://forum.magicmirror.builders/topic/1803/mmm-history/9
It’s a TDIH module that cycles through different years and their significance.
@ninjabreadman Thank you! I wonder if there’s a way to make it display not quite so much info? Like just a little blurb before moving on to the next event on the day in question?
You mean just showing an excerpt of the actual text? You could try to fiddle around with CSS using
text-overflow: ellipsis;but this does not support multiline text. So it would be very ugly :) Besides that, this is not possible at this point.
Should be easy to implement something likemaxLength: 200,to cut the text after 200 characters and to show a … at the end to indicate there is more text. I don’t see the use, as you cannot tap the … to see the whole text.I submitted a Pull Request, let’s see if cowboysdude accepts my changes to his module :)
@yawns Thank you! Solid suggestions. Yeah an excerpt would work. I just want less info on the screen at a time, and more of them. What I was envisioning is like what pops up when you type a date into Wikipedia (is that a faux pas? Noob here…). This was under the “Feb 12” entry:
@yawns Ok I think I found what I’m looking for here: http://history.muffinlabs.com
Now how do I get it on my Magic Mirror? Again, Noob here.
Just write a module.
@yawns said in This Day in History ticker?:
I wouldn’t have a problem with that if it’s a config option. :)
@cowboysdude said in This Day in History ticker?:
That’s exactly what I submitted: https://github.com/cowboysdude/MMM-History/pulls
Then request accepted :) Thank you! It’s done!
