    MagicMirror on Pi Zero W
    46 Posts 19 Posters 70.1k Views 21 Watching
    • kylelmartinK Offline
      kylelmartin @CaptnJB
      @CaptnJB @Iseknutz
      Silly me! I should have known that to get a wifi adapter to work I needed a wifi adapter!
      Fortunately I had a usb splitter with power supply and an edimax wifi lying around.
      After the update and upgrade its working well.
      Your help was greatly appreciated.
      Thanks from Texas!
      KLM
      • markbajajM Offline
        markbajaj @rootsudo
        @rootsudo Thank you!
        This along with post number 23 got my Pi Zero and Pi zero W working perfectly :)
          andreas-becker
          @rootsudo said in MagicMirror on Pi Zero W:
          The Beginnings:
          1. Place wpa_supplicant.conf in Boot folder of SD card
          2. Boot SD card and login
          3. Enable SSH: sudo raspi-config -> Select Interfacing Options -> select SSH -> select Enable -> select Finish
          After step 4 i recommend creating an empty file called “ssh” and also put it in the Boot folder of the SD card.
          So you don’t have to do step 6, cause ssh is started on boot with the default credentials (user: pi, password: raspberry)
          After boot, it did not open the browser, instead it just showed the console window.
          Problem was solved by installing x-server with sudo apt-get install xserver-xorg
          • 1 Offline
            12wsx
            my I please someone to make an image of sd card with installed and working MM? i’m trying about week to run MM on piZero and nothing… all the time diffrent errors which i don’t understand.
            Andrius okA 1 Reply Last reply Reply Quote 0
            • G Offline
              geeklimit @rootsudo
              • Andrius okA Offline
                Andrius ok @12wsx
                Hi @12wsx try this thread https://forum.magicmirror.builders/post/32731
                  bmarofsky
                  tried on stretch lite and got this
                  pi@raspberrypi:~/MagicMirror $ sudo npm install
                  npm WARN engine http-auth@3.2.3: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                  npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                  npm WARN engine apache-crypt@1.2.1: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                  npm WARN engine apache-md5@1.1.2: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                  npm WARN engine hawk@6.0.2: wanted: {"node":">=4.5.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
                    Mykle1 Project Sponsor Module Developer @bmarofsky
                    @bmarofsky
                    Warnings don’t necessarily mean that your mirror won’t work. Have you tried to run it after?
                    One thing to note: Installation of dependencies using sudo can, and often does, cause problems. So, in the future, simply use npm install without sudo
                    Updating your node should clear 4 of those 5 warnings
                      patoberli
                      I’m currently trying to do this with Debian Stretch, but the noobs image.
                      Anyway, the update.rc (command 18) doesn’t work here correctly, because they switched to systemd instead of system-V. There is no error, but the command doesn’t get added to the startup.
                      Replace the file content from step 14 to:
                      #! /bin/bash
                      ### BEGIN INIT INFO
                      # Provides:          startMagicMirror
                      # Required-Start:    $all
                      # Required-Stop:
                      # Default-Start:     2 3 4 5
                      # Default-Stop:
                      # Short-Description: Start MagicMirror software
                      ### END INIT INFO
                      cd /home/pi/MagicMirror
                      node serveronly &
                      sleep 45
                      sudo xinit /home/pi/startMidori.sh
                      After this, replace the command 18 with:
                      sudo systemctl enable startMagicMirror.sh
                      This should lead to the following output:
                      startMagicMirror.sh.service is not a native service, redirecting to systemd-sysv-install.
                      Executing: /lib/systemd/systemd-sysv-install enable startMagicMirror.sh
                      After this continue with the manual.
                      It currently only shows a white screen in my case, but I have just started and maybe that’s even normal, haven’t gotten that far yet in the manual.
                        patoberli @patoberli
                        Update1:
                        In my case the webserver was not accessible over the network, even after adding my client IP address to the /home/pi/MagicMirror/config/config.js file. This file is in the beginning not there, so first create a copy of the sample file:
                        cp /home/pi/MagicMirror/config/config.js.sample /home/pi/MagicMirror/config/config.js
                        After that, edit the file and replace the word localhost with 0.0.0.0. Also don’t forget to edit the ipWhitelist.
                        Found here: https://forum.magicmirror.builders/topic/5446/ipwhitelist-still-not-working/4
                        Still having just a white blank screen on my PI, but with the web browser from another pc it’s working :)
                          patoberli @rootsudo
                          Gave up for the moment and testing now the image from the other thread.
                          • H Offline
                            holotfi2003 @patoberli
                            @patoberli Have you tried to change Step 20 (from first page of this thread) startMidori.sh file to also refer to the same http://0.0.0.0:8080 that you put in your config.js file? I’m not sure that’ll solve your “white blank screen” problem, but it’s worth a shot…
                            Good luck!
                              patoberli @holotfi2003
                              @holotfi2003 I’ve switched now to a RPI3, also for performance reasons. I can’t say if I will test again with the zero… it would be nicer though, thanks to smaller size.
                              • 3 / 3
