    MMM-OlympicGames
    olympic games2022olympic winter gamesolympiabeijing
    41 Posts 15 Posters 30.4k Views 15 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @iwaldrum
      @iwaldrum sadly the api doesnt exist anymore, i will have a look after the olympic games have started for a new one
        dnks23 @strawberry 3.141
        @strawberry-3.141 check this out: https://sportradar.us/2017/12/2018-winter-olympics-api/
        strawberry 3.141S 1 Reply Last reply Reply Quote 1
          strawberry 3.141 Project Sponsor Module Developer @dnks23
          @dnks23 I’d prefer a different source, as sport radar needs an api key and is usually a paid service, not sure how much details the trial key allows access to. also the registration could take a while until the people get their keys
            @strawberry-3.141 Can you tell me what the original data source you used in the module? I can’t figure it out from the MMM-OlympicGames.js file.
              doubleT Module Developer @dnks23
              @dnks23 http://www.medalbot.com/api/v1/medals, it’s in the node_helper.js
              • O Offline
                onetwankyfive
                +1 for updating this module!
                  There doesn’t seem to be an official API. Without one, a website with an up-to-date medal table would have to be called and parsed regularly. There’s at least one API that can be found by reverse engineering, but solutions like these are not really legal (often it’s against the terms of use) and thus can’t/shouldn’t be shared/adviced on a public forum. Even if you get an API, the code that parses the JSON would have to be rewritten - more or less from zero, depending on the differences.
                    strawberry 3.141 Project Sponsor Module Developer @doubleT
                    @doubleT I just uploaded a new version with a different data source, pls keep in mind that the new data source works with 3 letter country codes in case you want to use the highlight option
                    [card:fewieden/MMM-OlympicGames]
                      cbo
                      I tried using the new version of the MMM-OlympicGames and the module only shows “Loading”
                        strawberry 3.141 Project Sponsor Module Developer @cbo
                        @cbo do you have any errors to report? terminal or electron? I just spinned up the module and got my data
                        • StoffbeuteluweS Offline
                          Stoffbeuteluwe Project Sponsor @strawberry 3.141
                          @strawberry-3-141Hi, does the module still work?
                            Link to module https://github.com/fewieden/MMM-OlympicGames
                            [1.1.0]
                            MagicMirror² version >= 2.15.0 required.
                            Fixed
                            • Installation instructions
                            Added
                            • Nunjuck template
                            • Dependency: node-fetch
                            • Dependency: lodash
                            • Github actions: build and changelog
                            • Github config files
                            Changed
                            • Data source
                            • Preview image
                            • Config options
                            • Country names are now translated with the Intl object
                            • Translations
                            Removed
                            • Dependency: request
                            • Travis-CI integration
                            W 1 Reply Last reply Reply Quote 2
                            • W Offline
                              Wenike @strawberry 3.141
                              @strawberry-3-141 Thank you for updating this!
                                mlhote
                                Hello, great job !!!
                                I update the module but It’s stay “Loading”
                                The log
                                0|MagicMirror | [02.02.2022 10:24.38.381] [ERROR]
                                0|MagicMirror | Error getting olympic game medals FetchError: invalid json response body at https://www.bloomberg.com/tosv2.html?vid=&uuid=eeef6240-8409-11ec-a0ac-73657468704e&url=L2dyYXBoaWNzL2JlaWppbmctMjAyMi1vbHltcGljcy1kYXRhL2N1cnJlbnQuanNvbg== reason: Unexpected token < in JSON at position 0
                                0|MagicMirror | at /home/pi/MagicMirror/modules/MMM-OlympicGames/node_modules/node-fetch/lib/index.js:273:32
                                0|MagicMirror | at runMicrotasks (:null:null)
                                0|MagicMirror | at processTicksAndRejections (internal/process/task_queues.js:93:5)
                                0|MagicMirror | at Class.getCountryMedals (/home/pi/MagicMirror/modules/MMM-OlympicGames/node_helper.js:54:36)
                                0|MagicMirror | {
                                0|MagicMirror | type: ‘invalid-json’
                                0|MagicMirror | }
                                What I have to do to repair ?
                                Sorry for my poor English
                                Mat
                                mumblebajM strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                • mumblebajM Offline
                                  mumblebaj Module Developer @mlhote
                                  @mlhote Did you run npm install in the MMM-OlympicGames folder?
                                    mlhote
                                    Yes
                                    it’s write on the github
                                      @mlhote I just clicked the link in your Error and it directs to the below.
                                      It seems to be working fine for me though
                                        strawberry 3.141 Project Sponsor Module Developer @mlhote
                                        @mlhote I had the same issue initially, but after telling the API that I’m not a server but actually using the latest version of the Google Chrome browser here it worked for me and I didn’t experience the same issue again.
                                        Maybe you changed the reload interval to something that is too frequent.
                                        Can you please show your config of the module?
                                          mlhote
                                          Great it’s work
                                          Thk at everybody
                                            mlhote
                                            Great it’s work 1 time !!!
                                            When i reboot MM, i have to click again on the url…
                                            see my config
                                            module: ‘MMM-OlympicGames’,
                                            position: ‘top_right’,
                                            disabled: false,
                                            // all your config options, which are different than their default values
                                            So the trouble is not fix
