    MMM-OlympicGames
    olympic games2022olympic winter gamesolympiabeijing
    41 Posts 15 Posters 31.5k Views 15 Watching
      doubleT Module Developer
      There doesn’t seem to be an official API. Without one, a website with an up-to-date medal table would have to be called and parsed regularly. There’s at least one API that can be found by reverse engineering, but solutions like these are not really legal (often it’s against the terms of use) and thus can’t/shouldn’t be shared/adviced on a public forum. Even if you get an API, the code that parses the JSON would have to be rewritten - more or less from zero, depending on the differences.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @doubleT
        @doubleT I just uploaded a new version with a different data source, pls keep in mind that the new data source works with 3 letter country codes in case you want to use the highlight option
        [card:fewieden/MMM-OlympicGames]
        Reply Quote 2
          cbo
          I tried using the new version of the MMM-OlympicGames and the module only shows “Loading”
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @cbo
            @cbo do you have any errors to report? terminal or electron? I just spinned up the module and got my data
            StoffbeuteluweS 1 Reply Last reply
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @strawberry 3.141
              @strawberry-3-141Hi, does the module still work?
              • strawberry 3.141S
                Link to module https://github.com/fewieden/MMM-OlympicGames
                [1.1.0]
                MagicMirror² version >= 2.15.0 required.
                Fixed
                • Installation instructions
                Added
                • Nunjuck template
                • Dependency: node-fetch
                • Dependency: lodash
                • Github actions: build and changelog
                • Github config files
                Changed
                • Data source
                • Preview image
                • Config options
                • Country names are now translated with the Intl object
                • Translations
                Removed
                • Dependency: request
                • Travis-CI integration
                W 1 Reply Last reply
                Reply Quote 2
                • W
                  Wenike @strawberry 3.141
                  @strawberry-3-141 Thank you for updating this!
                    mlhote
                    Hello, great job !!!
                    I update the module but It’s stay “Loading”
                    The log
                    0|MagicMirror | [02.02.2022 10:24.38.381] [ERROR]
                    0|MagicMirror | Error getting olympic game medals FetchError: invalid json response body at https://www.bloomberg.com/tosv2.html?vid=&uuid=eeef6240-8409-11ec-a0ac-73657468704e&url=L2dyYXBoaWNzL2JlaWppbmctMjAyMi1vbHltcGljcy1kYXRhL2N1cnJlbnQuanNvbg== reason: Unexpected token < in JSON at position 0
                    0|MagicMirror | at /home/pi/MagicMirror/modules/MMM-OlympicGames/node_modules/node-fetch/lib/index.js:273:32
                    0|MagicMirror | at runMicrotasks (:null:null)
                    0|MagicMirror | at processTicksAndRejections (internal/process/task_queues.js:93:5)
                    0|MagicMirror | at Class.getCountryMedals (/home/pi/MagicMirror/modules/MMM-OlympicGames/node_helper.js:54:36)
                    0|MagicMirror | {
                    0|MagicMirror | type: ‘invalid-json’
                    0|MagicMirror | }
                    What I have to do to repair ?
                    Sorry for my poor English
                    Mat
                    mumblebajM strawberry 3.141S 2 Replies Last reply
                    • mumblebajM
                      mumblebaj Module Developer @mlhote
                      @mlhote Did you run npm install in the MMM-OlympicGames folder?
                        mlhote
                        Yes
                        it’s write on the github
                        mumblebajM 1 Reply Last reply
                        • mumblebajM
                          @mlhote I just clicked the link in your Error and it directs to the below.
                          It seems to be working fine for me though
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @mlhote
                            @mlhote I had the same issue initially, but after telling the API that I’m not a server but actually using the latest version of the Google Chrome browser here it worked for me and I didn’t experience the same issue again.
                            Maybe you changed the reload interval to something that is too frequent.
                            Can you please show your config of the module?
                            J 1 Reply Last reply
                              mlhote
                              Great it’s work
                              Thk at everybody
                                mlhote
                                Great it’s work 1 time !!!
                                When i reboot MM, i have to click again on the url…
                                see my config
                                module: ‘MMM-OlympicGames’,
                                position: ‘top_right’,
                                disabled: false,
                                // all your config options, which are different than their default values
                                So the trouble is not fix
                                  justdreambig @strawberry 3.141
                                  @strawberry-3-141
                                  I hope you can help me… This is my first time posting in the message board so please excuse any formatting mistakes.
                                  the module is on my MM but just says loading…
                                  Here is the error
                                  [03.02.2022 12:44.24.245] [ERROR] Error getting olympic game medals FetchError: invalid json response body at https://www.bloomberg.com/tosv2.html?vid=&uuid=12216a4d-8532-11ec-99d5-6f52634e6775&url=L2dyYXBoaWNzL2JlaWppbmctMjAyMi1vbHltcGljcy1kYXRhL2N1cnJlbnQuanNvbg== reason: Unexpected token < in JSON at position 0
                                  I have clicked on the link and it takes you to a page that if you hold on the button it unlocks the data. I know someone else was dealing with that so I hope they found and answer
                                  Here is some info about what I have done so far
                                  MM version MagicMirror: v2.15.0
                                  Synology Docker v20.10.3-1239
                                  First I cloned the MMM-OlympicGames to my modules folder
                                  then added to my config file (see below)
                                  ]MM-Olympics.png )
                                          module: 'MMM-OlympicGames',
                                          position: 'bottom_left',
                                  then I ran npm install --production in ~/MagicMirror/modules/MMM-OlympicGames directory.
                                  added Locale to the default settings
                                  locale: "en-US",
                                  then I restarted the MM and it still says loading…
                                  I even tried removing it and staring over step by step this morning and still have loading…
                                  Any ideas to point me in the right direction would be most helpful. I really like this module and would like to use it
                                  KristjanESPERANTOK 1 Reply Last reply
                                  • KristjanESPERANTOK
                                    KristjanESPERANTO Module Developer @justdreambig
                                    I also had the “invalid json response” problem. After I upgraded node-fetch to 3.x, it works fine.
                                    • strawberry 3.141S
                                      In the beginning, I had the same issues with the invalid response. But I never had to click the link in order to fix it, I just started using the fake user agent in the module. Every time I restart the mirror it’s loading the data for me.
                                      The module is not using an official API. Everything else I found is charging money for it or does not return data.
                                      I was hoping once the games are starting that some other APIs start spitting out some data, so I could potentially switch.
                                      I’m open to links from free JSON APIs that would solve your issues.
                                      • strawberry 3.141S
                                        Most sport news sites including the official olympic games website still show 0 medals.
                                          mlhote @KristjanESPERANTO
                                          @kristjanesperanto Couldyou explain how to upgrade ?
                                            KristjanESPERANTO Module Developer @mlhote
                                            @mlhote In the meantime it works also with node-fetch v2 for me, so an upgrade seems not to be necessary.
                                            One assumption is that this occurs when you restart the mirror several times. Then the API is often queried in a short time and therefore you are blocked.
